Help, Sending Mail
Hassan84
Help, Sending Mail
Post by Hassan84 » 2019-08-13 19:28
Hello , i have tried everything to send mail from local to external email like hotmail, gmail ...
Error Type: SMTP
Connection to recipients server failed.
Error: Could not connect to 127.0.0.4 on port 25 since this would mean connecting to myself.
DOMAINS
"Domain1.com" - thxxxxxxxxxxxxx.com Enabled: True
Enabled: False Max size: 0 Enabled: True
Max message size: 0 Header: Relaxed Plus addressing: False
Max size of accounts: 0 Body: Relaxed
Algorithm: SHA256 Greylisting: False
Private key: **********************
Selector: dkim
IP RANGES
Allow connections Other
SMTP: True Antispam : True !! 'Spam tests' not enabled !!
POP3: True Antivirus: True !! ANTIVIRUS NOT CONFIGURED !!
IMAP: True SSL/TLS: False
External To External - False
AUTOBANNED Local Addresses:
No entries
AUTOBAN
Autoban Enabled: True Max invalid logon attempts: 3
Minutes Before Reset: 30 (0.50 hours, 0.02 days)
Minutes to Autoban: 300 (5.00 hours, 0.21 days)
INCOMING RELAYS
No entries
MIRRORING Disabled
PROTOCOLS
SMTP
No. Connections: 0 No Retries: 4 Mins: 1 Plain Text: False Bind:
Host: EXTERNAL.TLD Empty sender: True Batch recipients:
Re: Help, Sending Mail
Post by jimimaseye » 2019-08-13 19:34
run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914 and post all the results without editing.
Hassan84
Post by Hassan84 » 2019-08-13 19:41
2019-08-13   Hmailserver: 5.6.7-B2425
DOMAINS
                                                Private key: d:\hmailserver\dkim.Domain1.com.pem
                                                Selector:    dkim
IP RANGES
IP: 185.234.218.0 - 185.234.218.255     Priority: 20     Name: Ban 1
     SMTP:  False                              Antispam :   True !! 'Spam tests' not enabled !!
     POP3:  False                              Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
     IMAP:  False                              SSL/TLS:     True
IP: 185.234.219.0 - 185.234.219.255     Priority: 20     Name: Ban 2
     SMTP:  False                              Antispam :  False
     POP3:  False                              Antivirus:  False
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-08-13.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-08-13.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL
Backup directory D:\HMailServer is writable.
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=          **
Port=              0
Server=            localhost
Internal=          0
Generated by HMSSettingsDiagnostics v1.96, Hmailserver Forum.
Post by mattg » 2019-08-13 23:25
Hassan84 wrote:
2019-08-13 19:28
Error Type: SMTP
That doesn't match the diagnostics shown
Please try to send a message, wait 90 seconds and then show all logs created
Hassan84
Post by Hassan84 » 2019-08-14 00:15
"DEBUG" 3224 "2019-08-14 00:04:16.113" "Creating session 101"
"TCPIP" 3224 "2019-08-14 00:04:16.113" "TCP - 192.168.1.102 connected to 192.168.1.101:25."
"DEBUG" 3224 "2019-08-14 00:04:16.113" "TCP connection started for session 100"
"SMTPD" 3224 100 "2019-08-14 00:04:16.113" "192.168.1.102" "SENT: 220 mail.the*******.com ESMTP"
"SMTPD" 508 100 "2019-08-14 00:04:16.129" "192.168.1.102" "RECEIVED: EHLO "
"SMTPD" 508 100 "2019-08-14 00:04:16.129" "192.168.1.102" "SENT: 250-mail.the*******.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 2972 100 "2019-08-14 00:04:16.129" "192.168.1.102" "RECEIVED: AUTH LOGIN"
"SMTPD" 2972 100 "2019-08-14 00:04:16.129" "192.168.1.102" "RECEIVED: ***"
"SMTPD" 2972 100 "2019-08-14 00:04:16.144" "192.168.1.102" "SENT: 235 authenticated."
