Can hmailserver do this for me?
bamia
Post by bamia » 2019-09-30 05:41
Hello everyone,
I will try to detailed but brief.
I have a PLC with a program to communicate via TCP and it send email via SMTP port 25. That is not changeable.
I could not get this functionality to work and there are two possibilities:
1-The program is incorrect and has to be fixed.
2-The PLC is attempting to send email but it is blocked either by my ISP or my router or anything else other than the PLC.
Can intercept, transfer, re-route (whatever the proper terminology is) to hmailserver so I can determine if where the problem is? I don't care if the email leave my computer I just want to see some sort of a log of it or not.
I installed hmailserver and tried to get it to work but it is exhausting trying to learn too many things that really do not in any way interest me so I thought I should ask.
Thanks a lot
Re: Can hmailserver do this for me?
Post by mattg » 2019-09-30 09:04
Just install hmailserver, don't change ANY settings EXCEPT add an SMTP route that points to your other server (eg GMAIL) including credentials and port other than 25 (Gmail like many others accepts mail on port 587 using STartTLS or port 465 via SSL)
THEN add an IP range for your LAN, allowing external to external WITHOUT AUTH (Only for your LAN, NOT for the internet)
Open the windows firewall for port 25 on the machine that hmailserver is installed on
Then point your PLC program to the hmailserver IP address
It should just work
bamia
Post by bamia » 2019-10-01 07:33
Thanks mattg. I resolved most of the issues and have one that I can not figure out after hours of searching and reading which is "550 A valid address is required"
I understand that is a result of "RCPT TO:" being blank. If that I'm correct why are there two lines of "RCPT TO" ?
"SMTPD" 8960 389 "2019-09-30 23:27:41.790" "104.205.96.30" "SENT: 220 KAL-PC ESMTP"
"SMTPD" 11540 389 "2019-09-30 23:27:41.836" "104.205.96.30" "RECEIVED: EHLO TMAIL_C"
"SMTPD" 11540 389 "2019-09-30 23:27:41.837" "104.205.96.30" "SENT: 250-KAL-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 8936 389 "2019-09-30 23:27:41.902" "104.205.96.30" "RECEIVED: MAIL FROM:<kal@mywebiste.ca>"
"SMTPD" 8936 389 "2019-09-30 23:27:41.904" "104.205.96.30" "SENT: 250 OK"
"SMTPD" 11540 389 "2019-09-30 23:27:41.931" "104.205.96.30" "RECEIVED: RCPT TO:<kal@mywebsite.ca>"
"SMTPD" 11540 389 "2019-09-30 23:27:41.933" "104.205.96.30" "SENT: 250 OK"
"SMTPD" 8960 389 "2019-09-30 23:27:41.944" "104.205.96.30" "RECEIVED: RCPT TO:"
"SMTPD" 8960 389 "2019-09-30 23:27:41.945" "104.205.96.30" "SENT: 550 A valid address is required."
"SMTPD" 8936 389 "2019-09-30 23:27:41.975" "104.205.96.30" "RECEIVED: DATA"
"SMTPD" 8936 389 "2019-09-30 23:27:41.976" "104.205.96.30" "SENT: 354 OK, send."
"SMTPD" 9580 389 "2019-09-30 23:27:42.043" "104.205.96.30" "SENT: 250 Queued (0.064 seconds)"
"SMTPD" 11540 389 "2019-09-30 23:27:42.050" "104.205.96.30" "RECEIVED: QUIT"
bamia
Post by bamia » 2019-10-01 07:40
Ok, so I added and email address in CC and now have no errors but I haven't received any emails :mrgreen:
Post by mattg » 2019-10-01 15:50
hMailServer issues this error message if a SMTP client tries to specify a recipient address which is not valid (which has an incorrect syntax).
https://www.hmailserver.com/documentati ... sages_smtp
bamia wrote:
2019-10-01 07:40
Show more logs please
Also run this and post the results
viewtopic.php?f=20&t=30914
bamia
Post by bamia » 2019-10-01 19:19
Hello mattg,
Here's more logs. That line with PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP, is that a problem?
"SMTPD"	8960	586	"2019-10-01 00:31:49.455"	"104.205.96.30"	"SENT: 220 KAL-PC ESMTP"
"SMTPD"	9516	586	"2019-10-01 00:31:49.506"	"104.205.96.30"	"RECEIVED: EHLO TMAIL_C"
"SMTPD"	9516	586	"2019-10-01 00:31:49.507"	"104.205.96.30"	"SENT: 250-KAL-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	4240	586	"2019-10-01 00:31:49.561"	"104.205.96.30"	"RECEIVED: MAIL FROM:<kal@mywebsite.ca>"
"SMTPD"	4240	586	"2019-10-01 00:31:49.563"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	8960	586	"2019-10-01 00:31:49.596"	"104.205.96.30"	"RECEIVED: RCPT TO:kal@mywebsite.ca"
"SMTPD"	8960	586	"2019-10-01 00:31:49.598"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	4240	586	"2019-10-01 00:31:49.611"	"104.205.96.30"	"RECEIVED: RCPT TO:kal@mywebsite.ca"
"SMTPD"	4240	586	"2019-10-01 00:31:49.613"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	8960	586	"2019-10-01 00:31:49.653"	"104.205.96.30"	"RECEIVED: DATA"
"SMTPD"	8960	586	"2019-10-01 00:31:49.654"	"104.205.96.30"	"SENT: 354 OK, send."
