In old days when I used Mail Daemon it had very useful feature that all incoming mail stayed in incoming queue until user downloads it. That allowed admin to reapply all incoming mail processing limitless number of times again and again on all mail in queue.
That was very helpful for easy tweaking especially spam filters as after change in settings admin could simply reapply filters to existing mail.
hMailserver does not work that way. Incoming mail is processed and stored in user's queue and cannot be proccessed again. At least I do not know that is possible.
That said, I am interested in suggestion how could I test spam filters on hMailServer other than waiting for another similar spam to arrive. Can I somehow store example spam mail and trick hMailServer to check it against filters?
How do you check antispam settings?
Re: How do you check antispam settings?
I don't think that's possible.
What type of filters were you thinking about testing?
I recheck with SpamAssassin
If it subsequent scans find spam it is moved to the spam@ account, or deleted if high
I have some custom logging included, and run on a schedule
(I have cut and pasted some of my script - so it may not work in isolation)
I do this
I do this
Function SpamAssassin_ReCheck()
'custom event
'uses functions: CustomMonthlyLog
'called from:
Const SACheckExclude = ""
Const SACheckVerboseLogging = False
Const Spam_email_Address = "spam@example.com"
const Spam_email_name = "SPAM"
Dim oApp, oDomain, oAccount, oIMAPFolder, oMessage, oTempDirectory, obMessage
Dim i, j, k, l, m, s, dRetainDate, RetCode, SpamC, TempResult, OriginalScore, OriginalDate
Dim RequiredScore, TempText, PreviousScore, PreviousDate, RetFullCode, RetTests, TestAgain
OTempDirectory = oApp.Settings.Directories.TempDirectory & "\"
dRetainDate = CDate(Now() - 50)
SpamC = "%comspec% /C C:\hMailServer\Events\spamc.exe -d " & oApp.Settings.AntiSpam.SpamAssassinHost & " -p "
SpamC = spamc & oApp.Settings.AntiSpam.SpamAssassinPort
Call CustomMonthlyLog("***** START New reScan for SPAM using SpamAssassin *****", "Re-Spam")
RetFullCode = "Error obtaining details"
For i = 0 To oApp.Domains.count-1
Set oDomain = oApp.Domains.item(i)
For j = 0 To oDomain.Accounts.count-1
Set oAccount = oDomain.Accounts.Item(j)
If (InStr(SACheckExclude, oAccount.Address) = 0) And oAccount.Active Then
Call CustomMonthlyLog("**** Testing mail for " & oAccount.address , "Re-Spam")
For l = 0 To oAccount.IMAPFolders.Count-1
Set oIMAPFolder = oAccount.IMAPFolders.Item(l)
If oIMAPFolder.Messages.Count > 0 And oIMAPFolder.Name = "Inbox" Then
For k = oIMAPFolder.Messages.Count -1 To 0 Step -1
Set oMessage = oIMAPFolder.Messages.Item(k)
If oMessage.InternalDate > dRetainDate And oMessage.Flag(1) = False Then
OriginalScore = 0.0
OriginalDate = 0.0
PreviousScore = 0.0
PreviousDate = 0.0
TestAgain = 0
' On Error Resume Next
For m = 0 To oMessage.Headers.Count -1
If oMessage.Headers.Item(m).Name = "X-example-re-spam" Then
TestAgain = -100
Call CustomMonthlyLog("Previously re-scanned so not tested again" , "Re-Spam")
If oMessage.Headers.Item(m).Name = "X-Spam-Status" Then
OriginalScore = oMessage.Headers.ItemByName("X-Spam-Status").Value
OriginalScore = Left(OriginalScore,InStr(OriginalScore," required"))
OriginalScore = Right(OriginalScore, Len(OriginalScore) - InStr(OriginalScore, ", score=")-7)
