Deactivate Send
Lorbaro
Deactivate Send
Post by Lorbaro » 2019-10-10 16:45
is it possible to deactivate the send function completely for all clients on hmailserver? We moved our mail usage to the cloud but didnt import them to Exchange because we had huge issues with the server stability, mainly because of low RAM. Now we just use the old hmailserver if we want to check old mails, but some people still accidently send from the old hmail instead of the new Exchange.
Kind Regards
Re: Deactivate Send
Post by mattg » 2019-10-10 16:58
just turn off SMTP
Only allow connections via IMAP or POP3
Lorbaro
Re: Deactivate Send
Post by Lorbaro » 2019-10-10 16:59
Will the user get an Error if they try to send via hmail then? That would be a perfect easy solution! :)
Re: Deactivate Send
Post by mattg » 2019-10-10 17:15
try it - but yes
You may need to set the client SMTP server to be your cloud server
