Email sent to random person as BCC when invalid TO field specified
mfields
Post by mfields » 2019-06-17 17:01
Hello
Dealing with a possible bug in hMailServer which we believe has caused an email to be sent to a recipient which wasn't intended and looking for some guidance. Haven't attempted to reproduce yet and suspect it could be hard to do.
An email was sent from our application using CDO.Message.
To: legitimate-recipient1@foo.com; legitimate-recipient2@foo.com; legitimate-recipient3@foo.com : legitimate-recipient4@foo.com
Note that there was a typo in the To field, where a colon was used instead of a semi-colon. What resulted in hMailServer was an email sent to legitimate-recipient1@foo.com, legitimate-recipient2@foo.com and a different email address which wasn't contained in the To field. I see that the different email address the message was sent to was one which had previously been emailed in another session prior (but not immediately prior) to the email in question. Logs are as follows:
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.001"	"127.0.0.1"	"SENT: 220 servername.company.com ESMTP"
"SMTPD"	2296	1647401	"2019-06-14 12:10:13.002"	"127.0.0.1"	"RECEIVED: HELO SERVERNAMEHERE"
"SMTPD"	2296	1647401	"2019-06-14 12:10:13.003"	"127.0.0.1"	"SENT: 250 Hello."
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.004"	"127.0.0.1"	"RECEIVED: MAIL FROM: <noreply@company.com>"
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.016"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2308	1647401	"2019-06-14 12:10:13.017"	"127.0.0.1"	"RECEIVED: RCPT TO: <legitimate-recipient1@foo.com>"
"SMTPD"	2308	1647401	"2019-06-14 12:10:13.020"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.021"	"127.0.0.1"	"RECEIVED: RCPT TO: <legitimate-recipient2@foo.com>"
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.023"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2308	1647401	"2019-06-14 12:10:13.024"	"127.0.0.1"	"RECEIVED: RCPT TO: <incorrect-recipient@bar.com>"
"SMTPD"	2308	1647401	"2019-06-14 12:10:13.026"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.027"	"127.0.0.1"	"RECEIVED: DATA"
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.027"	"127.0.0.1"	"SENT: 354 OK, send."
"SMTPD"	1788	1647401	"2019-06-14 12:10:13.034"	"127.0.0.1"	"SENT: 250 Queued (0.000 seconds)"
"SMTPD"	2264	1647401	"2019-06-14 12:10:13.035"	"127.0.0.1"	"RECEIVED: QUIT"
"APPLICATION"	2136	"2019-06-14 12:10:13.036"	"SMTPDeliverer - Message 11711007: Delivering message from noreply@company.com to legitimate-recipient1@foo.com, legitimate-recipient2@foo.com, incorrect-recipient@bar.com. File: D:\hMailServer\Data\{D97FF848-4B1D-42AA-82F0-0BB742BB337B}.eml"
"APPLICATION"	2136	"2019-06-14 12:10:18.949"	"SMTPDeliverer - Message 11711007: Message delivery thread completed."
How can we proceed and help identify the root cause?
Re: Email sent to random person as BCC when invalid TO field specified
Post by jimimaseye » 2019-06-17 22:49
I would think it highly unlikely a problem with Hmailserver but yes, to determine the root cause, you would need to do a test.
I suspect the issue is still with the 'email client' though. If you look at the log hmailserver RECEIVED:
It doesnt make that up; "incorrect-recipient@bar.com" is what it was given by CDO
Of course, under normal circumstances, the cause would be laden entirely on the email client which should have its own email address convention check and parser (separating the addresses out by the delimiter of semi-colon or comma) but as you used CDO there is no such thing...or is there?! (Perhaps you should think about that).
Reproduce the exact test but change and use email addresses to someone or accounts you have access to (so random emails do not get sent out). I dont know for sure how CDO handles incorrect address formatting but I REALLY wouldnt be surprised if it didnt struggle somehow. I do know that Hmailserver has a very correct email address format checker builtin (as I helped write it with Martin after determining a few flaws in its original form) and should the original parser have tried to pass an incorrect format (such as "legitimate-recipient3@foo.com : legitimate-recipient4@foo.com" then it would not have accepted it.
Post by mattg » 2019-06-17 23:13
ALSO, can you please include your CDO.message code
I use CDO to send lots of mail (dozens every day for more than 10 years), and have never seen this issue
Post by SorenR » 2019-06-17 23:48
mfields wrote:
2019-06-17 17:01
Hello
I believe you just did... You found the ":" that caused a bug in your code.
This:
is proof that hMailServer received wrong information. Each email is handled in a private session and when the mail is sent, the session is destroyed. There is no way hMailServer can "remember" an address from a previous session.
mfields
Post by mfields » 2019-06-19 11:47
I have successfully replicated the issue where data is leaked from one session/thread to another.
I can confirm with 100% certainty that it is not our code. The issue must lie with either CDOSYS or hMailServer.
2019-06-17 23:13
Since we enabled the AWStats logs in April 2015, we've sent in excess of 50 million emails with the majority via CDO.
As this points to a vulnerability in code, how do you wish to proceed so I can share the details on how to replicate and copies of log files (with personal data removed)?
Post by mattg » 2019-06-19 15:42
posting here is fine (for de-identified data) or by PM if don't want to post publically
If we can replicate - we will raise an issue on GitHub
Post by SorenR » 2019-06-19 16:49
It's quite simple to test...
