Test local connect problem
Vinnie1000
Post by Vinnie1000 » 2019-07-13 12:32
I’m a new with hmailserer. I try to make my own e-mailserver with domain fam-asseler.nl. I tried several settings but the local test fails every time. Port 25 is checked and open. I seam not to understand watt I doing wrong. Maybe someone can give me a clue. I’m completely a
beginner with servers.
Here are the test results. Thanks for all the help.
Test: Collect server details
Database type: MSSQL Compact
Test: Test IPv6
Test: Test outbound port
SMTP relayer is in use.
Trying to connect to host mail.fam-asseler.nl...
Trying to connect to TCP/IP address 185.87.187.219 on port 587.
Received: 220-www69.totaalholding.nl ESMTP Exim 4.92 #2 Sat, 13 Jul 2019 12:24:21 +0200 .
Connected successfully.
Test: Test backup directory
Backup directory D:\Backup\Mailserver is writable.
Test: Test MX records
Trying to resolve MX records for fam-asseler.nl...
Host name found: mail.fam-asseler.nl
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain fam-asseler.nl...
Trying to connect to TCP/IP address 185.87.187.219 on port 25.
Received: 421 Cannot connect to SMTP server 185.87.187.219 (185.87.187.219:25), connect error 10060.
Re: Test local connect problem
Post by mattg » 2019-07-14 02:11
That's normally not a fatal error
It is often caused by your router/modem not doing loopback.
Send a message to your gmail / hotmail account and then reply to see if it works.
Vinnie1000
Post by Vinnie1000 » 2019-07-14 10:07
Hi mattg,
Thanks for your reply.
I tried to sent a mail. Log file shows;
(185.87.187.219), Port: 587, Security: 1, User name: vasseler@fam-asseler.nl"
"IMAPD" 11456 10 "2019-07-14 10:00:40.346" "192.168.0.8" "SENT: )"
"DEBUG" 11372 "2019-07-14 10:00:40.347" "Creating session 16"
"IMAPD" 11456 10 "2019-07-14 10:00:40.347" "192.168.0.8" "SENT: A15 OK UID completed"
"TCPIP" 11372 "2019-07-14 10:00:40.348" "Connecting to 185.87.187.219:587..."
"DEBUG" 11460 "2019-07-14 10:00:43.352" "TCP connection started for session 16"
"DEBUG" 11460 "2019-07-14 10:00:43.353" "Performing SSL/TLS handshake for session 16. Verify certificate: True, Expected remote host name: mail.fam-asseler.nl"
"TCPIP" 11452 "2019-07-14 10:00:43.380" "TCPConnection - TLS/SSL handshake failed. Session Id: 16, Remote IP: 185.87.187.219, Error code: 10054, Message: De externe host heeft een verbinding verbroken"
"DEBUG" 11452 "2019-07-14 10:00:43.380" "Ending session 16"
"DEBUG" 11372 "2019-07-14 10:00:43.381" "External delivery process completed"
"DEBUG" 11372 "2019-07-14 10:00:43.381" "Summarizing delivery result"
"DEBUG" 11372 "2019-07-14 10:00:43.382" "Summarized delivery results"
"DEBUG" 11372 "2019-07-14 10:00:43.382" "SD::RescheduleDelivery_"
"DEBUG" 11372 "2019-07-14 10:00:43.382" "Retrieving retry options."
"DEBUG" 11372 "2019-07-14 10:00:43.383" "Starting rescheduling."
"APPLICATION" 11372 "2019-07-14 10:00:43.383" "SMTPDeliverer - Message 27: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG" 11372 "2019-07-14 10:00:43.384" "PersistentMessage::SetNextTryTime()"
"DEBUG" 11372 "2019-07-14 10:00:43.385" "PersistentMessage::~SetNextTryTime()"
"DEBUG" 11372 "2019-07-14 10:00:43.386" "Message rescheduled for later delivery."
"APPLICATION" 11372 "2019-07-14 10:00:43.386" "SMTPDeliverer - Message 27: Message delivery thread completed."
"IMAPD" 11452 3 "2019-07-14 10:00:48.458" "192.168.0.8" "RECEIVED: DONE"
"IMAPD" 11452 3 "2019-07-14 10:00:48.459" "192.168.0.8" "SENT: A36 OK IDLE terminated"
"IMAPD" 11460 3 "2019-07-14 10:00:48.459" "192.168.0.8" "RECEIVED: A37 LIST "" "%""
"IMAPD" 11460 3 "2019-07-14 10:00:48.460" "192.168.0.8" "SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]* LIST (\HasNoChildren) "." "Trash"[nl]* LIST (\HasNoChildren) "." "Sent"[nl]A37 OK LIST completed"
"IMAPD" 11456 3 "2019-07-14 10:00:48.461" "192.168.0.8" "RECEIVED: A38 STATUS "INBOX" (UNSEEN)"
"IMAPD" 11456 3 "2019-07-14 10:00:48.461" "192.168.0.8" "SENT: * STATUS "INBOX" (UNSEEN 0)[nl]A38 OK Status completed"
"IMAPD" 11460 3 "2019-07-14 10:00:48.462" "192.168.0.8" "RECEIVED: A39 STATUS "Trash" (UNSEEN)"
"IMAPD" 11460 3 "2019-07-14 10:00:48.462" "192.168.0.8" "SENT: * STATUS "Trash" (UNSEEN 0)[nl]A39 OK Status completed"
"IMAPD" 11452 3 "2019-07-14 10:00:48.463" "192.168.0.8" "RECEIVED: A40 STATUS "Sent" (UNSEEN)"
"IMAPD" 11452 3 "2019-07-14 10:00:48.463" "192.168.0.8" "SENT: * STATUS "Sent" (UNSEEN 0)[nl]A40 OK Status completed"
"IMAPD" 11456 3 "2019-07-14 10:00:48.477" "192.168.0.8" "RECEIVED: A41 NOOP"
"IMAPD" 11456 3 "2019-07-14 10:00:48.477" "192.168.0.8" "SENT: A41 OK NOOP completed"
"IMAPD" 11460 3 "2019-07-14 10:00:51.479" "192.168.0.8" "RECEIVED: A42 IDLE"
"IMAPD" 11460 3 "2019-07-14 10:00:51.479" "192.168.0.8" "SENT: + idling"
Seams that the relay is not working wel. Any sugestions?
Local email was received annd processed by hmail, therfore hmail itself is working I think.
Cheers.
Post by mattg » 2019-07-14 11:13
There is no SMTPC logs in that, there was no SMTP connection
That's how mail is 'sent'
Clear you logs, try again, and show the entire log created after 90 seconds
Vinnie1000
Post by Vinnie1000 » 2019-07-14 12:40
I hope this gives a beter view. Here is a new complete log file;
"DEBUG" 11452 "2019-07-14 12:34:32.175" "Creating session 27"
"TCPIP" 11452 "2019-07-14 12:34:32.176" "TCP - 192.168.0.8 connected to 192.168.0.8:143."
