Global Rule to delete spam
tarucan
Post by tarucan » 2019-09-18 10:42
Hi there, i receive 18~25 spam mail a day all with different headers but all have something in the source in common:
Return-Path: MarioWrightuoh@logosfts.it
Received: from logosfts.it (Unknown [154.66.245.47])
by mail.lianna.it with ESMTP
; Wed, 18 Sep 2019 09:15:52 +0200
Received: from unknown (125.55.86.48)
by relay-x.misswldrs.com with SMTP; Wed, 18 Sep 2019 08:07:43 -0500
Received: from [64.226.30.68] by nntp.pinxodet.net with ASMTP; Wed, 18 Sep 2019 07:49:54 -0500
Message-ID: <25A6B8E9.FC3F1641@logosfts.it>
Date: Wed, 18 Sep 2019 07:46:02 -0500
User-Agent: Mozilla 4.79 [en] (Win98; U)
MIME-Version: 1.0
To: "Joselyn" <thp@lianna.it>
Subject: Verrai da me il fine settimana?
Content-Type: text/html;
charset="iso-8859-1"
Content-Transfer-Encoding: base64
PCFkb2N0eXBlIGh0bWw+DQo8aHRtbD4NCjxoZWFkPg0KPG1ldGEgY2hhcnNldD0idXRmLTgiPg0K
PC9oZWFkPg0KPGJvZHk+DQo8dGFibGUgd2lkdGg9IjYwMCIgIGJvcmRlcj0iMCIgYWxpZ249ImNl
bnRlciIgIHN0eWxlPSJmb250LWZhbWlseTogQXJpYWw7IGZvbnQtc2l6ZTogMThweCI+DQo8dGJv
the first 6 char PCFkb2 are common to all email, the problem is this is not part of body, since i made a rule delete all mail
which body contain :"PCFkb2" but i still receive
Any suggestions plz?
Re: Global Rule to delete spam
Post by jimimaseye » 2019-09-18 10:49
Yes.
https://www.hmailserver.com/forum/viewt ... 21&t=28133
tarucan
Post by tarucan » 2019-09-18 12:35
well can you shwo me how to add custom rules for my specific spam mail plz?
still receive that email, cause the string seems not belong to any common headers,
it looks like an inline image.
Post by palinka » 2019-09-18 13:30
I have noticed a pattern of spam using .it domains starting with the letter L. You can see an example from my connection log project:
http://hmsfirewallbandemo.ddns.net/accr ... mit=Search
If you're absolutely positive you will never receive any legitimate email from Italy, you can create a rule based on this pattern.
criteria > from > regular expression =
^.+(\@l[a-z]+\.it).+$
action > delete message
Post by palinka » 2019-09-18 13:46
You could also try regular expression for the body:
^.*(PCFkb2).*$
tarucan
Post by tarucan » 2019-09-18 14:07
you forgot to say where do i have to put ^.*(PCFkb2).*$
and no i dont block all italy, just mail containing those weird 6 char.
thanks
Post by palinka » 2019-09-18 14:29
tarucan wrote:
2019-09-18 14:07
Same as the other one: criteria > body > regular expression
tarucan
Post by tarucan » 2019-09-18 16:03
ok but in global rules of hmailserver?
Post by palinka » 2019-09-18 16:08
tarucan wrote:
2019-09-18 16:03
Yes.
Post by palinka » 2019-09-18 17:04
tarucan wrote:
2019-09-18 10:42
I looked in my connection log database again.
a) For HELO entries .it domains that start with L and end with S (and no "-" or "."): ^l([a-z]+[s])\.it$ - 1,932 Hits
b) For HELO entries .it domains that start with L and DO NOT end with S (and no "-" or "."): ^l([a-z]+[^s])\.it$ - 186 Hits
While both a & b are spam, its clear which one spammers prefer. There were no listings for lianna.it in my logs (as should be expected). This could be a bit tougher for you actually being in Italy (which I did not notice earlier). :mrgreen: Someone else might find it useful, though.
tarucan
Post by tarucan » 2019-09-18 17:20
problem is that return and from are variable, always differenet, noone email has same, an not only .it
the spammer generate it randomly, so there is no way to use those as spam hook
Post by jimimaseye » 2019-09-18 17:53
So:
2019-09-18 10:49
Yes.
Spamassassin will likely to catch it and you will not need tailored rules.
tarucan
Post by tarucan » 2019-09-19 08:00
I'm sorry to say none of your solutions work to me, i still receiving that spam.
Spamassassin is installed but dont do much cause obsolete and impossible to find a working dns to update it.