"SMTPD" 2972 100 "2019-08-14 00:04:16.160" "192.168.1.102" "RECEIVED: MAIL FROM: <info@the********.com>"
"SMTPD" 2972 100 "2019-08-14 00:04:16.160" "192.168.1.102" "SENT: 250 OK"
"SMTPD" 2972 100 "2019-08-14 00:04:16.160" "192.168.1.102" "RECEIVED: RCPT TO: <*********@hotmail.com>"
"SMTPD" 508 100 "2019-08-14 00:04:16.160" "192.168.1.102" "RECEIVED: DATA"
"SMTPD" 508 100 "2019-08-14 00:04:16.176" "192.168.1.102" "SENT: 354 OK, send."
"DEBUG" 508 "2019-08-14 00:04:16.191" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 3916 "2019-08-14 00:04:16.191" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 3916 "2019-08-14 00:04:16.191" "Saving message: {13313FC0-61FE-461D-8BBA-37053C8D76CC}.eml"
"DEBUG" 3916 "2019-08-14 00:04:16.223" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 3916 100 "2019-08-14 00:04:16.223" "192.168.1.102" "SENT: 250 Queued (0.016 seconds)"
"DEBUG" 3984 "2019-08-14 00:04:16.223" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 4024 "2019-08-14 00:04:16.223" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 4024 "2019-08-14 00:04:16.223" "Delivering message..."
"APPLICATION" 4024 "2019-08-14 00:04:16.223" "SMTPDeliverer - Message 90: Delivering message from info@the*******.com to ***********@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{13313FC0-61FE-461D-8BBA-37053C8D76CC}.eml"
"DEBUG" 4024 "2019-08-14 00:04:16.223" "Applying rules"
"DEBUG" 4024 "2019-08-14 00:04:16.223" "Performing local delivery"
"DEBUG" 4024 "2019-08-14 00:04:16.238" "Local delivery completed"
"DEBUG" 4024 "2019-08-14 00:04:16.238" "Signing message using DKIM..."
"TCPIP" 4024 "2019-08-14 00:04:16.238" "DNS MX lookup: hotmail.com"
"TCPIP" 4024 "2019-08-14 00:04:16.269" "DNS - MX Result: 1 IP addresses were found."
"DEBUG" 4024 "2019-08-14 00:04:16.285" "Starting external delivery process. Server: mx1.norelay.link.net (127.0.0.4), Port: 25, Security: 2, User name: "
"DEBUG" 4024 "2019-08-14 00:04:16.285" "Creating session 102"
"TCPIP" 4024 "2019-08-14 00:04:16.285" "Connecting to 127.0.0.4:25..."
"DEBUG" 4024 "2019-08-14 00:04:16.285" "SMTPDeliverer - Message 90 - Connection failed: Could not connect to 127.0.0.4 on port 25 since this would mean connecting to myself."
"TCPIP" 4024 "2019-08-14 00:04:16.285" "TCPConnection - Could not connect to 127.0.0.4 on port 25 since this would mean connecting to myself."
"DEBUG" 4024 "2019-08-14 00:04:16.285" "Ending session 102"
Post by jimimaseye » 2019-08-14 00:21
You have some incorrect routing going on probably within your router or dns.
Post by mattg » 2019-08-14 00:23
Hassan84 wrote:
2019-08-14 00:15
That means one of two things
#1 your DNS is broken
#2 You have that entry in your local hosts file
If this happens for multiple recipients then that is your DNS that is broken
What DNS do you use (in Windows)? Try using 8.8.8.8 instead - that is Google's public DNS
Hassan84
Post by Hassan84 » 2019-08-14 06:08
I have 2 Servers, on of them is Domain Controller, and i use the DNS of the DC and the Router, which is working perfect.
I tried and change my DNS to Google's Public DNS. Nothing change same error message.
I checked firewall and everything possible and nothing change.
it's drive me crazy, Should i contact my ISP and see if there anything on their side is wrong ?