The client use ";" to split the string thus the ":" is regarded as part of the address.
Telnet <your mailserver> 25
Lines NOT prefixed with a number is me typing ...
220 mx.mydomain.tld ESMTP
EHLO SorenR
250-mx.mydomain.tld
250 SIZE
MAIL FROM:<SorenR@mydomain.tld>
250 OK
RCPT TO:<SorenR@mydomain.tld:Postmaster@mydomain.tld>
550 Unknown user
QUIT
221 goodbye
Connection to host lost.
C:\WINDOWS>
Yes, I tried it with valid users :mrgreen:
EHLO SorenR
250-mx.mydomain.tld
250 SIZE
250 OK
RCPT TO:<postmaster@mydomain.tld>
530 SMTP authentication is required.
QUIT
221 goodbye
C:\WINDOWS>
PS... Some may wonder why my server do not display "250 HELP" after "250 SIZE" ... I rewrote the initial fix by having the code figure out what was needed. The "250 HELP" can be used to identify the server. 8)
mfields
Post by mfields » 2019-06-19 17:03
On our production server which has IIS and hMailServer as an outbound SMTP client, I created a new, separate ASP VBScript page from our main application to send an email using CDO where the To field contained a colon separator (see below for the details).
I executed this ASP page every 500ms via a Powershell script. At no time was the script changed.
Eventually I started to see entries in the log file as follows:
"SMTPD"	2488	153712	"2019-06-19 10:00:35.220"	"127.0.0.1"	"SENT: 220 servername.company.com ESMTP"
"SMTPD"	2492	153712	"2019-06-19 10:00:35.221"	"127.0.0.1"	"RECEIVED: HELO SERVERNAMEHERE"
"SMTPD"	2492	153712	"2019-06-19 10:00:35.221"	"127.0.0.1"	"SENT: 250 Hello."
"SMTPD"	2476	153712	"2019-06-19 10:00:35.221"	"127.0.0.1"	"RECEIVED: MAIL FROM: <noreply@company.com>"
"SMTPD"	2476	153712	"2019-06-19 10:00:35.223"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2492	153712	"2019-06-19 10:00:35.224"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid1@mypersonaldomain.com>"
"SMTPD"	2492	153712	"2019-06-19 10:00:35.226"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2488	153712	"2019-06-19 10:00:35.226"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid2@mypersonaldomain.com>"
"SMTPD"	2488	153712	"2019-06-19 10:00:35.228"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2492	153712	"2019-06-19 10:00:35.229"	"127.0.0.1"	"RECEIVED: RCPT TO: <î>"
"SMTPD"	2492	153712	"2019-06-19 10:00:35.229"	"127.0.0.1"	"SENT: 550 A valid address is required."
"SMTPD"	2476	153712	"2019-06-19 10:00:35.230"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	2476	153712	"2019-06-19 10:00:35.231"	"127.0.0.1"	"SENT: 221 goodbye"
then
"SMTPD"	2476	157791	"2019-06-19 10:19:53.650"	"127.0.0.1"	"SENT: 220 servername.company.com ESMTP"
"SMTPD"	2504	157791	"2019-06-19 10:19:53.651"	"127.0.0.1"	"RECEIVED: HELO SERVERNAMEHERE"
"SMTPD"	2504	157791	"2019-06-19 10:19:53.651"	"127.0.0.1"	"SENT: 250 Hello."
"SMTPD"	2476	157791	"2019-06-19 10:19:53.652"	"127.0.0.1"	"RECEIVED: MAIL FROM: <noreply@company.com>"
"SMTPD"	2476	157791	"2019-06-19 10:19:53.654"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2504	157791	"2019-06-19 10:19:53.655"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid1@mypersonaldomain.com>"
"SMTPD"	2504	157791	"2019-06-19 10:19:53.659"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2476	157791	"2019-06-19 10:19:53.659"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid2@mypersonaldomain.com>"
"SMTPD"	2476	157791	"2019-06-19 10:19:53.661"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2504	157791	"2019-06-19 10:19:53.662"	"127.0.0.1"	"RECEIVED: RCPT TO: <`®iaW>"
"SMTPD"	2504	157791	"2019-06-19 10:19:53.663"	"127.0.0.1"	"SENT: 550 A valid address is required."
"SMTPD"	2476	157791	"2019-06-19 10:19:53.663"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	2476	157791	"2019-06-19 10:19:53.664"	"127.0.0.1"	"SENT: 221 goodbye"
and eventually it also sent the email to an actual customer (who had been sent a legitimate email by our application shortly before):
"SMTPD"	2492	157512	"2019-06-19 10:19:36.830"	"127.0.0.1"	"SENT: 220 servername.company.com ESMTP"
"SMTPD"	2444	157512	"2019-06-19 10:19:36.831"	"127.0.0.1"	"RECEIVED: HELO SERVERNAMEHERE"
"SMTPD"	2444	157512	"2019-06-19 10:19:36.831"	"127.0.0.1"	"SENT: 250 Hello."
