Rules processing (forward vs copy)
mmpfred
Post by mmpfred » 2019-06-15 01:18
This is the first time I am posting to this forum. Firstly, thank you for creating and maintaining hMailServer. It is a fantastic mail server.
I have the following scenarios:
I use Thunderbird as the mail client.
Two accounts are setup on Thunderbird:
1. Smtp account connected to an external mail provider
2. IMAP account connected to hMailserver (local server running Windows 10)
When Smtp account receives an email:
Scenario 1 - Message filter is setup to blindly "Copy" all message to hMailserver.
Scenario 2 - Message filter is setup to blindly "Forward" all message to hMailserver.
On the hMailserver, I created account rules to move the messages to different IMAP folder based on certain subject and who sent the email.
In scenario 1, the account rules did not work(I did not see any log in the log file) and messages were not moved.
Whereas in scenario 2, the rules were applied (it was indicated in the log).
Can any one confirm if account rules are NOT supposed to run in scenario 1?
Please let me know if I am not making sense or this is not the right platform for this question.
thank you.
Re: Rules processing (forward vs copy)
Post by jimimaseye » 2019-06-15 06:57
run this and post the results: https://www.hmailserver.com/forum/viewt ... 0&t=30914- include RULES when prompted.
mmpfred
Post by mmpfred » 2019-06-15 07:43
2019-06-15   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - mmxxxxxxxxxxx.com              Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
GLOBAL RULES
ACCOUNT RULES for sales@Domain1.com:
  1, BestDealForwardToAccounting  Criteria:  Use AND
             From                      Contains        bdprint.ca
             Subject                   Contains        invoice
                                  -----Actions-----
             Forward                                   accounting@Domain1.com
  2, Quote Request                Criteria:  Use AND
             Subject                   Contains        Re: quote request
             Subject                   Not Contains    ORDER
                                  -----Actions-----
             Move To Folder                            INBOX.Vendors.Quotes
  3, FactorFormQuote              Criteria:  Use AND
             From                      Contains        factorforms.com
             Subject                   Contains        Quote
                                  -----Actions-----
IP RANGES
     POP3:   True !! Protocol DISABLED !!      Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
There is a total of 6 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
Max Msg Size: 40960  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
                     Port: 465                                           Loop limit:           5
                     Con. Sec.: SSL/TLS
  Routes:
     No routes defined.
POP3
 !! Service Not Enabled !!
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 3    Use Spamassassin:   False
  Add X-HmailServer-Spam:     True    Check HELO host:    True - 2
  Add X-HmailServer-Reason:   True    Check MX records:   True - 2
  Add X-HmailServer-Subject:  True    Verify DKIM:        True - 5
              Subject Text: "[SPAM]"
DNSBL ENTRIES:
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:   True       Defer mins: 30       Days Unused: 1      Days Used: 36
                            Bypass SPF: True     Bypass A/MX: False
Greylist WHITELIST ENTRIES:
   No entries
Greylist DOMAINS enabled:
  !! No active domains enabled - GREYLISTING INEFFECTIVE !!
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   mmpw
       Certificate: C:\\Program Files (x86)\\hMailServer\\Certs\\certificate.crt
       Private key: C:\\Program Files (x86)\\hMailServer\\Certs\\privateKey.key
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: mmpw
               0.0.0.0         / 587   / IMAP   -   SSL/TLS             Cert: mmpw
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: mmpw
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-06-15.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-06-15.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: PostgreSQL
HMAILSERVER.INI
Database folder:
Type=              PostgreSQL
Username=          postgres
Port=              5432
Server=            localhost
Internal=          0
Post by mattg » 2019-06-16 01:09
mmpfred wrote:
2019-06-15 01:18
So how is the SMTP account connected to hMailserver? How is hMailserver getting this mail? Via a thunderbiord rule?
mmpfred wrote:
2019-06-15 01:18
Why are you setting account rules on hmailserver?
But, Aren't you copying the message using thunderbird rules?
I'm really lost.
Why don't you ALSO use hmailserver's external account to download mail from the SMTP server, and then run your rules in hMailserver
mmpfred
Post by mmpfred » 2019-06-17 04:39
2019-06-16 01:09
Correct. All emails are Forwarded (Scenario 1) or Copied (Scenario 2) to hMailServer via Thunderbird message filters.
2019-06-16 01:09
I'm really lost.
Sorry...that is because I haven't given you any explanation.
I inherited this setup from my predecessor. My PC (so as other people in the organization) is currently receiving email from the service provider via POP3. There is no server, just a bunch of PCs in a workgroup.
I setup hMailServer in hope to move the emails to the server. Once hMailServer goes live, the POP3 access will be terminated (for all PCs) and hMailServer will receive all eMails and everyone will connect to hMailServer via IMAP.
As part of the test phase (and pre-populate hMailServer), emails are copied to hMailServer via Thunderbird message filters. Rules are setup on the hMailServer to move email around so that they are a bit more organized.
I was not able to get the rules to move the emails around until I changed the Thrunderbird filter to 'Forward' email to hMailServer.
2019-06-16 01:09
I didn't think of that option and I don't know how to do that. Can I do that via POP3? Would you provide some instructions please?
I can access the email from my service provider via either POP3 or IMAP. My predecessor had huge problem with IMAP previously so I am not willing to risk anything at the moment.
Thank you for your help.
Post by mattg » 2019-06-17 05:03
Each account on hMailserver has an External accounts tab
https://www.hmailserver.com/documentati ... al_account
mmpfred
Post by mmpfred » 2019-06-17 17:21
Thank you! mattg.
I will work on that this week.
mmpfred
Post by mmpfred » 2019-06-24 03:37
Everything is good. Thank you for your suggestion.
Post by mattg » 2019-06-24 04:34
Thanks for the post back