Post by jimimaseye » 2019-09-19 08:48
There are hundreds of people using Spamassassin from those installation instructions and it is very effective. Of you are unable to 'update' it then you have not configured your system correctly. (You need to allow it through firewall adding exceptions etc). As for DNS, it will use the DNS of the machine it is installed on. Review the installation instructions carefully.
tarucan
Post by tarucan » 2019-09-19 17:24
jimimaseye, i followed instructions and firewall is not the problem, if you read what i said there are no dns where to download from, take a look to this code to update:
net stop spamassassin
sa-update.exe -v --nogpg --channelfile UpdateChannels.txt
net start spamassassin
this is straight from instructions you mention, well you are wrong.
This command has no effect cause UpdateChannels.txt is missing.
Then as i said already but you didnt read, i spent hours to look for valid dns but noone is working anymore.
As you can see, spamassassin dont get updated even if someone follow the instructions.
Post by palinka » 2019-09-19 21:49
C:\Program Files\JAM Software\SpamAssassin for Windows\UpdateChannels.txt
Contents:
updates.spamassassin.org
xsaupdate.jam-software.com
sa.zmi.at
sought.rules.yerp.org
spamassassin.heinlein-support.de
Post by jimimaseye » 2019-09-19 21:56
No no, palinka, that can't be true. Because updates.txt is missing (apparently) and therefore those instructions do not work. You can't possibly have such a file.
:roll:
Post by palinka » 2019-09-19 22:43
2019-09-19 21:56
:roll:
I figured he deleted it, so here's a way to recreate it. Although, if one system file is deleted accidentally, then who knows what else has been deleted?
ras07
Post by ras07 » 2019-09-20 20:45
Wait, wait, wait. Reset.
tarucan wrote:
2019-09-18 10:42
First off, since it's base64 encoded, the literal string "PCFkb2" isn't going to show up in any regex on the body. AFAIK you can't even get to the un-decoded base64 string in hMS; matching happens after decoding. (And I think SA works the same way although I wouldn't swear to it.)
Secondly, if you decode the base64, it simply says:
<!doctype html>
<html>
<head>
<meta charset="utf-8">
...etc...
So it's just generic HTML tags. Therefore even if you were able to filter on the un-decoded string, you'd end up filtering out virtually every HTML email.
Neither rules nor Spam Assassin are going to help you here.
Most HTML-encoded email includes two Content-Type sections; a plain-text section and an HTML section. I noticed that I get a fair bit of spam that has only HTML. By the looks of it this is what you are seeing.
You could add a simple check in the OnAcceptMessage handler to look for email with an empty .Body and a non-empty .HTMLBody . Unfortunately it may filter legit(ish) email as well, since I have seen this from some legit bulk mailers.
By chance are the spam emails in all-image form? Because I do see a lot of spam that is both HTML-only and nothing but a JPG image (an image of text, but no actual text). These are easy to filter out in OnAcceptMessage (and probably in SA as well).
Post by jimimaseye » 2019-09-20 20:51
ras07 wrote:
2019-09-20 20:45
The suggestion of spamassassin is because it may pick or up based on ip and source reputation. Also, sa is very weary of 'image only' emails.
ras07
Post by ras07 » 2019-09-20 21:07
2019-09-20 20:51
ras07 wrote:
2019-09-20 20:45
Understood; didn't mean that SA wouldn't catch it, just that using anything to try to filter on "PCFkb2" isn't going to be effective.
tarucan
Post by tarucan » 2019-09-21 05:18
2019-09-19 21:49
Contents:
sa.zmi.at
Thanks palinka, this worked to me and now SA update, but as raz07 said, base64 cant see normal string so SA nor hmail rules can do much on this spam. I can't use ip reputation cause i noticed this spam use random ip and dns and names for each spam msg.
They are expert, indeed it's been 4 months i'm looking for a way to stop them but unsuccessful.
I really hope this guy will die soon and someone will shutdown his pc, this is the only solution atm.
This kind of people are leech of society they dont deserve to be alive and consume my oxygen :lol: :evil: :twisted:
Post by mattg » 2019-09-21 06:14
Can you please show some hMailserver SMTPD logs showing one (or some) of these messages being delivered
Post by palinka » 2019-09-21 12:26
tarucan wrote:
2019-09-21 05:18
Search for a thread called "SA Bootcamp". Its an excellent workup of using SA-learn to build a bayes database. If you teach SA that those messages are spam, it will learn and score them higher. The most important thing is to keep and sort your spam so it can learn. Believe me, it works great and it's not difficult to setup.