"DEBUG" 11452 "2019-07-14 12:34:32.177" "TCP connection started for session 26"
"IMAPD" 11452 26 "2019-07-14 12:34:32.178" "192.168.0.8" "SENT: * OK IMAPrev1"
"IMAPD" 11460 26 "2019-07-14 12:34:32.178" "192.168.0.8" "RECEIVED: A0 CAPABILITY"
"IMAPD" 11460 26 "2019-07-14 12:34:32.179" "192.168.0.8" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]A0 OK CAPABILITY completed"
"IMAPD" 11456 26 "2019-07-14 12:34:32.180" "192.168.0.8" "RECEIVED: A1 LOGIN "vinnie@fam-asseler.nl" ***"
"IMAPD" 11456 26 "2019-07-14 12:34:32.197" "192.168.0.8" "SENT: A1 OK LOGIN completed"
"IMAPD" 11456 26 "2019-07-14 12:34:32.198" "192.168.0.8" "RECEIVED: A2 NAMESPACE"
"IMAPD" 11456 26 "2019-07-14 12:34:32.198" "192.168.0.8" "SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]A2 OK namespace command complete"
"IMAPD" 11460 26 "2019-07-14 12:34:32.200" "192.168.0.8" "RECEIVED: A3 LIST "" "%""
"IMAPD" 11460 26 "2019-07-14 12:34:32.200" "192.168.0.8" "SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]* LIST (\HasNoChildren) "." "Trash"[nl]* LIST (\HasNoChildren) "." "Sent"[nl]A3 OK LIST completed"
"IMAPD" 11452 26 "2019-07-14 12:34:32.202" "192.168.0.8" "RECEIVED: A4 SELECT "INBOX""
"IMAPD" 11452 26 "2019-07-14 12:34:32.203" "192.168.0.8" "SENT: * 0 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1560256744] current uidvalidity[nl]* OK [UIDNEXT 8] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]A4 OK [READ-WRITE] SELECT completed"
"IMAPD" 11448 26 "2019-07-14 12:34:32.204" "192.168.0.8" "RECEIVED: A5 STATUS "INBOX" (UNSEEN)"
"IMAPD" 11448 26 "2019-07-14 12:34:32.204" "192.168.0.8" "SENT: * STATUS "INBOX" (UNSEEN 0)[nl]A5 OK Status completed"
"IMAPD" 11452 26 "2019-07-14 12:34:32.205" "192.168.0.8" "RECEIVED: A6 STATUS "Trash" (UNSEEN)"
"IMAPD" 11452 26 "2019-07-14 12:34:32.205" "192.168.0.8" "SENT: * STATUS "Trash" (UNSEEN 0)[nl]A6 OK Status completed"
"IMAPD" 11460 26 "2019-07-14 12:34:32.206" "192.168.0.8" "RECEIVED: A7 STATUS "Sent" (UNSEEN)"
"IMAPD" 11460 26 "2019-07-14 12:34:32.206" "192.168.0.8" "SENT: * STATUS "Sent" (UNSEEN 0)[nl]A7 OK Status completed"
"IMAPD" 11448 26 "2019-07-14 12:34:35.231" "192.168.0.8" "RECEIVED: A8 IDLE"
"IMAPD" 11448 26 "2019-07-14 12:34:35.231" "192.168.0.8" "SENT: + idling"
"IMAPD" 11460 26 "2019-07-14 12:34:50.897" "192.168.0.8" "RECEIVED: DONE"
"IMAPD" 11460 26 "2019-07-14 12:34:50.898" "192.168.0.8" "SENT: A8 OK IDLE terminated"
"IMAPD" 11452 26 "2019-07-14 12:34:50.898" "192.168.0.8" "RECEIVED: A9 IDLE"
"IMAPD" 11452 26 "2019-07-14 12:34:50.899" "192.168.0.8" "SENT: + idling"
"DEBUG" 11460 "2019-07-14 12:35:08.164" "Creating session 28"
"TCPIP" 11460 "2019-07-14 12:35:08.165" "TCP - 192.168.0.8 connected to 192.168.0.8:25."
"DEBUG" 11460 "2019-07-14 12:35:08.166" "TCP connection started for session 15"
"SMTPD" 11460 15 "2019-07-14 12:35:08.167" "192.168.0.8" "SENT: 220 mail.fam-asseler.nl ESMTP"
"SMTPD" 11448 15 "2019-07-14 12:35:08.167" "192.168.0.8" "RECEIVED: EHLO [192.168.0.8]"
"SMTPD" 11448 15 "2019-07-14 12:35:08.168" "192.168.0.8" "SENT: 250-mail.fam-asseler.nl[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 11452 15 "2019-07-14 12:35:08.170" "192.168.0.8" "RECEIVED: AUTH PLAIN AHZpbm5pZUBmYW0tYXNzZWxlci5ubAB0ZXN0MTAw"
"SMTPD" 11452 15 "2019-07-14 12:35:08.171" "192.168.0.8" "SENT: 235 authenticated."
"SMTPD" 11452 15 "2019-07-14 12:35:08.172" "192.168.0.8" "RECEIVED: MAIL FROM:<vinnie@fam-asseler.nl> SIZE=1136"
"SMTPD" 11452 15 "2019-07-14 12:35:08.173" "192.168.0.8" "SENT: 250 OK"
"SMTPD" 11460 15 "2019-07-14 12:35:08.174" "192.168.0.8" "RECEIVED: RCPT TO:<vasseler@ziggo.nl>"
"SMTPD" 11460 15 "2019-07-14 12:35:08.176" "192.168.0.8" "SENT: 250 OK"
"SMTPD" 11452 15 "2019-07-14 12:35:08.177" "192.168.0.8" "RECEIVED: DATA"
"SMTPD" 11452 15 "2019-07-14 12:35:08.178" "192.168.0.8" "SENT: 354 OK, send."
"DEBUG" 11452 "2019-07-14 12:35:09.195" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 10820 "2019-07-14 12:35:09.195" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 10820 "2019-07-14 12:35:09.196" "Saving message: {81F5873A-95DC-4097-A1F3-FCA8867CCE31}.eml"
"DEBUG" 10820 "2019-07-14 12:35:09.198" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 10820 15 "2019-07-14 12:35:09.198" "192.168.0.8" "SENT: 250 Queued (1.031 seconds)"
"SMTPD" 11460 15 "2019-07-14 12:35:09.199" "192.168.0.8" "RECEIVED: QUIT"
"DEBUG" 11320 "2019-07-14 12:35:09.200" "Adding task DeliveryTask to work queue SMTP delivery queue"
"SMTPD" 11460 15 "2019-07-14 12:35:09.200" "192.168.0.8" "SENT: 221 goodbye"
"DEBUG" 11372 "2019-07-14 12:35:09.200" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 11452 "2019-07-14 12:35:09.201" "Ending session 15"
"DEBUG" 11372 "2019-07-14 12:35:09.201" "Delivering message..."
"APPLICATION" 11372 "2019-07-14 12:35:09.204" "SMTPDeliverer - Message 29: Delivering message from vinnie@fam-asseler.nl to vasseler@ziggo.nl. File: C:\Program Files (x86)\hMailServer\Data\{81F5873A-95DC-4097-A1F3-FCA8867CCE31}.eml"
"DEBUG" 11372 "2019-07-14 12:35:09.205" "Applying rules"
"DEBUG" 11372 "2019-07-14 12:35:09.205" "Performing local delivery"
"DEBUG" 11372 "2019-07-14 12:35:09.205" "Local delivery completed"
"DEBUG" 11452 "2019-07-14 12:35:09.210" "Creating session 29"
"TCPIP" 11452 "2019-07-14 12:35:09.210" "TCP - 192.168.0.8 connected to 192.168.0.8:143."