"SMTPD"	2448	157512	"2019-06-19 10:19:36.832"	"127.0.0.1"	"RECEIVED: MAIL FROM: <noreply@company.com>"
"SMTPD"	2448	157512	"2019-06-19 10:19:36.833"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2492	157512	"2019-06-19 10:19:36.834"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid1@mypersonaldomain.com>"
"SMTPD"	2492	157512	"2019-06-19 10:19:36.836"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2444	157512	"2019-06-19 10:19:36.836"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid2@mypersonaldomain.com>"
"SMTPD"	2444	157512	"2019-06-19 10:19:36.838"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2492	157512	"2019-06-19 10:19:36.839"	"127.0.0.1"	"RECEIVED: RCPT TO: <i.surname@arealcustomer.com>"
"SMTPD"	2492	157512	"2019-06-19 10:19:36.841"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2444	157512	"2019-06-19 10:19:36.841"	"127.0.0.1"	"RECEIVED: DATA"
"SMTPD"	2444	157512	"2019-06-19 10:19:36.842"	"127.0.0.1"	"SENT: 354 OK, send."
"SMTPD"	1756	157512	"2019-06-19 10:19:36.846"	"127.0.0.1"	"SENT: 250 Queued (0.000 seconds)"
"SMTPD"	2492	157512	"2019-06-19 10:19:36.847"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	2492	157512	"2019-06-19 10:19:36.847"	"127.0.0.1"	"SENT: 221 goodbye"
followed by mangled garbage:
"SMTPD"	2448	157777	"2019-06-19 10:19:52.801"	"127.0.0.1"	"SENT: 220 servername.company.com ESMTP"
"SMTPD"	2504	157777	"2019-06-19 10:19:52.802"	"127.0.0.1"	"RECEIVED: HELO SERVERNAMEHERE"
"SMTPD"	2504	157777	"2019-06-19 10:19:52.802"	"127.0.0.1"	"SENT: 250 Hello."
"SMTPD"	2500	157777	"2019-06-19 10:19:52.803"	"127.0.0.1"	"RECEIVED: MAIL FROM: <noreply@company.com>"
"SMTPD"	2500	157777	"2019-06-19 10:19:52.805"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2448	157777	"2019-06-19 10:19:52.805"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid1@mypersonaldomain.com>"
"SMTPD"	2448	157777	"2019-06-19 10:19:52.807"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2500	157777	"2019-06-19 10:19:52.808"	"127.0.0.1"	"RECEIVED: RCPT TO: <valid2@mypersonaldomain.com>"
"SMTPD"	2500	157777	"2019-06-19 10:19:52.810"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	2448	157777	"2019-06-19 10:19:52.811"	"127.0.0.1"	"RECEIVED: RCPT TO: <i.surnam„¨au
"SMTPD"	2448	157777	"2019-06-19 10:19:52.811"	"127.0.0.1"	"SENT: 550 A valid address is required."
"SMTPD"	2500	157777	"2019-06-19 10:19:52.812"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	2500	157777	"2019-06-19 10:19:52.813"	"127.0.0.1"	"SENT: 221 goodbye"
To rule out anything on our production servers, I set out to replicate this on a new Azure VM. While I was unable to get it to send an email to an invalid recipient, I was able to get it to say it's received an extra recipient which was not passed from the ASP script using CDO.
I created a new VM in Azure with Windows Server 2016, installed hMailServer and IIS with ASP support.
I added the following ASP file to send an email which sends a simple email to an email address (or addresses) specified in the querystring:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="65001"%>
Private Sub testEmail(emailto)
    Set NewMail = Server.CreateObject("CDO.Message")
    Set iConf = Server.CreateObject("CDO.Configuration")
    Set Flds = iConf.Fields
    iConf.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
    iConf.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "localhost"
    iConf.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 10
    iConf.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
    iConf.Fields.Update
    Set NewMail.Configuration = iConf
    Dim NewMail
    NewMail.To = emailto
    NewMail.From = "noreply@ourdomain.com"
    NewMail.Subject = "Test subject"
    NewMail.HTMLBody = "Test body"
    NewMail.Send
    Set NewMail = Nothing
    Response.Write("Sent email to " & emailto & " at " & Now())
Call testEmail(Request.QueryString("emailto"))
Then use a simple Powershell script to call the page in a loop and execute a couple instances of this script to send a lot of traffic to the page:
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
Do {
$emailswithcolon = @{
    emailto = 'cust1@cust.com;cust2@cust.com;cust3@cust.com: cust4@cust.com'
$emailwithoutcolon = @{
    emailto = 'another@customer.com'
Invoke-WebRequest -URI "http://azurevmIP/emailtest.asp" -Body $emailswithcolon
Invoke-WebRequest -URI "http://azurevmIP/emailtest.asp" -Body $emailwithoutcolon
sleep 0.5
while ($true)
This results in random occurrences in the hMailServer log file of receiving invalid data which should never be possible:
"SMTPD"	2816	48333	"2019-06-19 14:43:48.450"	"127.0.0.1"	"SENT: 220 hmailservertest ESMTP"
"SMTPD"	2816	48333	"2019-06-19 14:43:48.465"	"127.0.0.1"	"RECEIVED: HELO hmailservertest"
"SMTPD"	2816	48333	"2019-06-19 14:43:48.465"	"127.0.0.1"	"SENT: 250 Hello."
