Change Header details for Sent emails only
mrbtamp2018
Post by mrbtamp2018 » 2019-08-06 06:28
Hmailserver is configured with a domain 'domain' having a account 'X.domain', which receives mails from external pop3 account and sends mail through through SMTP route configured with same external account.
This account 'X.domain' has 4 aliases A.domain,B.domain,C.domain,D.domain.
Outlook is configured with alias account names with main email address as 'X.domain'.
Now, when sending emails, the recipients receive the alias names in their message headers i.e FROM, REPLY-TO, RETURN-PATH.
If the recipient tries to reply to these mails, it would be delivered to alias accounts which does not exist.
So I tried to modify the message header under 'OnDeliverMessage' eventhandler vbscript.
Following is the code
oMessage.HeaderValue("From") = "X.domain"
oMessage.HeaderValue("FromAddress") = "X.domain"
oMessage.HeaderValue("Reply-To") = "X.domain"
oMessage.HeaderValue("Return-Path") = "X.domain"
oMessage.save()
Result.Value=0
But this changes headers for all the messages, received as well as sent.
What modification to the above code is needed to restrict the header changes to sent messages only Or is there any better way to handle this situation.
Kindly Suggest
Re: Change Header details for Sent emails only
Post by katip » 2019-08-06 10:58
assuming your senders do authenticate to send emails, you can distinguish local outbound messages from external incoming with for example:
If oClient.Username <> "" Then... (i.e. this is from a local user)
alternatively, you can try global rules (Criteria : From contains xyz, Action -> Set Header value)
HTH
hmailer24
Post by hmailer24 » 2019-08-08 19:12
i want to achieve similar thing, emails that are sent via my server (via authorized/whitelisted) hosts (my webservers) and change the from/to address.
The reason is that my docker containers are not configured FQDNs and this results in from/to addresses like application@5der3sdf5 (there is no domain ending).
I have configured rules already, but it seems they are not applied. Are rules applied when there is direct SMTP sending via the server?
Post by mattg » 2019-08-09 05:16
hmailer24 wrote:
2019-08-08 19:12
I see an easy fix there
hmailer24 wrote:
2019-08-08 19:12
Please enable all logging in hmailserver, and send a message, then after 30 seconds show all logs created
hmailer24 wrote:
2019-08-08 19:12
Er... what other kind of sending is there?
hMailserver accepts SMTP connections, and messages received this way should have rules applied
Perhaps I don't understand your question