"DEBUG" 11452 "2019-07-14 12:35:09.212" "TCP connection started for session 27"
"IMAPD" 11452 27 "2019-07-14 12:35:09.212" "192.168.0.8" "SENT: * OK IMAPrev1"
"IMAPD" 11448 27 "2019-07-14 12:35:09.213" "192.168.0.8" "RECEIVED: A0 CAPABILITY"
"IMAPD" 11448 27 "2019-07-14 12:35:09.213" "192.168.0.8" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]A0 OK CAPABILITY completed"
"IMAPD" 11452 27 "2019-07-14 12:35:09.214" "192.168.0.8" "RECEIVED: A1 LOGIN "vinnie@fam-asseler.nl" ***"
"IMAPD" 11452 27 "2019-07-14 12:35:09.215" "192.168.0.8" "SENT: A1 OK LOGIN completed"
"IMAPD" 11448 27 "2019-07-14 12:35:09.217" "192.168.0.8" "RECEIVED: A2 APPEND "Sent" (\Seen) "14-Jul-2019 10:35:08 +0000" {1347}"
"IMAPD" 11448 27 "2019-07-14 12:35:09.217" "192.168.0.8" "SENT: + Ready for literal data"
"DEBUG" 11452 "2019-07-14 12:35:09.219" "Saving message: {176BE171-8D85-4190-8CE7-92EEED0FDA52}.eml"
"IMAPD" 11452 27 "2019-07-14 12:35:09.221" "192.168.0.8" "SENT: A2 OK APPEND completed"
"IMAPD" 11452 27 "2019-07-14 12:35:09.222" "192.168.0.8" "RECEIVED: A3 SELECT "Sent""
"DEBUG" 11452 "2019-07-14 12:35:09.223" "Reading messages from database."
"APPLICATION" 11372 "2019-07-14 12:35:09.224" "SMTPDeliverer - Message 29: Relaying to host mail.fam-asseler.nl."
"IMAPD" 11452 27 "2019-07-14 12:35:09.224" "192.168.0.8" "SENT: * 4 EXISTS[nl]* 1 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1560259084] current uidvalidity[nl]* OK [UIDNEXT 8] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]A3 OK [READ-WRITE] SELECT completed"
"DEBUG" 11372 "2019-07-14 12:35:09.224" "Starting external delivery process. Server: mail.fam-asseler.nl (185.87.187.219), Port: 587, Security: 1, User name: vasseler@fam-asseler.nl"
"IMAPD" 11448 27 "2019-07-14 12:35:09.225" "192.168.0.8" "RECEIVED: A4 UID SEARCH HEADER "Message-Id" "<em10d4c058-1ed3-4566-a51e-3009e2afb5fa@vincent>""
"DEBUG" 11372 "2019-07-14 12:35:09.225" "Creating session 30"
"TCPIP" 11372 "2019-07-14 12:35:09.226" "Connecting to 185.87.187.219:587..."
"DEBUG" 11452 "2019-07-14 12:35:09.228" "TCP connection started for session 30"
"DEBUG" 11452 "2019-07-14 12:35:09.228" "Performing SSL/TLS handshake for session 30. Verify certificate: True, Expected remote host name: mail.fam-asseler.nl"
"IMAPD" 11448 27 "2019-07-14 12:35:09.228" "192.168.0.8" "SENT: * SEARCH 7"
"IMAPD" 11448 27 "2019-07-14 12:35:09.229" "192.168.0.8" "SENT: A4 OK UID completed"
"TCPIP" 11452 "2019-07-14 12:35:09.256" "TCPConnection - TLS/SSL handshake failed. Session Id: 30, Remote IP: 185.87.187.219, Error code: 10054, Message: De externe host heeft een verbinding verbroken"
"DEBUG" 11452 "2019-07-14 12:35:09.256" "Ending session 30"
"DEBUG" 11372 "2019-07-14 12:35:09.257" "External delivery process completed"
"DEBUG" 11372 "2019-07-14 12:35:09.257" "Summarizing delivery result"
"DEBUG" 11372 "2019-07-14 12:35:09.257" "Summarized delivery results"
"DEBUG" 11372 "2019-07-14 12:35:09.258" "SD::RescheduleDelivery_"
"DEBUG" 11372 "2019-07-14 12:35:09.258" "Retrieving retry options."
"DEBUG" 11372 "2019-07-14 12:35:09.258" "Starting rescheduling."
"APPLICATION" 11372 "2019-07-14 12:35:09.259" "SMTPDeliverer - Message 29: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG" 11372 "2019-07-14 12:35:09.259" "PersistentMessage::SetNextTryTime()"
"DEBUG" 11372 "2019-07-14 12:35:09.260" "PersistentMessage::~SetNextTryTime()"
"DEBUG" 11372 "2019-07-14 12:35:09.261" "Message rescheduled for later delivery."
"APPLICATION" 11372 "2019-07-14 12:35:09.261" "SMTPDeliverer - Message 29: Message delivery thread completed."
"IMAPD" 11452 27 "2019-07-14 12:35:26.230" "192.168.0.8" "RECEIVED: A5 UID SEARCH UID 7:8"
"IMAPD" 11452 27 "2019-07-14 12:35:26.231" "192.168.0.8" "SENT: * SEARCH 7"
"IMAPD" 11452 27 "2019-07-14 12:35:26.231" "192.168.0.8" "SENT: A5 OK UID completed"
"IMAPD" 11460 27 "2019-07-14 12:35:26.232" "192.168.0.8" "RECEIVED: A6 UID FETCH 7 (UID RFC822.SIZE FLAGS INTERNALDATE BODYSTRUCTURE ENVELOPE BODY.PEEK[HEADER.FIELDS (importance x-priority references content-type)])"
"IMAPD" 11460 27 "2019-07-14 12:35:26.233" "192.168.0.8" "SENT: * 4 FETCH (UID 7 RFC822.SIZE 1349 FLAGS (\Seen) INTERNALDATE "14-Jul-2019 10:35:08 +0200" ENVELOPE ("Sun, 14 Jul 2019 10:35:08 +0000" "Test 5" (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vasseler@ziggo.nl" NIL "vasseler" "ziggo.nl")) NIL NIL NIL "<em10d4c058-1ed3-4566-a51e-3009e2afb5fa@vincent>") BODYSTRUCTURE (("TEXT" "PLAIN" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 1 1)("TEXT" "HTML" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 567 16) "ALTERNATIVE" ("BOUNDARY" "------=_MB992CD840-A15B-46C1-AE44-89AACF4CE68C") NIL NIL) BODY[HEADER.FIELDS (importance x-priority references content-type)] {98}"
"IMAPD" 11460 27 "2019-07-14 12:35:26.234" "192.168.0.8" "SENT: )"
"IMAPD" 11460 27 "2019-07-14 12:35:26.234" "192.168.0.8" "SENT: A6 OK UID completed"
"IMAPD" 11448 27 "2019-07-14 12:35:26.235" "192.168.0.8" "RECEIVED: A7 UID FETCH 1:7 (FLAGS)"
"IMAPD" 11448 27 "2019-07-14 12:35:26.236" "192.168.0.8" "SENT: * 1 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD" 11448 27 "2019-07-14 12:35:26.236" "192.168.0.8" "SENT: * 2 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD" 11448 27 "2019-07-14 12:35:26.237" "192.168.0.8" "SENT: * 3 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD" 11448 27 "2019-07-14 12:35:26.237" "192.168.0.8" "SENT: * 4 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD" 11448 27 "2019-07-14 12:35:26.238" "192.168.0.8" "SENT: A7 OK UID completed"
"IMAPD" 11460 27 "2019-07-14 12:35:28.641" "192.168.0.8" "RECEIVED: A8 UID COPY 6 "Trash""
"DEBUG" 11460 "2019-07-14 12:35:28.642" "Copying mail contents"
"DEBUG" 11460 "2019-07-14 12:35:28.644" "Saving message: {1E7952EC-642C-4710-834A-B97493065A86}.eml"
"IMAPD" 11460 27 "2019-07-14 12:35:28.646" "192.168.0.8" "SENT: A8 OK UID completed"
"DEBUG" 11452 "2019-07-14 12:35:28.652" "Creating session 31"
"TCPIP" 11452 "2019-07-14 12:35:28.653" "TCP - 192.168.0.8 connected to 192.168.0.8:143."
