I'm not getting to send e-mail
sdiogos
Post by sdiogos » 2019-07-29 18:05
I did all configurations abou hmailserver and I get to receive e-mails but I'm not getting to send email, what is my issue?
Re: I'm not getting to send e-mail
Post by palinka » 2019-07-29 18:53
A few details about your configuration would be helpful. Logs too.
sdiogos
Post by sdiogos » 2019-07-29 19:05
ok, I'm attachment and the log I'm put here:
"APPLICATION"	3212	"2019-07-29 14:00:12.235"	"Stopping servers..."
"APPLICATION"	3212	"2019-07-29 14:00:12.235"	"Servers stopped."
"APPLICATION"	3212	"2019-07-29 14:00:12.938"	"Starting servers..."
"APPLICATION"	3212	"2019-07-29 14:00:12.938"	"Servers started."
"SMTPD"	7460	327	"2019-07-29 14:00:24.630"	"172.16.30.3"	"SENT: 220 Bem vindo ao servidor de e-mail"
"SMTPD"	6444	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"RECEIVED: EHLO [172.16.30.3]"
"SMTPD"	6444	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"SENT: 250-172.16.30.3[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	3300	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"RECEIVED: AUTH LOGIN"
"SMTPD"	3300	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	7460	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"RECEIVED: Y29udGF0bw=="
"SMTPD"	7460	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	6444	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"RECEIVED: ***"
"SMTPD"	6444	327	"2019-07-29 14:00:24.662"	"172.16.30.3"	"SENT: 235 authenticated."
"SMTPD"	3300	327	"2019-07-29 14:00:24.677"	"172.16.30.3"	"RECEIVED: MAIL FROM:<contato@verostore.com.br> SIZE=439"
"SMTPD"	3300	327	"2019-07-29 14:00:24.677"	"172.16.30.3"	"SENT: 250 OK"
"SMTPD"	5400	327	"2019-07-29 14:00:24.677"	"172.16.30.3"	"RECEIVED: RCPT TO:<contato.diogo.soares@gmail.com>"
"SMTPD"	5400	327	"2019-07-29 14:00:24.677"	"172.16.30.3"	"SENT: 250 OK"
"SMTPD"	5400	327	"2019-07-29 14:00:24.677"	"172.16.30.3"	"RECEIVED: DATA"
"SMTPD"	5400	327	"2019-07-29 14:00:24.677"	"172.16.30.3"	"SENT: 354 OK, send."
"SMTPD"	9924	327	"2019-07-29 14:00:24.693"	"172.16.30.3"	"SENT: 250 Queued (0.000 seconds)"
"SMTPD"	5400	327	"2019-07-29 14:00:24.693"	"172.16.30.3"	"RECEIVED: QUIT"
"SMTPD"	5400	327	"2019-07-29 14:00:24.693"	"172.16.30.3"	"SENT: 221 goodbye"
"APPLICATION"	7604	"2019-07-29 14:00:24.693"	"SMTPDeliverer - Message 58: Delivering message from contato@verostore.com.br to contato.diogo.soares@gmail.com. File: C:\Program Files (x86)\hMailServer\Data\{6B80C248-18A8-41AE-821C-CE9EBFBD646D}.eml"
"APPLICATION"	7604	"2019-07-29 14:00:24.693"	"SMTPDeliverer - Message 58: Relaying to host mail.verostore.com.br."
"APPLICATION"	7604	"2019-07-29 14:00:24.693"	"SMTPDeliverer - Message 58: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"APPLICATION"	7604	"2019-07-29 14:00:24.693"	"SMTPDeliverer - Message 58: Message delivery thread completed."
"IMAPD"	7460	326	"2019-07-29 14:00:24.708"	"172.16.30.3"	"SENT: * OK IMAPrev1"
"IMAPD"	6444	326	"2019-07-29 14:00:24.708"	"172.16.30.3"	"RECEIVED: 1 capability"
"IMAPD"	6444	326	"2019-07-29 14:00:24.708"	"172.16.30.3"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	7460	326	"2019-07-29 14:00:24.708"	"172.16.30.3"	"RECEIVED: 3 login "contato" ***"
"IMAPD"	7460	326	"2019-07-29 14:00:24.708"	"172.16.30.3"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3300	326	"2019-07-29 14:00:24.708"	"172.16.30.3"	"RECEIVED: 4 append "Sent" (\Seen) {439}"
"IMAPD"	3300	326	"2019-07-29 14:00:24.708"	"172.16.30.3"	"SENT: + Ready for literal data"
"IMAPD"	7460	326	"2019-07-29 14:00:24.724"	"172.16.30.3"	"SENT: 4 OK APPEND completed"
sdiogos
Post by sdiogos » 2019-07-29 19:06
other prints
Post by palinka » 2019-07-29 20:16
OK, now we're getting somewhere. First of all, run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914
However, it appears to have failed at your transmission to your relay.