OriginalScore = CDbl(OriginalScore)
RequiredScore = OriginalScore
If oMessage.Headers.Item(m).Name = "X-Spam-Recheck-Score" Then
PreviousScore = oMessage.Headers.ItemByName("X-Spam-Recheck-Score").Value
PreviousScore = CDbl(PreviousScore)
PreviousDate = oMessage.Headers.ItemByName("X-Spam-Recheck-Date").Value
PreviousDate = CDate(PreviousDate)
If oMessage.Headers.Item(m).Name = "Date" Then
OriginalDate = oMessage.Headers.ItemByName("Date").Value
' OriginalDate = CDate(OriginalDate)
OriginalDate = Now()
End if
Next 'm
On Error Goto 0
If OriginalScore = 0.0 And PreviousScore = 0 Then TestAgain = TestAgain + 1
If PreviousScore = 0.0 And OriginalDate < DateAdd("h",-4,Now()) Then TestAgain = TestAgain + 2
If OriginalScore >= 0.0 And OriginalDate < DateAdd("h",-2,Now()) And PreviousScore >= 0 Then TestAgain = TestAgain + 4
If OriginalScore >= 0.0 And OriginalDate < DateAdd("h",-2,Now()) And PreviousScore > 0 And PreviousDate < DateAdd("h",-4,Now()) Then TestAgain = TestAgain + 8
If PreviousScore >= 0.0 And PreviousDate < DateAdd("h",-4,Now()) Then TestAgain = TestAgain + 16
If PreviousScore < 0.0 And OriginalScore < 0 Then TestAgain = 0
If TestAgain > 0 Then
TempText = " -c < " & Chr(34) & oMessage.FileName & Chr(34)
TempResult = 0
RetCode = RunCommandWithOutput(SpamC & TempText, 1, 0, otempdirectory & "message.txt", 1, 1)
TempResult = CDbl(Left(RetCode,Len(RetCode)-8))
On Error Goto 0
'delete if very high
Call CleanSubject(oMessage)
If TempResult > 25.0 Then
oIMAPFolder.Messages.DeleteByDBID(oMessage.ID) ' comment this line to NOT delete the message
If TempResult > 4.0 Then
TempText = " -R < " & Chr(34) & oMessage.FileName & Chr(34)
RetFullCode = RunCommandWithOutput(SpamC & temptext, 1, 0, oTempDirectory & "message_long.txt", 1, 1)
On Error Goto 0
' oMessage.Copy(oApp.Settings.PublicFolders.ItemByName("spam").id)
Set obMessage = CreateObject("hmailserver.Message")
obMessage.HeaderValue("X_example_re_spam") = True
obMessage.Body = oMessage.Body
If oMessage.HTMLBody Is Not Null Then
obMessage.HTMLBody = oMessage.HTMLBody
TempText = oApp.Settings.Directories.TempDirectory & "\AttachmentDropFolder\" & oMessage.ID
Call SaveAttachments(oMessage)
For m = oMessage.Attachments.Count - 1 To 0 Step -1
Call obMessage.Attachments.Add(TempText & "-" & oMessage.attachments.item(m).Filename)
Next 'm
On Error Goto 0
obMessage.Charset = oMessage.Charset
obMessage.Date = oMessage.Date
obMessage.From = oMessage.From
obMessage.Subject = oMessage.Subject
' obMessage.To = oMessage.To
obMessage.AddRecipient Spam_email_name, Spam_email_Address
obMessage.Flag(1) = true
obMessage.Save
Call LogItTest(obMessage)
If OriginalScore = 0 Then
oMessage.HeaderValue("X-Spam-Flag") = "YES"
If Int(TempResult) > 1 Then
oMessage.HeaderValue("X-Spam-Level") = Replace(Space(Int(TempResult))," ","*")
' TempText = " -R < " & Chr(34) & oMessage.FileName & Chr(34)
' TempText = RunCommandWithOutput(SpamC & TempText, 1, 0, oTempdirectory & "message_tests.txt", 1, 1)
TempText = "Yes, score=" & TempResult & " required=" & RequiredScore & " tests=" & TempText
oMessage.HeaderValue("X-Spam-Status") = TempText
'Add headers
TempText = InStr(RetFullCode, "---- ---------------------- --------------------------------------------------")
oMessage.HeaderValue("X-Spam-Recheck-Date") = CDate(Now)