"DEBUG" 11452 "2019-07-14 12:35:28.654" "TCP connection started for session 29"
"IMAPD" 11452 29 "2019-07-14 12:35:28.654" "192.168.0.8" "SENT: * OK IMAPrev1"
"IMAPD" 11460 29 "2019-07-14 12:35:28.655" "192.168.0.8" "RECEIVED: A0 CAPABILITY"
"IMAPD" 11460 29 "2019-07-14 12:35:28.655" "192.168.0.8" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]A0 OK CAPABILITY completed"
"IMAPD" 11456 29 "2019-07-14 12:35:28.656" "192.168.0.8" "RECEIVED: A1 LOGIN "vinnie@fam-asseler.nl" ***"
"IMAPD" 11456 29 "2019-07-14 12:35:28.657" "192.168.0.8" "SENT: A1 OK LOGIN completed"
"IMAPD" 11460 29 "2019-07-14 12:35:28.658" "192.168.0.8" "RECEIVED: A2 SELECT "Trash""
"DEBUG" 11460 "2019-07-14 12:35:28.659" "Reading messages from database."
"IMAPD" 11460 29 "2019-07-14 12:35:28.659" "192.168.0.8" "SENT: * 1 EXISTS[nl]* 1 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1560258987] current uidvalidity[nl]* OK [UIDNEXT 12] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]A2 OK [READ-WRITE] SELECT completed"
"IMAPD" 11456 29 "2019-07-14 12:35:28.660" "192.168.0.8" "RECEIVED: A3 UID SEARCH HEADER "Message-Id" "<em94be0f48-5952-495f-b422-a7a71044612d@vincent>""
"IMAPD" 11456 29 "2019-07-14 12:35:28.661" "192.168.0.8" "SENT: * SEARCH 11"
"IMAPD" 11456 29 "2019-07-14 12:35:28.661" "192.168.0.8" "SENT: A3 OK UID completed"
"IMAPD" 11456 29 "2019-07-14 12:35:28.665" "192.168.0.8" "RECEIVED: A4 NOOP"
"IMAPD" 11456 29 "2019-07-14 12:35:28.666" "192.168.0.8" "SENT: A4 OK NOOP completed"
"DEBUG" 11460 "2019-07-14 12:35:28.667" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 29, Code: 2, Message: End of file"
"IMAPD" 11456 27 "2019-07-14 12:35:28.667" "192.168.0.8" "RECEIVED: A9 UID STORE 6 +FLAGS.SILENT (\Deleted)"
"DEBUG" 11460 "2019-07-14 12:35:28.668" "Ending session 29"
"IMAPD" 11456 27 "2019-07-14 12:35:28.669" "192.168.0.8" "SENT: A9 OK UID completed"
"IMAPD" 11460 27 "2019-07-14 12:35:28.670" "192.168.0.8" "RECEIVED: A10 UID SEARCH DELETED"
"IMAPD" 11460 27 "2019-07-14 12:35:28.671" "192.168.0.8" "SENT: * SEARCH 6"
"IMAPD" 11460 27 "2019-07-14 12:35:28.671" "192.168.0.8" "SENT: A10 OK UID completed"
"IMAPD" 11452 27 "2019-07-14 12:35:28.672" "192.168.0.8" "RECEIVED: A11 EXPUNGE"
"DEBUG" 11452 "2019-07-14 12:35:28.672" "Deleting message"
"DEBUG" 11452 "2019-07-14 12:35:28.673" "Deleting message file."
"IMAPD" 11452 27 "2019-07-14 12:35:28.674" "192.168.0.8" "SENT: * 3 EXPUNGE"
"IMAPD" 11452 27 "2019-07-14 12:35:28.674" "192.168.0.8" "SENT: A11 OK EXPUNGE Completed"
"IMAPD" 11460 27 "2019-07-14 12:35:29.439" "192.168.0.8" "RECEIVED: A12 UID COPY 5 "Trash""
"DEBUG" 11460 "2019-07-14 12:35:29.440" "Copying mail contents"
"DEBUG" 11460 "2019-07-14 12:35:29.442" "Saving message: {B4FD40B5-9971-4A47-9621-D14DD5258673}.eml"
"IMAPD" 11460 27 "2019-07-14 12:35:29.445" "192.168.0.8" "SENT: A12 OK UID completed"
"DEBUG" 11452 "2019-07-14 12:35:29.446" "Creating session 32"
"TCPIP" 11452 "2019-07-14 12:35:29.447" "TCP - 192.168.0.8 connected to 192.168.0.8:143."
"DEBUG" 11452 "2019-07-14 12:35:29.448" "TCP connection started for session 31"
"IMAPD" 11452 31 "2019-07-14 12:35:29.449" "192.168.0.8" "SENT: * OK IMAPrev1"
"IMAPD" 11460 31 "2019-07-14 12:35:29.450" "192.168.0.8" "RECEIVED: A0 CAPABILITY"
"IMAPD" 11460 31 "2019-07-14 12:35:29.450" "192.168.0.8" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]A0 OK CAPABILITY completed"
"IMAPD" 11460 31 "2019-07-14 12:35:29.451" "192.168.0.8" "RECEIVED: A1 LOGIN "vinnie@fam-asseler.nl" ***"
"IMAPD" 11460 31 "2019-07-14 12:35:29.452" "192.168.0.8" "SENT: A1 OK LOGIN completed"
"IMAPD" 11456 31 "2019-07-14 12:35:29.452" "192.168.0.8" "RECEIVED: A2 SELECT "Trash""
"DEBUG" 11456 "2019-07-14 12:35:29.453" "Reading messages from database."
"IMAPD" 11456 31 "2019-07-14 12:35:29.454" "192.168.0.8" "SENT: * 2 EXISTS[nl]* 1 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1560258987] current uidvalidity[nl]* OK [UIDNEXT 13] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]A2 OK [READ-WRITE] SELECT completed"
"IMAPD" 11456 31 "2019-07-14 12:35:29.455" "192.168.0.8" "RECEIVED: A3 UID SEARCH HEADER "Message-Id" "<em38db5e5e-6c19-4a9c-ad5f-c295688f1583@vincent>""
"IMAPD" 11456 31 "2019-07-14 12:35:29.455" "192.168.0.8" "SENT: * SEARCH 12"
"IMAPD" 11456 31 "2019-07-14 12:35:29.456" "192.168.0.8" "SENT: A3 OK UID completed"
"IMAPD" 11452 31 "2019-07-14 12:35:29.458" "192.168.0.8" "RECEIVED: A4 NOOP"
"IMAPD" 11452 31 "2019-07-14 12:35:29.459" "192.168.0.8" "SENT: A4 OK NOOP completed"
"DEBUG" 11456 "2019-07-14 12:35:29.460" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 31, Code: 2, Message: End of file"
"IMAPD" 11460 27 "2019-07-14 12:35:29.460" "192.168.0.8" "RECEIVED: A13 UID STORE 5 +FLAGS.SILENT (\Deleted)"
"DEBUG" 11456 "2019-07-14 12:35:29.460" "Ending session 31"
"IMAPD" 11460 27 "2019-07-14 12:35:29.461" "192.168.0.8" "SENT: A13 OK UID completed"
"IMAPD" 11452 27 "2019-07-14 12:35:29.462" "192.168.0.8" "RECEIVED: A14 UID SEARCH DELETED"
"IMAPD" 11452 27 "2019-07-14 12:35:29.463" "192.168.0.8" "SENT: * SEARCH 5"
"IMAPD" 11452 27 "2019-07-14 12:35:29.463" "192.168.0.8" "SENT: A14 OK UID completed"
"IMAPD" 11460 27 "2019-07-14 12:35:29.464" "192.168.0.8" "RECEIVED: A15 EXPUNGE"
"DEBUG" 11460 "2019-07-14 12:35:29.464" "Deleting message"
"DEBUG" 11460 "2019-07-14 12:35:29.465" "Deleting message file."