Post by mattg » 2019-08-14 07:26
hMailserver isn't even trying to reach the internet, your ISP won't help
Open a command prompt on the machine with hMailserver installed on it
and type
nslookup
type=mx
hotmail.com
and then post the results
Hassan84
Post by Hassan84 » 2019-08-14 08:02
when i try to nslookup it's give me DNS request timeout.
thanks for trying to help me , i appreciate it.
Post by mattg » 2019-08-14 09:19
Which shows that your local DNS is the problem
mikedibella
Post by mikedibella » 2019-08-14 16:55
Your nslookup command syntax is wrong.
At the command prompt, type:
nslookup -type=mx hotmail.com
Post the result.
Hassan84
Post by Hassan84 » 2019-08-14 19:26
Here's what happened
mikedibella
Post by mikedibella » 2019-08-14 20:34
Breakdown of the response:
Server:  localhost
Address:  ::1
This machine is hosting a DNS server, and it's DNS client is configured to use the local DNS server to resolve queries.
Non-authoritative answer:
A remote DNS server other than the server that is the authority for the zone queried (hotmail.com) has responded to the query. In other words, you cannot be sure that the response is authentic for the domain.
hotmail.com    MX preference = 10, mail exchanger = mx1.norelay.link.net
mx1.norelay.link.net    internet address = 127.0.0.4
Mail exchange for @hotmail.com is hosted on a server named mx1.norelay.link.net whose IP address is 127.0.0.4.
My guess is that your local DNS server is a caching server and you are forwarding from this server to another DNS server hosted by your ISP (is your ISP link.net?). Your ISP doesn't want you to host SMTP services, so it proxies MX record queries and returns the loopback address.
This is not an hMailServer configuration issue.
Hassan84
Post by Hassan84 » 2019-08-14 21:02
that what i was thinking of, i already sent them an email, will see what gonna happen.
Thank for your help.
Post by mattg » 2019-08-15 01:17
mikedibella wrote:
2019-08-14 16:55
Post the result.
Thanks for cleaning up after me mikedibella :D
Hassan84
Post by Hassan84 » 2019-08-22 17:39
Guys,
i'm here again after a week with trying to solve the problem, contacted with my ISP and they have nothing to do with it , i tried everything guys and nothing help same issues , if anyone have any new idea please help me .
mikedibella
Post by mikedibella » 2019-08-22 18:51
run this command:
nslookup -norecurse -debug -type=mx hotmail.com.
If you see
in the response, look for the last line starting with
ttl =
and wait at least that amount of time, then run the command again.
When you don't see
in the response, post the full response as text, not a screen image.
Hassan84
Post by Hassan84 » 2019-08-22 19:49
Microsoft Windows [Version 10.0.18362.295]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\Users\Administrator>nslookup -norecurse -debug -type=mx hotmail.com
Got answer:
HEADER:
opcode = QUERY, id = 1, rcode = NOERROR
header flags: response, auth. answer, recursion avail.
questions = 1, answers = 1, authority records = 0, additional = 0
QUESTIONS:
100.1.168.192.in-addr.arpa, type = PTR, class = IN
ANSWERS:
-> 100.1.168.192.in-addr.arpa
name = DC-1.*********.com
ttl = 1200 (20 mins)
Server: DC-1.*********.com
Address: 192.168.1.100
Got answer:
HEADER:
opcode = QUERY, id = 2, rcode = NXDOMAIN
questions = 1, answers = 0, authority records = 1, additional = 0
QUESTIONS:
hotmail.com.*********.com, type = MX, class = IN
AUTHORITY RECORDS:
-> *********.com
ttl = 3600 (1 hour)
primary name server = dc-1.*********.com
responsible mail addr = hostmaster.*********.com
serial = 519
refresh = 900 (15 mins)
retry = 600 (10 mins)
expire = 86400 (1 day)
default TTL = 3600 (1 hour)
Got answer:
HEADER:
opcode = QUERY, id = 3, rcode = SERVFAIL
header flags: response, recursion avail.
questions = 1, answers = 0, authority records = 0, additional = 0
QUESTIONS:
hotmail.com, type = MX, class = IN
*** DC-1.*********.com can't find hotmail.com: Server failed
mikedibella
Post by mikedibella » 2019-08-22 20:18
Start over. The period at the end of the command is significant.