And it looks like you're relaying to yourself.
Do you have another mail server running on 172.16.30.3? I don't think so or you would not have said you were able to receive mail. Therefore, you simply need to delete the relay, or relay to an outside service. Is port 25 outgoing open for you?
sdiogos
Post by sdiogos » 2019-07-29 20:24
Yes I can receive emails and I also have the port 25 open external.
I'll run the diagnostics
sdiogos
Post by sdiogos » 2019-07-29 21:55
I runned the diagnostics
[code]2019-07-29   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - fixxxxxxx.com.br               Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - vexxxxxxx.com.br               Enabled: True
        Greylisting:     False
IP RANGES
     External To External -  True              External To External - False
     External To Local    -  True           !! External To Local    -  True !!
       !! EXTERNAL INBOUND ON SUB IP RANGES OR EXTERNAL DOWNLOADS ONLY !!
IP: 172.16.30.3 - 172.16.30.3     Priority: 10     Name: verostore
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain2.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                      EXTERNAL.TLD             Disc. on invalid:  False  Delivered-To hdr: False
                    (Points to HOST file entry)
                     Port:  25                                           Loop limit:           5
                     Req Auth: False                                     Recipient hosts:     15
                     Con. Sec.: None
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-07-29.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-07-29.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\Backup_Emails is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v1.96, Hmailserver Forum.
[/code]
Post by palinka » 2019-07-29 22:26
1) Delete the relay. We know from earlier that you're relaying to yourself.
2) Delete the IP range 172.16.30.3 - 172.16.30.3. This is your IP.
3) Change your hostname to a FQDN (in earlier post, log showed [172.16.30.3]). That will get you firewall banned on my server and I don't care what the RFC has to say about it - all HELO banners with an IP are spambots.
4) Disable External-to-external on all IP ranges unless you have a genuine need. That attracts spammers.
5) disable authentication on external-to-local on the internet IP range or you won't receive any mail from the outside world.
6) delete default domain in SMTP settings unless you have a genuine need.
That should get you going.
sdiogos
Post by sdiogos » 2019-07-31 21:29
I made the corrections mentioned above, but still still getting the ip on Helo could someone tell me why?
Post by palinka » 2019-07-31 22:10
Are you able to send and receive mail?
sdiogos
Post by sdiogos » 2019-07-31 22:13
Nops, I'm just receive, but I need to send
Post by mattg » 2019-08-01 00:29
2019-07-29 20:16
Do this again, so that we can see what your current config looks like please
Post by palinka » 2019-08-01 00:33
He's blacklisted on spamhaus.
Send an email, wait a minute then post the log here.
sdiogos
Post by sdiogos » 2019-08-01 14:09
Yes, it is blacklist.
Look on picture.
sdiogos
Post by sdiogos » 2019-08-01 14:23
This is my current diagnostics
[code]2019-08-01   Hmailserver: 5.6.7-B2425
DOMAINS
        Greylisting:     False
        Greylisting:     False
IP RANGES
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-08-01.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-08-01.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
[/code]
Post by palinka » 2019-08-01 16:38
2019-08-01 00:33
sdiogos
Post by sdiogos » 2019-08-01 17:24
Now I not received nothing, it's been over 10 minutes
I tried send email from external to internal but I also not received.
Post by palinka » 2019-08-02 02:15
2019-08-01 16:38
2019-08-01 00:33
Post by mattg » 2019-08-02 02:38
ALSO (In addition to showing logs for SENDING an email)
on the IP ranges page there is a 'default' button - press that
You have a default domain set. Do you know why?
If you don't know why, then remove that please.
sdiogos
Post by sdiogos » 2019-08-02 15:29
I caught the following log using the wireshark
EHLO [172.16.30.3]
250-mail.verostore.com.br
250-SIZE 20480000
250-AUTH LOGIN
250 HELP
AUTH LOGIN
334 VXNlcm5hbWU6
Y29udGF0bw==
334 UGFzc3dvcmQ6
M2lhMDEj
235 authenticated.