"IMAPD" 11460 27 "2019-07-14 12:35:29.466" "192.168.0.8" "SENT: * 2 EXPUNGE"
"IMAPD" 11460 27 "2019-07-14 12:35:29.466" "192.168.0.8" "SENT: A15 OK EXPUNGE Completed"
"IMAPD" 11452 27 "2019-07-14 12:35:30.016" "192.168.0.8" "RECEIVED: A16 UID COPY 4 "Trash""
"DEBUG" 11452 "2019-07-14 12:35:30.017" "Copying mail contents"
"DEBUG" 11452 "2019-07-14 12:35:30.019" "Saving message: {F993E6CD-6B3F-497E-A3D2-D8F764684028}.eml"
"IMAPD" 11452 27 "2019-07-14 12:35:30.021" "192.168.0.8" "SENT: A16 OK UID completed"
"DEBUG" 11452 "2019-07-14 12:35:30.023" "Creating session 33"
"TCPIP" 11452 "2019-07-14 12:35:30.023" "TCP - 192.168.0.8 connected to 192.168.0.8:143."
"DEBUG" 11452 "2019-07-14 12:35:30.024" "TCP connection started for session 32"
"IMAPD" 11452 32 "2019-07-14 12:35:30.025" "192.168.0.8" "SENT: * OK IMAPrev1"
"IMAPD" 11460 32 "2019-07-14 12:35:30.026" "192.168.0.8" "RECEIVED: A0 CAPABILITY"
"IMAPD" 11460 32 "2019-07-14 12:35:30.026" "192.168.0.8" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]A0 OK CAPABILITY completed"
"IMAPD" 11456 32 "2019-07-14 12:35:30.027" "192.168.0.8" "RECEIVED: A1 LOGIN "vinnie@fam-asseler.nl" ***"
"IMAPD" 11456 32 "2019-07-14 12:35:30.028" "192.168.0.8" "SENT: A1 OK LOGIN completed"
"IMAPD" 11460 32 "2019-07-14 12:35:30.028" "192.168.0.8" "RECEIVED: A2 SELECT "Trash""
"DEBUG" 11460 "2019-07-14 12:35:30.030" "Reading messages from database."
"IMAPD" 11460 32 "2019-07-14 12:35:30.030" "192.168.0.8" "SENT: * 3 EXISTS[nl]* 1 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1560258987] current uidvalidity[nl]* OK [UIDNEXT 14] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]A2 OK [READ-WRITE] SELECT completed"
"IMAPD" 11452 32 "2019-07-14 12:35:30.031" "192.168.0.8" "RECEIVED: A3 UID SEARCH HEADER "Message-Id" "<em3e13207d-4031-4c5d-94f8-1b093a454545@vincent>""
"IMAPD" 11452 32 "2019-07-14 12:35:30.032" "192.168.0.8" "SENT: * SEARCH 13"
"IMAPD" 11452 32 "2019-07-14 12:35:30.032" "192.168.0.8" "SENT: A3 OK UID completed"
"IMAPD" 11456 32 "2019-07-14 12:35:30.034" "192.168.0.8" "RECEIVED: A4 NOOP"
"IMAPD" 11456 32 "2019-07-14 12:35:30.035" "192.168.0.8" "SENT: A4 OK NOOP completed"
"DEBUG" 11452 "2019-07-14 12:35:30.036" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 32, Code: 2, Message: End of file"
"IMAPD" 11456 27 "2019-07-14 12:35:30.036" "192.168.0.8" "RECEIVED: A17 UID STORE 4 +FLAGS.SILENT (\Deleted)"
"DEBUG" 11452 "2019-07-14 12:35:30.037" "Ending session 32"
"IMAPD" 11456 27 "2019-07-14 12:35:30.038" "192.168.0.8" "SENT: A17 OK UID completed"
"IMAPD" 11452 27 "2019-07-14 12:35:30.039" "192.168.0.8" "RECEIVED: A18 UID SEARCH DELETED"
"IMAPD" 11452 27 "2019-07-14 12:35:30.039" "192.168.0.8" "SENT: * SEARCH 4"
"IMAPD" 11452 27 "2019-07-14 12:35:30.040" "192.168.0.8" "SENT: A18 OK UID completed"
"IMAPD" 11460 27 "2019-07-14 12:35:30.040" "192.168.0.8" "RECEIVED: A19 EXPUNGE"
"DEBUG" 11460 "2019-07-14 12:35:30.041" "Deleting message"
"DEBUG" 11460 "2019-07-14 12:35:30.044" "Deleting message file."
"IMAPD" 11460 27 "2019-07-14 12:35:30.045" "192.168.0.8" "SENT: * 1 EXPUNGE"
"IMAPD" 11460 27 "2019-07-14 12:35:30.045" "192.168.0.8" "SENT: A19 OK EXPUNGE Completed"
"IMAPD" 11456 27 "2019-07-14 12:35:33.047" "192.168.0.8" "RECEIVED: A20 IDLE"
"IMAPD" 11456 27 "2019-07-14 12:35:33.047" "192.168.0.8" "SENT: + idling"
"DEBUG" 11452 "2019-07-14 12:35:33.067" "Creating session 34"
"TCPIP" 11452 "2019-07-14 12:35:33.067" "TCP - 192.168.0.8 connected to 192.168.0.8:143."