Hassan84
Post by Hassan84 » 2019-08-22 20:38
I tried again , same answer !!
_________________________________________
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
Got answer:
    HEADER:
    QUESTIONS:
    ANSWERS:
Got answer:
    HEADER:
    QUESTIONS:
    AUTHORITY RECORDS:
    ->  **********.com
        ttl = 3600 (1 hour)
        primary name server = DC-1.*********.com
        serial  = 519
Got answer:
    HEADER:
    QUESTIONS:
_______________________________________________
and then i removed -norecurse from command and get this answer
C:\Users\Administrator>nslookup -debug -type=mx hotmail.com
Got answer:
    HEADER:
        header flags:  response, auth. answer, want recursion, recursion avail.
    QUESTIONS:
    ANSWERS:
Got answer:
    HEADER:
    QUESTIONS:
        hotmail.com.**********.com, type = MX, class = IN
    AUTHORITY RECORDS:
    ->  **********.com
        ttl = 3600 (1 hour)
        responsible mail addr = hostmaster.**********.com
        serial  = 519
Got answer:
    HEADER:
        opcode = QUERY, id = 3, rcode = NOERROR
        header flags:  response, want recursion, recursion avail.
        questions = 1,  answers = 1,  authority records = 0,  additional = 1
    QUESTIONS:
    ANSWERS:
    ->  hotmail.com
        ttl = 0 (0 secs)
    ADDITIONAL RECORDS:
    ->  mx1.norelay.link.net
        ttl = 0 (0 secs)
hotmail.com
        ttl = 0 (0 secs)
        ttl = 0 (0 secs)
mikedibella
Post by mikedibella » 2019-08-22 20:49
You are executing
the correct command is
Note the period "." at the end.
Hassan84
Post by Hassan84 » 2019-08-22 21:08
I did it , and same answer Server Failed.
C:\Windows\system32>nslookup -norecurse -debug -type=mx hotmail.com.
Got answer:
    HEADER:
    QUESTIONS:
    ANSWERS:
        name = DC-1.***********.com
Server:  DC-1.***********.com
Got answer:
    HEADER:
        opcode = QUERY, id = 2, rcode = SERVFAIL
    QUESTIONS:
*** DC-1.***********.com can't find hotmail.com.: Server failed
mikedibella
Post by mikedibella » 2019-08-22 22:22
now run
nslookup -debug -type=mx hotmail.com.
and compare the result
Hassan84
Post by Hassan84 » 2019-08-22 22:28
C:\Windows\system32>nslookup -debug -type=mx hotmail.com.
Got answer:
    HEADER:
    QUESTIONS:
    ANSWERS:
Got answer:
    HEADER:
        opcode = QUERY, id = 2, rcode = NOERROR
    QUESTIONS:
    ANSWERS:
    ->  hotmail.com
        ttl = 0 (0 secs)
    ADDITIONAL RECORDS:
        ttl = 0 (0 secs)
hotmail.com
        ttl = 0 (0 secs)
        ttl = 0 (0 secs)
mikedibella
Post by mikedibella » 2019-08-22 22:32
I think your DNS is misconfigured but I'm not sure where. Here a couple of things to check:
1. If you are using multiple DNS servers in the local TCP/IP stack configuration, they all have to be replicas of the same set of zones. You can't use your local server as the first DNS entry and your ISP as the second. This just the way the DNS client works.
2. If you have a Forwarder configured in the local DNS server point to your ISP's DNS server, I'd try removing it or changing to Goggle's DNS (8.8.8.8 and 8.8.4.4) instead.