"SMTPD"	9580	586	"2019-10-01 00:31:49.691"	"104.205.96.30"	"SENT: 250 Queued (0.032 seconds)"
"SMTPD"	4240	586	"2019-10-01 00:31:49.698"	"104.205.96.30"	"RECEIVED: QUIT"
"SMTPD"	4240	586	"2019-10-01 00:31:49.698"	"104.205.96.30"	"SENT: 221 goodbye"
"SMTPD"	8960	589	"2019-10-01 00:39:35.258"	"104.205.96.30"	"SENT: 220 KAL-PC ESMTP"
"SMTPD"	8960	589	"2019-10-01 00:39:35.313"	"104.205.96.30"	"RECEIVED: EHLO TMAIL_C"
"SMTPD"	8960	589	"2019-10-01 00:39:35.314"	"104.205.96.30"	"SENT: 250-KAL-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	4240	589	"2019-10-01 00:39:35.352"	"104.205.96.30"	"RECEIVED: MAIL FROM:<kal@mywebsite.ca>"
"SMTPD"	4240	589	"2019-10-01 00:39:35.354"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	4240	589	"2019-10-01 00:39:35.378"	"104.205.96.30"	"RECEIVED: RCPT TO:kal@mywebsite.ca"
"SMTPD"	4240	589	"2019-10-01 00:39:35.380"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	9516	589	"2019-10-01 00:39:35.387"	"104.205.96.30"	"RECEIVED: RCPT TO:kal@mywebsite.ca"
"SMTPD"	9516	589	"2019-10-01 00:39:35.390"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	4240	589	"2019-10-01 00:39:35.396"	"104.205.96.30"	"RECEIVED: DATA"
"SMTPD"	4240	589	"2019-10-01 00:39:35.396"	"104.205.96.30"	"SENT: 354 OK, send."
"SMTPD"	9580	589	"2019-10-01 00:39:35.437"	"104.205.96.30"	"SENT: 250 Queued (0.032 seconds)"
"SMTPD"	11540	589	"2019-10-01 00:39:35.443"	"104.205.96.30"	"RECEIVED: QUIT"
"SMTPD"	11540	589	"2019-10-01 00:39:35.443"	"104.205.96.30"	"SENT: 221 goodbye"
"SMTPD"	8960	604	"2019-10-01 00:42:32.233"	"104.205.96.30"	"SENT: 220 KAL-PC ESMTP"
"SMTPD"	9516	604	"2019-10-01 00:42:32.271"	"104.205.96.30"	"RECEIVED: EHLO TMAIL_C"
"SMTPD"	9516	604	"2019-10-01 00:42:32.271"	"104.205.96.30"	"SENT: 250-KAL-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	8960	604	"2019-10-01 00:42:32.339"	"104.205.96.30"	"RECEIVED: MAIL FROM:<kal@mywebsite.ca>"
"SMTPD"	8960	604	"2019-10-01 00:42:32.341"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	9516	604	"2019-10-01 00:42:32.378"	"104.205.96.30"	"RECEIVED: RCPT TO:kal@mywebsite.ca"
"SMTPD"	9516	604	"2019-10-01 00:42:32.380"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	11540	604	"2019-10-01 00:42:32.391"	"104.205.96.30"	"RECEIVED: RCPT TO:kal@mywebsite.ca"
"SMTPD"	11540	604	"2019-10-01 00:42:32.394"	"104.205.96.30"	"SENT: 250 OK"
"SMTPD"	8960	604	"2019-10-01 00:42:32.402"	"104.205.96.30"	"RECEIVED: DATA"
"SMTPD"	8960	604	"2019-10-01 00:42:32.402"	"104.205.96.30"	"SENT: 354 OK, send."
"SMTPD"	9580	604	"2019-10-01 00:42:32.440"	"104.205.96.30"	"SENT: 250 Queued (0.032 seconds)"
"SMTPD"	11540	604	"2019-10-01 00:42:32.475"	"104.205.96.30"	"RECEIVED: QUIT"
bamia
Post by bamia » 2019-10-01 19:20
Here is the diagnostic results:
2019-10-01   Hmailserver: 5.6.7-B2425
DOMAINS
     (No Domains Entered)
IP RANGES
IP: 104.205.96.30 - 104.205.96.32     Priority: 25     Name: plc
     POP3:   True                              Antivirus:  False
     External To External -  True              External To External - False
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "EXTERNAL.TLD"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Host: Domain0.com         Empty sender:       True  Batch recipients:   100
        Loop limit:           5
        Recipient hosts:     15
  Routes:
    toxxxxxxxxxxxxx.ca       - S: Local   R: Local  - Addr: All         !! Target does not resolve !!
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-10-01.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-10-01.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by mattg » 2019-10-02 01:40
bamia wrote:
2019-10-01 19:19
No, that's fine
That is your server detailing what it can do
That log shows 3 messages accepted normally
Can you also enable Application, debug and TCPIP logging and try to send another message
As for your diagnostics, there are two small issues which probably don't affect your issue
#1 you have a default domain set - remove that unless you KNOW that you need it please
#2 The SMTP route that is set doesn't resolve
If that route matches the recipient in your test email - that MAY be your problem
bamia
Post by bamia » 2019-10-02 03:55
Thanks mattg. I will have to admit defeat and move on as I spent too much time troubleshooting software that I wanted to use to troubleshoot a PLC!!!!!!!!!!!
That is just insane.
Thanks Again.
Post by mattg » 2019-10-02 03:58
This really should be easy
But you are correct the PLC should allow proper email server configurations
bamia
Post by bamia » 2019-10-02 05:37
Thanks mattg. I got it working and I'm sure it's easy for those who know what they're doing and that's where I fail as I have very little understanding of networking and TCP/IP and all that. I would love to learn and most certainly will set time for it in the next months. For now I got it working by trial and error and by looking and the debug as you suggested.
Thanks a lot. Very much appreciated.