"DEBUG" 11452 "2019-07-14 12:35:33.069" "TCP connection started for session 33"
"IMAPD" 11452 33 "2019-07-14 12:35:33.069" "192.168.0.8" "SENT: * OK IMAPrev1"
"IMAPD" 11456 33 "2019-07-14 12:35:33.070" "192.168.0.8" "RECEIVED: A0 CAPABILITY"
"IMAPD" 11456 33 "2019-07-14 12:35:33.070" "192.168.0.8" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]A0 OK CAPABILITY completed"
"IMAPD" 11456 33 "2019-07-14 12:35:33.071" "192.168.0.8" "RECEIVED: A1 LOGIN "vinnie@fam-asseler.nl" ***"
"IMAPD" 11456 33 "2019-07-14 12:35:33.073" "192.168.0.8" "SENT: A1 OK LOGIN completed"
"IMAPD" 11460 33 "2019-07-14 12:35:33.074" "192.168.0.8" "RECEIVED: A2 SELECT "Trash""
"IMAPD" 11460 33 "2019-07-14 12:35:33.074" "192.168.0.8" "SENT: * 3 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1560258987] current uidvalidity[nl]* OK [UIDNEXT 14] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]A2 OK [READ-WRITE] SELECT completed"
"IMAPD" 11452 33 "2019-07-14 12:35:33.075" "192.168.0.8" "RECEIVED: A3 UID STORE 11:13 +FLAGS.SILENT (\Deleted)"
"IMAPD" 11452 33 "2019-07-14 12:35:33.088" "192.168.0.8" "SENT: A3 OK UID completed"
"IMAPD" 11460 33 "2019-07-14 12:35:33.089" "192.168.0.8" "RECEIVED: A4 FETCH 1:3 (UID RFC822.SIZE FLAGS INTERNALDATE BODYSTRUCTURE ENVELOPE BODY.PEEK[HEADER.FIELDS (importance x-priority references content-type)])"
"IMAPD" 11460 33 "2019-07-14 12:35:33.090" "192.168.0.8" "SENT: * 1 FETCH (UID 11 RFC822.SIZE 1349 FLAGS (\Deleted \Seen) INTERNALDATE "14-Jul-2019 08:00:39 +0200" ENVELOPE ("Sun, 14 Jul 2019 08:00:39 +0000" "test 3" (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vasseler@ziggo.nl" NIL "vasseler" "ziggo.nl")) NIL NIL NIL "<em94be0f48-5952-495f-b422-a7a71044612d@vincent>") BODYSTRUCTURE (("TEXT" "PLAIN" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 1 1)("TEXT" "HTML" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 567 16) "ALTERNATIVE" ("BOUNDARY" "------=_MBFEDE7459-D93E-453D-AB9F-7A153089B25C") NIL NIL) BODY[HEADER.FIELDS (importance x-priority references content-type)] {98}"
"IMAPD" 11460 33 "2019-07-14 12:35:33.090" "192.168.0.8" "SENT: )"
"IMAPD" 11460 33 "2019-07-14 12:35:33.091" "192.168.0.8" "SENT: * 2 FETCH (UID 12 RFC822.SIZE 2068 FLAGS (\Deleted \Seen) INTERNALDATE "14-Jul-2019 07:49:30 +0200" ENVELOPE ("Sun, 14 Jul 2019 07:49:30 +0000" "Fw: test 2" (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vasseler@ziggo.nl" NIL "vasseler" "ziggo.nl")) NIL NIL NIL "<em38db5e5e-6c19-4a9c-ad5f-c295688f1583@vincent>") BODYSTRUCTURE (("TEXT" "PLAIN" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 194 9)("TEXT" "HTML" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 1111 26) "ALTERNATIVE" ("BOUNDARY" "------=_MBDA71BC59-7E95-4C5B-916A-1082B117AC61") NIL NIL) BODY[HEADER.FIELDS (importance x-priority references content-type)] {98}"
"IMAPD" 11460 33 "2019-07-14 12:35:33.092" "192.168.0.8" "SENT: )"
"IMAPD" 11460 33 "2019-07-14 12:35:33.093" "192.168.0.8" "SENT: * 3 FETCH (UID 13 RFC822.SIZE 1349 FLAGS (\Deleted \Seen) INTERNALDATE "14-Jul-2019 07:47:10 +0200" ENVELOPE ("Sun, 14 Jul 2019 07:47:10 +0000" "test 1" (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vinnie@fam-asseler.nl" NIL "vinnie" "fam-asseler.nl")) (("vasseler@ziggo.nl" NIL "vasseler" "ziggo.nl")) NIL NIL NIL "<em3e13207d-4031-4c5d-94f8-1b093a454545@vincent>") BODYSTRUCTURE (("TEXT" "PLAIN" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 1 1)("TEXT" "HTML" ("CHARSET" "utf-8") NIL NIL "quoted-printable" 567 16) "ALTERNATIVE" ("BOUNDARY" "------=_MB8ADA437F-EFC4-403F-99C6-656A13D590DE") NIL NIL) BODY[HEADER.FIELDS (importance x-priority references content-type)] {98}"
"IMAPD" 11460 33 "2019-07-14 12:35:33.093" "192.168.0.8" "SENT: )"
"IMAPD" 11460 33 "2019-07-14 12:35:33.094" "192.168.0.8" "SENT: A4 OK FETCH completed"
"IMAPD" 11456 33 "2019-07-14 12:35:33.094" "192.168.0.8" "RECEIVED: A5 UID SEARCH DELETED"
"IMAPD" 11460 26 "2019-07-14 12:35:33.094" "192.168.0.8" "RECEIVED: DONE"
"IMAPD" 11456 33 "2019-07-14 12:35:33.095" "192.168.0.8" "SENT: * SEARCH 11 12 13"
"IMAPD" 11460 26 "2019-07-14 12:35:33.095" "192.168.0.8" "SENT: A9 OK IDLE terminated"
"IMAPD" 11456 33 "2019-07-14 12:35:33.095" "192.168.0.8" "SENT: A5 OK UID completed"
"IMAPD" 11448 26 "2019-07-14 12:35:33.096" "192.168.0.8" "RECEIVED: A10 LIST "" "Trash.%""
"IMAPD" 11460 33 "2019-07-14 12:35:33.096" "192.168.0.8" "RECEIVED: A6 EXPUNGE"
"IMAPD" 11448 26 "2019-07-14 12:35:33.096" "192.168.0.8" "SENT: A10 OK LIST completed"
"DEBUG" 11460 "2019-07-14 12:35:33.097" "Deleting message"
"DEBUG" 11460 "2019-07-14 12:35:33.098" "Deleting message file."
"DEBUG" 11460 "2019-07-14 12:35:33.099" "Deleting message"
"DEBUG" 11460 "2019-07-14 12:35:33.100" "Deleting message file."
"DEBUG" 11460 "2019-07-14 12:35:33.101" "Deleting message"
"DEBUG" 11460 "2019-07-14 12:35:33.101" "Deleting message file."
"IMAPD" 11460 33 "2019-07-14 12:35:33.102" "192.168.0.8" "SENT: * 1 EXPUNGE[nl]* 1 EXPUNGE[nl]* 1 EXPUNGE"
"IMAPD" 11460 33 "2019-07-14 12:35:33.103" "192.168.0.8" "SENT: A6 OK EXPUNGE Completed"
"DEBUG" 11452 "2019-07-14 12:35:33.114" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 27, Code: 2, Message: End of file"
"DEBUG" 11452 "2019-07-14 12:35:33.115" "Ending session 27"
"DEBUG" 11452 "2019-07-14 12:35:33.150" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 26, Code: 2, Message: End of file"
"DEBUG" 11456 "2019-07-14 12:35:33.151" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 33, Code: 2, Message: End of file"
"DEBUG" 11452 "2019-07-14 12:35:33.151" "Ending session 26"
"DEBUG" 11456 "2019-07-14 12:35:33.152" "Ending session 33"
Post by jimimaseye » 2019-07-14 12:45
2019-07-14 11:13
Post by palinka » 2019-07-14 16:03
Vinnie1000 wrote:
2019-07-13 12:32
Test: Test IPv6
You're relaying to yourself? Is this: www69.totaalholding.nl ESMTP Exim 4.92 installed on the same IP? I just tried both that and mail.fam-asseler.nl on mxtoolbox and neither responded to smtp query (timeout).
Run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914
Vinnie1000
Post by Vinnie1000 » 2019-07-14 16:35
Hi Palinka,
Your wright, my domain is fam-asseler.nl And hmail is set localy on this domain. The same is set to relay to this domain. mayby I do not configure it wright.
The script gives this;
2019-07-14   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - faxxxxxxxxx.nl                 Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: vincent@Domain1.com
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
     External To External - False
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain1.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
                              Minutes to Autoban:             40  (0,67 hours, 0,03 days)
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                      EXTERNAL.TLD  (ok)       Disc. on invalid:   True  Delivered-To hdr: False
                     Port: 587                 Max number commands: 100  Loop limit:           5
                     Con. Sec.: SSL/TLS
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 465   / SMTP   -   None
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-07-14.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-07-14.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Vinnie1000
Post by Vinnie1000 » 2019-07-14 16:39
Hi jimimaseye ,
Sorry that no SMPT is in the log file. I had done whatt mattg hat wrote, cleared the log file and tried to sent a email agian. I think that Palinka is on to something watt i doing wrong.
Thanks for your repy.
Post by palinka » 2019-07-14 17:09
Diagnostics look very vanilla to me. The only thing in question seems to be your relay. So is there an exim server in your LAN sharing your WAN IP? Because that's what your internal diagnostic report says.