"SMTPD"	2816	48333	"2019-06-19 14:43:48.465"	"127.0.0.1"	"RECEIVED: MAIL FROM: <noreply@ourdomain.com>"
"SMTPD"	2816	48333	"2019-06-19 14:43:48.575"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	1768	48333	"2019-06-19 14:43:48.575"	"127.0.0.1"	"RECEIVED: RCPT TO: <cust1@cust.com>"
"SMTPD"	1768	48333	"2019-06-19 14:43:48.575"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	1768	48333	"2019-06-19 14:43:48.575"	"127.0.0.1"	"RECEIVED: RCPT TO: <cust2@cust.com>"
"SMTPD"	1768	48333	"2019-06-19 14:43:48.590"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	1768	48333	"2019-06-19 14:43:48.590"	"127.0.0.1"	"RECEIVED: RCPT TO: <$>"
"SMTPD"	1768	48333	"2019-06-19 14:43:48.590"	"127.0.0.1"	"SENT: 550 A valid address is required."
"SMTPD"	2816	48333	"2019-06-19 14:43:48.590"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	2816	48333	"2019-06-19 14:43:48.590"	"127.0.0.1"	"SENT: 221 goodbye"
and with more data such as the following (note I have removed several other sessions which were communicating in amongst the below lines in the log file):
"SMTPD"	192	59667	"2019-06-19 15:06:49.318"	"127.0.0.1"	"SENT: 220 hmailservertest ESMTP"
"SMTPD"	192	59667	"2019-06-19 15:06:49.318"	"127.0.0.1"	"RECEIVED: HELO hmailservertest"
"SMTPD"	192	59667	"2019-06-19 15:06:49.318"	"127.0.0.1"	"SENT: 250 Hello."
"SMTPD"	192	59667	"2019-06-19 15:06:49.334"	"127.0.0.1"	"RECEIVED: MAIL FROM: <noreply@ourdomain.com>"
"SMTPD"	192	59667	"2019-06-19 15:06:49.350"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	192	59667	"2019-06-19 15:06:49.350"	"127.0.0.1"	"RECEIVED: RCPT TO: <cust1@cust.com>"
"SMTPD"	192	59667	"2019-06-19 15:06:49.365"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	4864	59667	"2019-06-19 15:06:49.365"	"127.0.0.1"	"RECEIVED: RCPT TO: <cust2@cust.com>"
"SMTPD"	4864	59667	"2019-06-19 15:06:49.584"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	4788	59667	"2019-06-19 15:06:49.584"	"127.0.0.1"	"RECEIVED: RCPT TO: <ÈGÃÛþ>"
"SMTPD"	4788	59667	"2019-06-19 15:06:49.584"	"127.0.0.1"	"SENT: 550 A valid address is required."
"SMTPD"	3956	59667	"2019-06-19 15:06:49.600"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	3956	59667	"2019-06-19 15:06:49.600"	"127.0.0.1"	"SENT: 221 goodbye"
P.S. it's fairly easy to locate such lines in the log file by using a RegEx query (which I use with FileSeek):
<.{1,13}>
I am fairly convinced there a leakage of data either with CDO or hMailServer, possibly a buffer overrun or similar.
A copy of the log file is available to download here: https://www.dropbox.com/s/we4290mjy0zds ... 9.log?dl=0
I look forward to your reply.
Post by SorenR » 2019-06-19 20:37
Why is "Dim NewMail" down the middle of the code?
Post by SorenR » 2019-06-20 03:20
Wireshark trace performed from the client computer. I believe CDO do have a problem!
No.     Time        Source                Destination           Protocol Info
     32 10.959975   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 32: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Ethernet II, Src: Intel_6c:2c:c6 (00:0e:0c:6c:2c:c6), Dst: CompalIn_f1:cb:fa (1c:75:08:f1:cb:fa)
Internet Protocol, Src: 192.168.0.5 (192.168.0.5), Dst: 192.168.0.60 (192.168.0.60)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4275 (4275), Seq: 1, Ack: 1, Len: 24
Simple Mail Transfer Protocol
     33 10.960257   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 33: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Ethernet II, Src: CompalIn_f1:cb:fa (1c:75:08:f1:cb:fa), Dst: Intel_6c:2c:c6 (00:0e:0c:6c:2c:c6)
Internet Protocol, Src: 192.168.0.60 (192.168.0.60), Dst: 192.168.0.5 (192.168.0.5)
Transmission Control Protocol, Src Port: 4275 (4275), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
     34 10.973105   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 34: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4275 (4275), Seq: 25, Ack: 10, Len: 12
     35 10.973413   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 35: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4275 (4275), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
     36 10.974489   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 36: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4275 (4275), Seq: 37, Ack: 39, Len: 8
     37 10.974760   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user3@mydomain.tld>
Frame 37: 87 bytes on wire (696 bits), 87 bytes captured (696 bits)
Transmission Control Protocol, Src Port: 4275 (4275), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 33
     38 10.975688   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 38: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4275 (4275), Seq: 45, Ack: 72, Len: 8
     39 10.975951   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <wile.e.coyote@acme.inc>
Frame 39: 89 bytes on wire (712 bits), 89 bytes captured (712 bits)
Transmission Control Protocol, Src Port: 4275 (4275), Dst Port: smtp (25), Seq: 72, Ack: 53, Len: 35
     40 10.976869   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 40: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4275 (4275), Seq: 53, Ack: 107, Len: 8
     41 10.977132   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <"road.runner@a"@mydomain.tld>
Frame 41: 92 bytes on wire (736 bits), 92 bytes captured (736 bits)
Transmission Control Protocol, Src Port: 4275 (4275), Dst Port: smtp (25), Seq: 107, Ack: 61, Len: 38
     42 10.977733   192.168.0.5           192.168.0.60          SMTP     S: 550 A valid address is required.
