Changing data directory
brutzler
Post by brutzler » 2019-10-12 12:59
if i change the data directory e.g. from c:\data to d:\data.
Is it enough to make a matching entry in the hmailsever.ini and restart services, or do I have to make some changes on the database too?
Re: Changing data directory
Post by jimimaseye » 2019-10-12 15:32
If you are on v 5.6 or more then yes. That is the procedure.
brutzler
Post by brutzler » 2019-10-12 16:01
5.6.7-B2425 :D
THX
Post by mattg » 2019-10-12 22:46
Run the internal diagnostics to confirm, especially if you had an earlier version and later upgraded