But both internal and Jimi's diagnostics report no mx connection possible. Mxtoolbox confirms that, although you have an mx record that appears to point to the correct IP.
I would guess your lan/router setup is faulty.
If you have an exim server running, why? If you want to use hmailserver, it can do all exim can making exim redundant. Turn it off (at least for testing). If port 25 outbound is open, get rid of the relay in hmailserver. If not, use a different relay. SMTP2GO has a free (limited) option. Sign up for a free account for testing purposes.
Make sure your router is forwarding port 25 (and any other mail ports you want) to the machine running hmailserver. Get those things sorted out and try again.
Vinnie1000
Post by Vinnie1000 » 2019-07-15 12:18
Hi Palinka,
Thanks for your reply. I have the SMPT relayer now set off. There is no other exim server running on this pc. My domain host provides with email support, but cannot open port 25 for me. I think this is the problem. I do'nt understand how this can work without port 25 for smpt. The domain provider say's to use port 587 with authentification, wich i had aded to the configuartion of hmailserver. I do not know how to let hmailserver use this port 587 with authentification. Mayby i'm completely wrong with this and is it not possible without using port 25.
I found out that if I want to sent a email from hmailserver to a adress wich contains the domainname it will not sent at all. Then it keeps in the locat email client. When i sent it to a other domain it is sent but never comes to the receiver.
I keep trying and any suggestion is welcome. :oops:
This is the log without the SMPT relayer and to a other domain adress.
"IMAPD" 22088 119 "2019-07-15 12:26:44.022" "192.168.0.8" "RECEIVED: A3 UID SEARCH HEADER "Message-Id" "<emabf1e5fb-db6a-410e-ae75-8c7a52cc7768@vincent>""
"IMAPD" 22088 119 "2019-07-15 12:26:44.023" "192.168.0.8" "SENT: * SEARCH 23"
"IMAPD" 22088 119 "2019-07-15 12:26:44.024" "192.168.0.8" "SENT: A3 OK UID completed"
"IMAPD" 23952 119 "2019-07-15 12:26:44.027" "192.168.0.8" "RECEIVED: A4 NOOP"
"IMAPD" 23952 119 "2019-07-15 12:26:44.027" "192.168.0.8" "SENT: A4 OK NOOP completed"
"DEBUG" 11232 "2019-07-15 12:26:44.028" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 119, Code: 2, Message: End of file"
"DEBUG" 11232 "2019-07-15 12:26:44.029" "Ending session 119"
"IMAPD" 22088 117 "2019-07-15 12:26:44.029" "192.168.0.8" "RECEIVED: A10 UID STORE 11 +FLAGS.SILENT (\Deleted)"
"IMAPD" 22088 117 "2019-07-15 12:26:44.031" "192.168.0.8" "SENT: A10 OK UID completed"
"IMAPD" 23952 117 "2019-07-15 12:26:44.033" "192.168.0.8" "RECEIVED: A11 UID SEARCH DELETED"
"IMAPD" 23952 117 "2019-07-15 12:26:44.034" "192.168.0.8" "SENT: * SEARCH 11"
"IMAPD" 23952 117 "2019-07-15 12:26:44.034" "192.168.0.8" "SENT: A11 OK UID completed"
"IMAPD" 11232 117 "2019-07-15 12:26:44.035" "192.168.0.8" "RECEIVED: A12 EXPUNGE"
"DEBUG" 11232 "2019-07-15 12:26:44.036" "Deleting message"
"DEBUG" 11232 "2019-07-15 12:26:44.037" "Deleting message file."
"IMAPD" 11232 117 "2019-07-15 12:26:44.038" "192.168.0.8" "SENT: * 1 EXPUNGE"
"IMAPD" 11232 117 "2019-07-15 12:26:44.039" "192.168.0.8" "SENT: A12 OK EXPUNGE Completed"
"DEBUG" 23952 "2019-07-15 12:26:45.416" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.0.8, Session: 117, Code: 2, Message: End of file"
"DEBUG" 23952 "2019-07-15 12:26:45.418" "Ending session 117"
"IMAPD" 23952 114 "2019-07-15 12:26:48.377" "192.168.0.8" "RECEIVED: DONE"
"IMAPD" 23952 114 "2019-07-15 12:26:48.378" "192.168.0.8" "SENT: A13 OK IDLE terminated"
"IMAPD" 22088 114 "2019-07-15 12:26:48.379" "192.168.0.8" "RECEIVED: A14 IDLE"
"IMAPD" 22088 114 "2019-07-15 12:26:48.379" "192.168.0.8" "SENT: + idling"
"SMTPC" 23952 120 "2019-07-15 12:27:00.649" "212.54.34.8" "RECEIVED: 421 Cannot connect to SMTP server 212.54.34.8 (212.54.34.8:25), connect error 10060"
"SMTPC" 23952 120 "2019-07-15 12:27:00.650" "212.54.34.8" "SENT: QUIT"
"DEBUG" 11232 "2019-07-15 12:27:00.651" "The read operation failed. Bytes transferred: 0 Remote IP: 212.54.34.8, Session: 120, Code: 10053, Message: De software op uw hostcomputer heeft een verbinding verbroken"
"DEBUG" 11232 "2019-07-15 12:27:00.652" "Ending session 120"
"DEBUG" 5448 "2019-07-15 12:27:00.652" "External delivery process completed"
"DEBUG" 5448 "2019-07-15 12:27:00.653" "Starting external delivery process. Server: mx.tb.mail.iss.as9143.net ( 212.54.42.8 ), Port: 25, Security: 2, User name: "
"DEBUG" 5448 "2019-07-15 12:27:00.654" "Creating session 122"
"TCPIP" 5448 "2019-07-15 12:27:00.655" "Connecting to 212.54.42.8:25..."
"DEBUG" 11232 "2019-07-15 12:27:00.658" "TCP connection started for session 122"
Post by palinka » 2019-07-15 13:50
You seem to have multiple issues. Let's start from scratch. Is 185.87.187.219 your IP or your ISP's relay IP?
Vinnie1000
Post by Vinnie1000 » 2019-07-15 14:25
Hi Palinka,
185.87.187.219 is the Ip from my ISP's relay IP.
Thanks for all the help from you and the others. :mrgreen:
Post by palinka » 2019-07-15 19:19
There's your problem. Your initial relay settings were likely correct, but your mx records were wrong.
https://mxtoolbox.com/SuperTool.aspx?ac ... n=toolpage
Put the relay back like it was before. Then change your mx records so they point to your own IP.
Post by palinka » 2019-07-15 19:26
PS - you may find that your ISP will only allow relaying from your registered account, which is unlikely to be your fam-asseler.nl domain. Don't be shocked if you still can't SEND email. If that happens, sign up for a free relay account at smtp2go and give that a try. At least you'll be able to troubleshoot sending issues. But try your ISP as relay first since you're already paying for it.
Vinnie1000
Post by Vinnie1000 » 2019-07-15 19:52
Hi Palinka,
I will try it out tomorrow and let you know. Thanks for all! :D
Vinnie1000
Post by Vinnie1000 » 2019-07-18 10:14
Hi Palinka,
I tried to make it work with domain fam-asseler.nl. But this will not do the trick. Then I tried a other domain famasseler.nl without mail with a other ISP for 3 euro a year. This will not work to. At last I tried SMP2GO and this works. The new domain famasseler.nl should work also say's the ISP man. I think I got the dns still wrongly configured. For example I set the mx record ok but the hmailserver ip wrong. How can i check watt the hmailserver ip schould be. I tried out watts myip and used that ip for de dns but there are several ip's and when i use this ip i get blacklisted and other errors in MXtool. It works now with SMP2GO, but i like to use hmailserver to get the smpt working without SMP2GO.