Frame 42: 88 bytes on wire (704 bits), 88 bytes captured (704 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4275 (4275), Seq: 61, Ack: 145, Len: 34
     43 10.980066   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 43: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4275 (4275), Dst Port: smtp (25), Seq: 145, Ack: 95, Len: 6
     46 10.980642   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 46: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4275 (4275), Seq: 95, Ack: 152, Len: 13
     53 10.998247   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 53: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4277 (4277), Seq: 1, Ack: 1, Len: 24
     54 10.998539   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 54: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Transmission Control Protocol, Src Port: 4277 (4277), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
     55 11.008420   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 55: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4277 (4277), Seq: 25, Ack: 10, Len: 12
     56 11.008741   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 56: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4277 (4277), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
     57 11.009833   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 57: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4277 (4277), Seq: 37, Ack: 39, Len: 8
     58 11.010059   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user2@mydomain.tld>
Frame 58: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: 4277 (4277), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 28
     59 11.011446   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 59: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4277 (4277), Seq: 45, Ack: 67, Len: 8
     60 11.011723   192.168.0.60          192.168.0.5           SMTP     C: DATA
Frame 60: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4277 (4277), Dst Port: smtp (25), Seq: 67, Ack: 53, Len: 6
     63 11.016981   192.168.0.5           192.168.0.60          SMTP     S: 354 OK, send.
Frame 63: 69 bytes on wire (552 bits), 69 bytes captured (552 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4277 (4277), Seq: 53, Ack: 73, Len: 15
     68 11.024864   192.168.0.60          192.168.0.5           IMF      from: <user1@mydomain.tld>, subject: Test subject,
Frame 68: 665 bytes on wire (5320 bits), 665 bytes captured (5320 bits)
Transmission Control Protocol, Src Port: 4277 (4277), Dst Port: smtp (25), Seq: 73, Ack: 68, Len: 611
Internet Message Format
     73 11.071263   192.168.0.5           192.168.0.60          SMTP     S: 250 Queued (0.015 seconds)
Frame 73: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4277 (4277), Seq: 68, Ack: 684, Len: 28
     74 11.073017   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 74: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4277 (4277), Dst Port: smtp (25), Seq: 684, Ack: 96, Len: 6
     79 11.076916   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 79: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4277 (4277), Seq: 96, Ack: 691, Len: 13
     85 11.088879   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 85: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4281 (4281), Seq: 1, Ack: 1, Len: 24
     86 11.089169   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 86: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Transmission Control Protocol, Src Port: 4281 (4281), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
     87 11.099402   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 87: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4281 (4281), Seq: 25, Ack: 10, Len: 12
     90 11.099784   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 90: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4281 (4281), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
     91 11.101102   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 91: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4281 (4281), Seq: 37, Ack: 39, Len: 8
     92 11.101338   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user3@mydomain.tld>
Frame 92: 87 bytes on wire (696 bits), 87 bytes captured (696 bits)
Transmission Control Protocol, Src Port: 4281 (4281), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 33
     96 11.102312   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 96: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4281 (4281), Seq: 45, Ack: 72, Len: 8
     97 11.102609   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <wile.e.coyote@acme.inc>
Frame 97: 89 bytes on wire (712 bits), 89 bytes captured (712 bits)
Transmission Control Protocol, Src Port: 4281 (4281), Dst Port: smtp (25), Seq: 72, Ack: 53, Len: 35
     99 11.103835   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 99: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4281 (4281), Seq: 53, Ack: 107, Len: 8
    100 11.104071   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <"road.runner@a"@mydomain.tld>
Frame 100: 92 bytes on wire (736 bits), 92 bytes captured (736 bits)
Transmission Control Protocol, Src Port: 4281 (4281), Dst Port: smtp (25), Seq: 107, Ack: 61, Len: 38
    101 11.104718   192.168.0.5           192.168.0.60          SMTP     S: 550 A valid address is required.
Frame 101: 88 bytes on wire (704 bits), 88 bytes captured (704 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4281 (4281), Seq: 61, Ack: 145, Len: 34
    102 11.106429   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 102: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4281 (4281), Dst Port: smtp (25), Seq: 145, Ack: 95, Len: 6
    104 11.107236   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 104: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4281 (4281), Seq: 95, Ack: 151, Len: 13
    113 11.123057   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 113: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4283 (4283), Seq: 1, Ack: 1, Len: 24
    114 11.123324   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 114: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Transmission Control Protocol, Src Port: 4283 (4283), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
    115 11.135066   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 115: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4283 (4283), Seq: 25, Ack: 10, Len: 12
    116 11.135366   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 116: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4283 (4283), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
    117 11.136472   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 117: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4283 (4283), Seq: 37, Ack: 39, Len: 8
    118 11.136775   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user2@mydomain.tld>
Frame 118: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: 4283 (4283), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 28
    119 11.137724   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 119: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4283 (4283), Seq: 45, Ack: 67, Len: 8
    120 11.137974   192.168.0.60          192.168.0.5           SMTP     C: DATA
Frame 120: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4283 (4283), Dst Port: smtp (25), Seq: 67, Ack: 53, Len: 6
    121 11.143201   192.168.0.5           192.168.0.60          SMTP     S: 354 OK, send.