MAIL FROM:<contato@verostore.com.br> SIZE=427
250 OK
RCPT TO:<diogo@3ia.com.br>
250 OK
DATA
354 OK, send.
To: diogo@3ia.com.br
Subject: teste2
Message-ID: <9489e2f0-adf3-5870-5e4c-0563de864a5b@verostore.com.br>
Date: Fri, 2 Aug 2019 10:25:56 -0300
User-Agent: Mozilla/5.0 (Windows NT 6.3; WOW64; rv:60.0) Gecko/20100101
 Thunderbird/60.8.0
MIME-Version: 1.0
Content-Type: text/plain; charset=utf-8; format=flowed
Content-Language: pt-BR
teste2
QUIT
221 goodbye
And after to send the email I get take this return of email
   Sent: Fri, 2 Aug 2019 10:25:56 -0300
   Subject: teste2
diogo@3ia.com.br
   Error Type: SMTP
   Remote server (162.220.60.234) issued an error.
   hMailServer sent: RCPT TO:<diogo@3ia.com.br>
   Remote server replied: 550-"JunkMail rejected - (mail.verostore.com.br) [45.7.171.88]:50186 is in an
550 RBL: http://www.barracudanetworks.com/reputation/?pr=1&ip=45.7.171.88"
Post by palinka » 2019-08-02 15:41
sdiogos wrote:
2019-08-02 15:29
   Subject: teste2
diogo@3ia.com.br
   Error Type: SMTP
Confirmed you are able to send mail. It's being rejected because you are on several blacklists.
You are either policy blocked - meaning your ISP has reported your IP (within a block of IPs) as being a residential account or dynamic IP, meaning an IP that should never be sending mail.
Or, you have been sending spam.
If the former, there's nothing you can do except relay through a reputable relay. If the latter, you can fix it by not sending spam then by going to the blacklists and attempting to delist yourself, which is intentionally hard. If you were blacklisted for sending spam, usually (after stopping and preventing future spam) you will automatically be removed after some time, which is different for every blacklist.
sdiogos
Post by sdiogos » 2019-08-02 15:50
I'm not send spam, I'm simply configurating my email service, now I don't know what to do.
Post by palinka » 2019-08-02 16:00
Says here you're a spammer. NOT policy blocked:
https://www.abuseat.org/lookup.cgi?ip=45.7.171.88
RESULTS OF LOOKUP
45.7.171.88 is listed
This IP address was detected and listed 7 times in the past 28 days, and 1 times in the past 24 hours. The most recent detection was at Fri Aug 2 12:35:00 2019 UTC +/- 5 minutes
This IP is infected (or NATting for a computer that is infected) with an infection that is emitting spam.
45.7.171.88 was using the following name to identify itself during email (port 25) connections via the SMTP HELO/EHLO commands as "45.7.171.88".
This is USUALLY spamware, but in some rare circumstances, it can be a misconfiguration in your mail server. The CBL attempts to distinguish real mail server software from malware SMTP clients by expecting users to name their mail server[s] to indicate who _they_ are, not their provider, not the destination server, and be consistent with Internet protocol standards.
Use of a bare IP address in the HELO is a violation of RFC2821 section 4.1.1.1, which says that the HELO value MUST be either a fully qualified domain name (such as "mail01.example.com") or an IP address enclosed in square brackets (such as "[45.7.171.88]").
You will need to investigate and fix this.
Norton Power Eraser is a free tool and doesn't require installation. It just needs to be downloaded and run. One of our team has tested the tool with Zeus, Ice-X, Citadel, ZeroAccess and Cutwail. It was able to detect and clean up the system in each case. It probably works with many other infections.
If Microsoft Windows Defender is available to you, use it!
Is this IP address a NAT gateway/firewall/router? In other words, is this IP address shared with other computers? See NAT for further information about NATs and how to secure them.
If this IP address is shared with other computers, only the administrator of this IP address can prevent this happening again by following the instructions in NAT to secure the NAT against future infections. In this way, no matter how badly infected the network behind the NAT is, the network can't spam the Internet. The administrator can also refer to Advanced BOT detection for hints and tips on how to find the infected computer behind a NAT.
HOW IS THIS LISTING AFFECTING YOU?
The CBL is primarily intended to be used by mail servers to block inbound undesirable email containing spam or malware that was emitted by a computer virus or some other infection. CBL listings can affect users in a variety of ways beyond this. It is recommended that people unfamiliar with the CBL (or Spamhaus XBL) and/or are unsure of what is happening consult this link.
If this listing is of an unshared IP address, and the affected access is email, then, the computer corresponding to this IP address at time of detection (see above) is infected with a spambot, or, if it's a mail server, in some rare cases this can be a severe misconfiguration or bug.
The first step is to run at least one (preferably more) reputable anti-spam/spyware tools on your computer. If you're lucky, one of them will find and remove the infection.
If you are unable to find it using anti-virus tools, you may want to take a close look at the discussions of netstat or tcpview in the "Per-machine methods" section of Finding BOTs in a LAN.
If the above does not help, you may have to resort to taking your computer to a computer dealer/service company and have them clean it.
If all else fails, you may need to have your machine's software re-installed from scratch.
