Rule to reply to the sender of an external account address
brimaud
Post by brimaud » 2019-09-19 10:12
Hello
I want to create a rule to reject the big mails and send a reply to the sender to say that the mail is rejected.
It seems that messages coming from an external account are actually filtered but the sender does not receive the answer. I tested this with multiple addresses. The message does not go in spam.
the log file give no error
however it works with an internal account.
I work with version 5.6.7-B2425 in French.
Please can you reproduce it and tell me how to make it work correctly
Thank you
Bruno
Re: Rule to reply to the sender of an external account address
Post by mattg » 2019-09-19 13:38
Run this and post the results please
viewtopic.php?f=20&t=30914
brimaud
Post by brimaud » 2019-09-19 16:01
This is the diag file
Thank you
HMSDiagnostic_201909191556.zip
(2.77 KiB) Downloaded 137 times
Post by mattg » 2019-09-20 00:55
In your My computer range you have NOT allowed Local to external
That will stop all mail being sent out from your server, including replies generated from rules
ALSO, you have current errors
Can you please show your error log
E:\hmailserver\Logs\ERROR_hmailserver_2019-09-19.log
Does this machine have multiple NICs (network cards)?
brimaud
Post by brimaud » 2019-09-20 08:39
I've actived the option but the result is bad
The error is about the backup
Please See the attached files.
I send you a new diag file
The machine have only one network card
Thank you very much
Bruno
HMSDiagnostic_201909200831.zip
(3.41 KiB) Downloaded 138 times
Post by mattg » 2019-09-21 00:04
brimaud wrote:
2019-09-20 08:39
What does 'bad' mean in this instance?
Your IP range looks fine
Your Route should have sender = A remote address
SMTP >> Advanced >> Bind to local address could be blank (but may not matter)
You should NOT allow SSLv3.0
Otherwise looks OK to me
If you are still having issues, enable all logging, rename today's logs, Create your issue (send and reply to an external address), wait 90 seconds, then show all logs created
brimaud
Post by brimaud » 2019-09-23 08:09
Hello
"Bad" mean that it not work correctly. The sender does not recieve the reply.
See look the attached log file.
I use the external address **********removed*************
With this addresse I send a message at **********removed*************
The subject have to contain the word "test"
If you send me a message with the subject "test", you have to recieve a reply from me.
Bruno
log.zip
(11.25 KiB) Downloaded 131 times
Reason: email address removed
Post by mattg » 2019-09-23 10:34
do you have smtp logging enabled?
brimaud
Post by brimaud » 2019-09-23 11:13
Hello
This is the SMTP logging :
"SMTPC" 1528 26162 "2019-09-23 11:07:42.969" "212.227.15.184" "RECEIVED: 220 kundenserver.de (mreue109) Nemesis ESMTP Service ready"
"SMTPC" 1528 26162 "2019-09-23 11:07:42.969" "212.227.15.184" "SENT: EHLO 192.168.123.7"
"SMTPC" 1544 26162 "2019-09-23 11:07:43.016" "212.227.15.184" "RECEIVED: 250-kundenserver.de Hello 192.168.123.7 [92.245.150.143][nl]250-8BITMIME[nl]250-AUTH LOGIN PLAIN[nl]250 SIZE 69920427"
"SMTPC" 1544 26162 "2019-09-23 11:07:43.016" "212.227.15.184" "SENT: AUTH LOGIN"
"SMTPC" 2004 26162 "2019-09-23 11:07:43.047" "212.227.15.184" "RECEIVED: 334 VXNlcm5hbWU6"
"SMTPC" 2004 26162 "2019-09-23 11:07:43.047" "212.227.15.184" "SENT: YnJ1bm8ucmltYXVkQGJlY3Qtc2FzLmZy"
"SMTPC" 172 26162 "2019-09-23 11:07:43.094" "212.227.15.184" "RECEIVED: 334 UGFzc3dvcmQ6"
"SMTPC" 172 26162 "2019-09-23 11:07:43.094" "212.227.15.184" "SENT: ***"
"SMTPC" 2060 26162 "2019-09-23 11:07:43.141" "212.227.15.184" "RECEIVED: 235 Authentication succeeded"
"SMTPC" 2060 26162 "2019-09-23 11:07:43.141" "212.227.15.184" "SENT: ***"
"SMTPC" 2004 26162 "2019-09-23 11:07:43.188" "212.227.15.184" "RECEIVED: 250 Requested mail action okay, completed"
"SMTPC" 2004 26162 "2019-09-23 11:07:43.188" "212.227.15.184" "SENT: RCPT TO:**********removed*************
"SMTPC" 172 26162 "2019-09-23 11:07:43.235" "212.227.15.184" "RECEIVED: 250 OK"
"SMTPC" 172 26162 "2019-09-23 11:07:43.235" "212.227.15.184" "SENT: DATA"
"SMTPC" 2060 26162 "2019-09-23 11:07:43.297" "212.227.15.184" "RECEIVED: 354 Start mail input; end with <CRLF>.<CRLF>"
"SMTPC" 2060 26162 "2019-09-23 11:07:43.297" "212.227.15.184" "SENT: [nl]."
"SMTPC" 1544 26162 "2019-09-23 11:07:43.469" "212.227.15.184" "RECEIVED: 250 Requested mail action okay, completed: id=1MCKO4-1iLhzJ0VRS-009QOn"
"SMTPC" 1544 26162 "2019-09-23 11:07:43.469" "212.227.15.184" "SENT: QUIT"
"SMTPC" 1528 26162 "2019-09-23 11:07:43.531" "212.227.15.184" "RECEIVED: 221 kundenserver.de Service closing transmission channel"
It seam that the mail is sent correctly...
But where is it now ??? It is a mystery
Post by katip » 2019-09-23 11:34
PMFJI,
it seems you relay outgoing mail via "kundenserver.de" which accepts your message perfectly.
however, for the rest of delivery process you should apply to them if mail never arrives.
HMS 5.7, MariaDB 10.4.10, SA 4.0.0, ClamAV 0.103.8
brimaud
Post by brimaud » 2019-09-23 14:03
It is difficult to do some tests and catch loggings this afternoon because several clients send and recieve many mails during the day.
I'l try this evening when there will be fewer people.
brimaud
Post by brimaud » 2019-09-24 08:00
In attached zip file there is the log file
The story begin at the line number 54 at 07:54:28.804 Message 130115
The email sent is : {E449DC32-0BD3-4B4E-BCC2-A33D45380910} which I caught.
I wait few minutes to copy the log file after.
There olso the reply which it sent and my rule to reply
Thank you for your assistance
Bruno
Log3.zip
(15.15 KiB) Downloaded 132 times
Post by mattg » 2019-09-24 10:40
katip wrote:
2019-09-23 11:34
Yep
brimaud
Post by brimaud » 2019-09-24 16:00
ok I'll phone to my hosting...
But
Isn't it a problem that the from data is equal to <Empty>
"APPLICATION" 1376 "2019-09-24 07:55:29.192" "SMTPDeliverer - Message 130116: Delivering message from <Empty> to be.bect-sa@orange.fr. File: E:\hmailserver\Data\{E449DC32-0BD3-4B4E-BCC2-A33D45380910}.eml"
Bruno
Post by katip » 2019-09-24 16:18
brimaud wrote:
2019-09-24 16:00
don't worry. it's not visible From, it's Return-Path which is empty in headers.
receiver will see From (you) intact.