Frame 121: 69 bytes on wire (552 bits), 69 bytes captured (552 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4283 (4283), Seq: 53, Ack: 73, Len: 15
    122 11.149712   192.168.0.60          192.168.0.5           IMF      from: <user1@mydomain.tld>, subject: Test subject,
Frame 122: 665 bytes on wire (5320 bits), 665 bytes captured (5320 bits)
Transmission Control Protocol, Src Port: 4283 (4283), Dst Port: smtp (25), Seq: 73, Ack: 68, Len: 611
    168 11.194553   192.168.0.5           192.168.0.60          SMTP     S: 250 Queued (0.000 seconds)
Frame 168: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4283 (4283), Seq: 68, Ack: 684, Len: 28
    173 11.198187   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 173: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4283 (4283), Dst Port: smtp (25), Seq: 684, Ack: 96, Len: 6
    178 11.200198   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 178: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4283 (4283), Seq: 96, Ack: 691, Len: 13
    208 11.216050   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 208: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4285 (4285), Seq: 1, Ack: 1, Len: 24
    210 11.216352   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 210: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Transmission Control Protocol, Src Port: 4285 (4285), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
    229 11.226251   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 229: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4285 (4285), Seq: 25, Ack: 10, Len: 12
    230 11.226691   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 230: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4285 (4285), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
    234 11.228101   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 234: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4285 (4285), Seq: 37, Ack: 39, Len: 8
    235 11.228287   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user3@mydomain.tld>
Frame 235: 87 bytes on wire (696 bits), 87 bytes captured (696 bits)
Transmission Control Protocol, Src Port: 4285 (4285), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 33
    238 11.229285   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 238: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4285 (4285), Seq: 45, Ack: 72, Len: 8
    239 11.229469   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <wile.e.coyote@acme.inc>
Frame 239: 89 bytes on wire (712 bits), 89 bytes captured (712 bits)
Transmission Control Protocol, Src Port: 4285 (4285), Dst Port: smtp (25), Seq: 72, Ack: 53, Len: 35
    242 11.230468   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 242: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4285 (4285), Seq: 53, Ack: 107, Len: 8
    243 11.230659   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <"road.runner@a"@mydomain.tld>
Frame 243: 92 bytes on wire (736 bits), 92 bytes captured (736 bits)
Transmission Control Protocol, Src Port: 4285 (4285), Dst Port: smtp (25), Seq: 107, Ack: 61, Len: 38
    246 11.231532   192.168.0.5           192.168.0.60          SMTP     S: 550 A valid address is required.
Frame 246: 88 bytes on wire (704 bits), 88 bytes captured (704 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4285 (4285), Seq: 61, Ack: 145, Len: 34
    250 11.233933   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 250: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4285 (4285), Dst Port: smtp (25), Seq: 145, Ack: 95, Len: 6
    255 11.235044   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 255: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4285 (4285), Seq: 95, Ack: 152, Len: 13
    292 11.254444   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 292: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4287 (4287), Seq: 1, Ack: 1, Len: 24
    293 11.254781   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 293: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Transmission Control Protocol, Src Port: 4287 (4287), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
    312 11.264879   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 312: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4287 (4287), Seq: 25, Ack: 10, Len: 12
    314 11.265152   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 314: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4287 (4287), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
    317 11.266442   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 317: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4287 (4287), Seq: 37, Ack: 39, Len: 8
    319 11.266691   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user2@mydomain.tld>
Frame 319: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: 4287 (4287), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 28
    321 11.267742   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 321: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4287 (4287), Seq: 45, Ack: 67, Len: 8
    323 11.268014   192.168.0.60          192.168.0.5           SMTP     C: DATA
Frame 323: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4287 (4287), Dst Port: smtp (25), Seq: 67, Ack: 53, Len: 6
    333 11.283377   192.168.0.5           192.168.0.60          SMTP     S: 354 OK, send.
Frame 333: 69 bytes on wire (552 bits), 69 bytes captured (552 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4287 (4287), Seq: 53, Ack: 73, Len: 15
    352 11.298326   192.168.0.60          192.168.0.5           IMF      from: <user1@mydomain.tld>, subject: Test subject,
Frame 352: 665 bytes on wire (5320 bits), 665 bytes captured (5320 bits)
Transmission Control Protocol, Src Port: 4287 (4287), Dst Port: smtp (25), Seq: 73, Ack: 68, Len: 611
    400 11.365119   192.168.0.5           192.168.0.60          SMTP     S: 250 Queued (0.032 seconds)
Frame 400: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4287 (4287), Seq: 68, Ack: 684, Len: 28
    404 11.370984   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 404: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4287 (4287), Dst Port: smtp (25), Seq: 684, Ack: 96, Len: 6
    407 11.371592   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 407: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4287 (4287), Seq: 96, Ack: 691, Len: 13
    414 11.384505   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 414: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4295 (4295), Seq: 1, Ack: 1, Len: 24
    415 11.384865   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 415: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Transmission Control Protocol, Src Port: 4295 (4295), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
    416 11.394900   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 416: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4295 (4295), Seq: 25, Ack: 10, Len: 12
    417 11.395181   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 417: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4295 (4295), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
    418 11.396221   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 418: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4295 (4295), Seq: 37, Ack: 39, Len: 8
    419 11.396808   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user3@mydomain.tld>
Frame 419: 87 bytes on wire (696 bits), 87 bytes captured (696 bits)
Transmission Control Protocol, Src Port: 4295 (4295), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 33
    420 11.397719   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 420: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4295 (4295), Seq: 45, Ack: 72, Len: 8
    421 11.398045   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <wile.e.coyote@acme.inc>
Frame 421: 89 bytes on wire (712 bits), 89 bytes captured (712 bits)
Transmission Control Protocol, Src Port: 4295 (4295), Dst Port: smtp (25), Seq: 72, Ack: 53, Len: 35
    422 11.398982   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 422: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4295 (4295), Seq: 53, Ack: 107, Len: 8
    423 11.399383   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <"road.runner@a"@mydomain.tld>
Frame 423: 92 bytes on wire (736 bits), 92 bytes captured (736 bits)
Transmission Control Protocol, Src Port: 4295 (4295), Dst Port: smtp (25), Seq: 107, Ack: 61, Len: 38
    424 11.399945   192.168.0.5           192.168.0.60          SMTP     S: 550 A valid address is required.