oMessage.HeaderValue("X-Spam-Recheck-Score") = TempResult
If Len(RetFullCode) > 100 Then
' oMessage.HeaderValue("X-Spam-Report") = Right(RetFullCode,Len(RetFullCode)-InStr(RetFullCode, TempText) - 78)
End if
set oIMAPFolder = oApp.settings.Publicfolders.ItemByName("spam")
Call CustomMonthlyLog("**** Testing mail already sent to SPAM folder" , "Re-Spam")
If oIMAPFolder.Messages.Count > 0 Then
If oMessage.InternalDate < dRetainDate Then
If Left(oMessage.Subject,31) <> "[Resent by spam re-test script]" Then
TestAgain = 0
On Error Goto 0
If OriginalScore = 0 And PreviousScore = 0 Then TestAgain = TestAgain + 1
If PreviousScore = 0 And OriginalDate < DateAdd("h",-4,Now()) Then TestAgain = TestAgain + 2
If OriginalScore >= 0 And OriginalDate < DateAdd("h",-2,Now()) And PreviousScore >= 0 Then TestAgain = TestAgain + 4
If OriginalScore >= 0 And OriginalDate < DateAdd("h",-2,Now()) And PreviousScore > 0 And PreviousDate < DateAdd("h",-4,Now()) Then TestAgain = TestAgain + 8
If PreviousScore >= 0 And PreviousDate < DateAdd("h",-4,Now()) Then TestAgain = TestAgain + 16
If PreviousScore < 0 And OriginalScore < 0 Then TestAgain = 0
TempResult = 0
TempText = Left(oMessage.Subject & Space(40),40)
TempText = TempText & " " & Left(oMessage.Headers.ItemByName("From").Value & Space(55),55)
On Error Goto 0
If TempResult < -95 Then
Call CustomMonthlyLog("**** Whitelisted Message Found", "Re-Spam")
For l = oMessage.Attachments.Count - 1 To 0 Step -1
Call obMessage.Attachments.Add(TempText & "-" & oMessage.attachments.item(l).Filename)
Next 'l
' On Error Goto 0
For l = 0 To oMessage.Headers.Count -1
obMessage.HeaderValue(oMessage.Headers.Item(l).Name) = oMessage.Headers.Item(l).Value
Next 'l
obMessage.Subject = "[Resent by spam re-test script]" & oMessage.Subject
obMessage.AddRecipient "", oMessage.To
obMessage.Flag(1) = false
obMessage.Save
On Error Goto 0
'Add headers
Call CustomMonthlyLog(Right(RetFullCode,Len(RetFullCode)-InStr(RetFullCode, TempText) - 78), "Re-Spam")
End if
End if
Next 'k
End if
Call CustomMonthlyLog("ReScan completed", "Re-Spam")
I was thinking more along the lines of the filters i use to reject mail based on IP checking, helo, etc. I guess all of those could be recreated within spamassassin. Some are already there, like spamhaus.
That is a pretty nifty script. Please forgive my ignorance, but I'm coming up short on seeing it's usefulness, although I'm sure there is a good reason for it. Sometimes i need a slap upside the head to get set in the right direction. Could you share some insight? I mean, you're running it on a schedule so it's obviously not for merely testing new rules. Does it regularly find stuff that was missed on incoming scan?
I find the sanesecurity defs for ClamAV excellent
(I run Clam tests within Spamassassin)
The one thing, is that sometimes those defs pick up something an hour or two after it is received.
What my script does is trawl all unread mail in every inbox, looking for something that wasn't flagged as spam when it arrived, and test it to see if it is NOW spam, and if so remove it.
It finds a few a week that were missed initially, mostly thanks to the excellent work of the SaneSecurity Defs
Cool. Sounds great. I use the clamav/sane plugin too. Also download definitions hourly. I'll give that a try.