Sofare this project. Can you give me more information on dns settings? Like watt to put with the record like;
A
AAA
MX
Cname
It’s all abadacabra for me wright now. Thanks for all your time and reply’s.
Greetz Vinnie1000
Update: With SMP2GO email sent to hmailserver from client will not be received in hmailsserver or client! Another problem.
Post by palinka » 2019-07-18 12:32
A should be your domain and point to the ip of your hmailserver.
MX should be your domain and point to the ip of your hmailserver.
Don't worry about cname and AAAA. They don't have anything to do with email.
Are you on a residential ip? Residential IPs are policy block blacklisted. No one will accept mail from a residential ip. Im on one and that's why i use a relay. Plus, port 25 outbound is blocked by my isp.
Vinnie1000
Post by Vinnie1000 » 2019-07-18 13:12
Hi Palinka,
my dns settings are now;
Naam Domein Type Prio Content
@ .famasseler.nl A 84.106.206.7
mail .famasseler.nl A 84.106.206.7
@ .famasseler.nl MX 20 fallbackmail.zxcs.nl.
@ .famasseler.nl MX 10 mail.famasseler.nl.
_domainkey .famasseler.nl TXT "o=~"
@ .famasseler.nl TXT "v=spf1 a mx -all"
_dmarc .famasseler.nl TXT "v=DMARC1; p=reject; sp=reject; adkim=s; aspf=s"
All the others records i have deleted. Like Cname and AAAA.
MXtools gives 5 Problems;
Category Host Result
Blacklist mail.famasseler.nl Blacklisted by Spamhaus ZEN
https famasseler.nl Unable to connect to the remote server (https://famasseler.nl)
dns famasseler.nl SOA Expire Value out of recommended range
smtp mail.famasseler.nl Reverse DNS does not match SMTP Banner
smtp mail.famasseler.nl Warning - Does not support TLS.
Ip 84.106.206.7 is myip and Ip 185.104.28.238 the Ip from my famasseler.nl domain, where port 25 is open and has no authentification needed. Ip 84.106.206.7 is my internet provider. wich has a policy that port 25 is closed. When I chek the ip's with open port finder i get;
Remote Address
84.106.206.7
Use Current IP
Port Number
25
Open Port 25 is open on 84.106.206.7.
And for IP 185.104.28.238
open port finder
Remote Address
185.104.28.238
Use Current IP
Port Number
25
Open Port 25 is open on 185.104.28.238
So I think that for both Ip's this port is open?
Hmailserver diagnostics say's;
Test: Test IPv6
Trying to connect to host mail.famasseler.nl...
Trying to connect to TCP/IP address 185.104.28.238 on port 25.
Received: 421 Cannot connect to SMTP server 185.104.28.238 (185.104.28.238:25), connect error 10060.
Trying to resolve MX records for famasseler.nl...
Host name found: mail.famasseler.nl
Host name found: fallbackmail.zxcs.nl
Connecting to TCP/IP address in MX records for local domain domain famasseler.nl...
Vinnie1000.
Post by palinka » 2019-07-18 16:26
Vinnie1000 wrote:
2019-07-18 13:12
Hi Palinka,
https://www.spamhaus.org/query/ip/84.106.206.7
As suspected, you're on the PBL. Probably for being a residential IP.
https://mxtoolbox.com/SuperTool.aspx?ac ... ler.nl&run
Tests OK. SMTP tests OK.
Connecting to 84.106.206.7
220 HmailServerready. [710 ms]
EHLO keeper-us-east-1b.mxtoolbox.com
250-famasseler.nl
250-SIZE 20480000
250-AUTH LOGIN
250 HELP [718 ms]
MAIL FROM:<supertool@mxtoolbox.com>
250 OK [705 ms]
RCPT TO:<test@mxtoolboxsmtpdiag.com>
530 SMTP authentication is required. [714 ms]
LookupServer 4188ms
Change the banner from "HmailServerready" to "mail.famasseler.nl". You want to identify yourself. My server would reject mail from you with EHLO "HmailServerready" because its not a FQDN.
Remote Address
84.106.206.7
Use Current IP
Port Number
25
Port 25 INCOMING is open. Not outgoing - see below.
open port finder
Remote Address
185.104.28.238
Use Current IP
Port Number
25
Test: Test IPv6
Port 25 OUTGOING is blocked by your ISP. Change your relay settings to a different port. Mail submission should be on port 587.
Is your hmailserver located on 185.104.28.238 or 84.106.206.7? I know its on 84.106.206.7. MX records should point to your hmailserver. From my test at mxtoolbox (above), it appears you already fixed that. DNS records take hours to propgate. Make sure your mx points to 84.106.206.7 and wait until tomorrow to test again.
Vinnie1000.
Vinnie1000
Post by Vinnie1000 » 2019-07-18 20:16
Hi Palinka,
Thanks again for your help. I done watt you explaind above and test it tomorrow again.
Good evening and til tomorrow. :D
Vinnie1000
Vinnie1000
Post by Vinnie1000 » 2019-07-19 12:44
Hi palnka,
All tested and the banner is stil wrong.
220 mail.famasseler.nl [706 ms]
250-mail.famasseler.nl
250-SIZE 20480000
250 HELP [709 ms]
SendSMTPCommand: Timeout waiting for response after 15 seconds.
LookupServer 18138ms
The client email on the same pc can't acces hmailserver, sofare this. First the banner problem to solve i think.
Vinnie1000
Post by palinka » 2019-07-19 14:31
Vinnie1000 wrote:
2019-07-19 12:44
Hi palnka,
250-SIZE 20480000
250 HELP [709 ms]
Vinnie1000
It worked for me just now.
220 mail.famasseler.nl [695 ms]
250-SIZE 20480000
250-AUTH LOGIN
250 HELP [729 ms]
250 OK [722 ms]
530 SMTP authentication is required. [708 ms]
LookupServer 4225ms
Edit - i skimmed your post without looking carefully. It worked for you too. I just bolded the part that is your server communicating with mxtoolbox.com. I'm not sure what the timeout error was when you tried. Probably a routine network glitch. Nothing to worry about.
Vinnie1000
Post by Vinnie1000 » 2019-07-19 14:44
Hi Palinka,
I found out that the ISP public Ip gives the error. When i set the banner reply to: "cable.dynamic.v4.ziggo.nl" in hmailserver the error is gone in MXtool. MXtool gives now: SMTP Reverse DNS Mismatch OK - 84.106.206.7 resolves to 84-106-206-7.cable.dynamic.v4.ziggo.nl
220 cable.dynamic.v4.ziggo.nl [704 ms]
EHLO keeper-us-east-1c.mxtoolbox.com
250-SIZE 20480000
250-AUTH LOGIN
250 HELP [718 ms]
250 OK [709 ms]
LookupServer 3858ms
So i Think this part is OK now.
Greetz,
Vinnie1000
Post by palinka » 2019-07-19 15:00
^^ This would get you firewall banned on my server IF you were sending directly. But since you're using a relay it doesn't really matter what you put as a banner. The world will see your relay's banner, not yours.
I still think you should identify yourself with your domain name and not your cable company's dynamic dns name. That's what I do, for whatever that's worth.
Vinnie1000
Post by Vinnie1000 » 2019-07-19 15:22
Hi Palinka,
Tanks for all your help. I wil set it back to mij mail.famasseler.nl. I try to get the the email client to interact with hmailserver but somehow it will not work, where it wordkt before.
Greetz,
Vinnie1000