Frame 424: 88 bytes on wire (704 bits), 88 bytes captured (704 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4295 (4295), Seq: 61, Ack: 145, Len: 34
    425 11.403618   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 425: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4295 (4295), Dst Port: smtp (25), Seq: 145, Ack: 95, Len: 6
    426 11.404138   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 426: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4295 (4295), Seq: 95, Ack: 151, Len: 13
    438 11.420394   192.168.0.5           192.168.0.60          SMTP     S: 220 mx.mydomain.tld ESMTP
Frame 438: 78 bytes on wire (624 bits), 78 bytes captured (624 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4297 (4297), Seq: 1, Ack: 1, Len: 24
    439 11.420700   192.168.0.60          192.168.0.5           SMTP     C: HELO sr
Frame 439: 63 bytes on wire (504 bits), 63 bytes captured (504 bits)
Transmission Control Protocol, Src Port: 4297 (4297), Dst Port: smtp (25), Seq: 1, Ack: 25, Len: 9
    440 11.430684   192.168.0.5           192.168.0.60          SMTP     S: 250 Hello.
Frame 440: 66 bytes on wire (528 bits), 66 bytes captured (528 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4297 (4297), Seq: 25, Ack: 10, Len: 12
    441 11.430983   192.168.0.60          192.168.0.5           SMTP     C: MAIL FROM: <user1@mydomain.tld>
Frame 441: 83 bytes on wire (664 bits), 83 bytes captured (664 bits)
Transmission Control Protocol, Src Port: 4297 (4297), Dst Port: smtp (25), Seq: 10, Ack: 37, Len: 29
    442 11.432059   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 442: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4297 (4297), Seq: 37, Ack: 39, Len: 8
    443 11.432327   192.168.0.60          192.168.0.5           SMTP     C: RCPT TO: <user2@mydomain.tld>
Frame 443: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: 4297 (4297), Dst Port: smtp (25), Seq: 39, Ack: 45, Len: 28
    444 11.433264   192.168.0.5           192.168.0.60          SMTP     S: 250 OK
Frame 444: 62 bytes on wire (496 bits), 62 bytes captured (496 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4297 (4297), Seq: 45, Ack: 67, Len: 8
    445 11.433528   192.168.0.60          192.168.0.5           SMTP     C: DATA
Frame 445: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4297 (4297), Dst Port: smtp (25), Seq: 67, Ack: 53, Len: 6
    446 11.438484   192.168.0.5           192.168.0.60          SMTP     S: 354 OK, send.
Frame 446: 69 bytes on wire (552 bits), 69 bytes captured (552 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4297 (4297), Seq: 53, Ack: 73, Len: 15
    447 11.445013   192.168.0.60          192.168.0.5           IMF      from: <user1@mydomain.tld>, subject: Test subject,
Frame 447: 665 bytes on wire (5320 bits), 665 bytes captured (5320 bits)
Transmission Control Protocol, Src Port: 4297 (4297), Dst Port: smtp (25), Seq: 73, Ack: 68, Len: 611
    449 11.489196   192.168.0.5           192.168.0.60          SMTP     S: 250 Queued (0.015 seconds)
Frame 449: 82 bytes on wire (656 bits), 82 bytes captured (656 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4297 (4297), Seq: 68, Ack: 684, Len: 28
    450 11.490647   192.168.0.60          192.168.0.5           SMTP     C: QUIT
Frame 450: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
Transmission Control Protocol, Src Port: 4297 (4297), Dst Port: smtp (25), Seq: 684, Ack: 96, Len: 6
    452 11.491152   192.168.0.5           192.168.0.60          SMTP     S: 221 goodbye
Frame 452: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
Transmission Control Protocol, Src Port: smtp (25), Dst Port: 4297 (4297), Seq: 96, Ack: 690, Len: 13
mfields
Post by mfields » 2019-06-20 11:06
2019-06-19 20:37
That was an error - I have re-ran the test without that line of code and still the same results.
2019-06-20 03:20
I'm not too sure what to be looking out for, but that looks fine to me.
I ran a Wireshark trace while performing the test after removing the redundant "Dim NewMail" line.
While I'm not 100% sure on how to analyse the data and come to any conclusions, here is a PDF output of a TCP conversation which includes some mangled data, "RCPT TO: <X"\273%\033\002>": https://www.dropbox.com/s/8zwps1ngl2ra1 ... e.pdf?dl=0
Post by jimimaseye » 2019-06-20 12:27
No. Time Source Destination Protocol Length Info
4447 08:42:08.075544 127.0.0.1 127.0.0.1 SMTP 73 C: RCPT TO: <X"\273%\033\002>
Yep. Pretty conclusive. The error is coming from the client (CDO in this case).
tunis
Post by tunis » 2019-06-20 14:00
I have test with this script.
Set objMsg      = CreateObject("CDO.Message")
objMsg.Subject  = "CDO TEST MESSAGE" & vbTab & Now()
objMsg.Sender   = "test@test.local"
objMsg.To       = "test1@test.local; test2@test.local: test3@test.local; test4@test.local;"
objMsg.From     = "admin@tech.samobler.se"
objMsg.TextBody = "CDO TEST MESSAGE" & vbTab & Now()
objMsg.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
objMsg.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "192.168.1.111"
objMsg.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
objMsg.Configuration.Fields.Update
objMsg.Send
Wscript.Echo "DONE"
Wscript.Quit
And this gives error that SMTP-server sent: 550 A valid address is required.
And the hMail log shows this
"SMTPD"	564	116592	"2019-06-20 13:56:02.796"	"10.10.0.5"	"SENT: 220 mail.test.local ESMTP"
"SMTPD"	1856	116592	"2019-06-20 13:56:02.796"	"10.10.0.5"	"RECEIVED: HELO SAPC19801"
"SMTPD"	1856	116592	"2019-06-20 13:56:02.796"	"10.10.0.5"	"SENT: 250 Hello."
"SMTPD"	296	116592	"2019-06-20 13:56:02.796"	"10.10.0.5"	"RECEIVED: MAIL FROM: <test@test.local>"
"SMTPD"	296	116592	"2019-06-20 13:56:02.811"	"10.10.0.5"	"SENT: 250 OK"
"SMTPD"	564	116592	"2019-06-20 13:56:02.811"	"10.10.0.5"	"RECEIVED: RCPT TO: <test1@test.local>"
"SMTPD"	564	116592	"2019-06-20 13:56:02.811"	"10.10.0.5"	"SENT: 250 OK"
"SMTPD"	296	116592	"2019-06-20 13:56:02.811"	"10.10.0.5"	"RECEIVED: RCPT TO: <test4@test.local>"
"SMTPD"	296	116592	"2019-06-20 13:56:02.827"	"10.10.0.5"	"SENT: 250 OK"
"SMTPD"	1856	116592	"2019-06-20 13:56:02.827"	"10.10.0.5"	"RECEIVED: RCPT TO: <>"
"SMTPD"	1856	116592	"2019-06-20 13:56:02.827"	"10.10.0.5"	"SENT: 550 A valid address is required."
"SMTPD"	296	116592	"2019-06-20 13:56:02.842"	"10.10.0.5"	"RECEIVED: QUIT"
"SMTPD"	296	116592	"2019-06-20 13:56:02.842"	"10.10.0.5"	"SENT: 221 goodbye"
No messeges are sent or wrong TO address.
HMS 5.6.8 B2437.17 on Windows Server 2019 Core VM.
HMS 5.6.8 B2451.21 on Windows Server 2016 Core VM.
Post by SorenR » 2019-06-20 14:05
mfields wrote:
2019-06-20 11:06
2019-06-19 20:37
2019-06-20 03:20
Try this code...
Private Sub testEmail( emailto )
    Dim oMatch, oMatches
        .Pattern = "(([a-zA-Z0-9_\-\.]+)\@([a-zA-Z0-9_\-\.]+)\.([a-zA-Z]{2,5}))"
        .Global = True
        .MultiLine = True
        .IgnoreCase = True
        Set oMatches = .Execute(emailto)
    emailto = ""
    For Each oMatch In oMatches
        emailto = oMatch & ";" & emailto
    With CreateObject("CDO.Message")
        .Configuration.Fields.Item(             "http://schemas.microsoft.com/cdo/configuration/sendusing" ) = 2
        .Configuration.Fields.Item(            "http://schemas.microsoft.com/cdo/configuration/smtpserver" ) = "localhost"
        .Configuration.Fields.Item(        "http://schemas.microsoft.com/cdo/configuration/smtpserverport" ) = 25
        .Configuration.Fields.Item(      "http://schemas.microsoft.com/cdo/configuration/smtpauthenticate" ) = 0
        .Configuration.Fields.Item(               "http://schemas.microsoft.com/cdo/configuration/sendtls" ) = False
        .Configuration.Fields.Item(            "http://schemas.microsoft.com/cdo/configuration/smtpusessl" ) = False
        .Configuration.Fields.Item( "http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout" ) = 10
        .Configuration.Fields.Item(          "http://schemas.microsoft.com/cdo/configuration/sendusername" ) = "user@domain.tld"
        .Configuration.Fields.Item(          "http://schemas.microsoft.com/cdo/configuration/sendpassword" ) = "password"
        .From = "user@domin.tld"
        .To = emailto
        .TextBody = "Test body"
        .Send
    WScript.Echo( "eMail(s) sent to " & emailto & " at " & Now() )
Call testEmail(Request.QueryString( "emailto") )
This part
        .Global = True
        .MultiLine = True
        .IgnoreCase = True
    emailto = ""
The RegEx extract the email addresses from "emailto" without the separator and put them together afterwards with the proper separator.
One major flaw with CDO is the inability to configure a FQDN for the HELO greeting, CDO is using the stations NetBios name. RFC says HELO/EHLO greeting *must* contain FQDN or Domain Literal (IPAddress in square brackets).
