Is there a way I can mask the sender email ID with a name
RDadmin
Post by RDadmin » 2019-06-13 04:08
Is there a way I can mask the sender email ID with a name?
For example:
All email sent from test@domain.com should be seen by the recepients as TestCompany.
Any and all suggestions are appreciated.
Re: Is there a way I can mask the sender email ID with a name
Post by mattg » 2019-06-13 10:19
This is set in your mail client
hMailserver cares little about what name you choose.
What mail client do you use?
RDadmin
Post by RDadmin » 2019-06-14 02:57
Hi Matt,
Thanks for the reply.
We are using hmailserver as an SMTP relay to send out email through a web app.
Basically this is done by our developers. I am on the IT side of the project.
Any thoughts?
Post by mattg » 2019-06-14 06:15
Get the web app to set this
You could do it with scripts in hMailserver if you are really stuck, but seriously this is pretty basic stuff for your web developers to get right.
What can you tell us about the app? What language is it written in? is it PHP or ASP or...
What library is used to send mail?
RDadmin
Post by RDadmin » 2019-06-17 08:27
Hi Matt,
Sorry for the delayed reply.
we are using asp.net. I will ask my web team to have a look at this and will come back here.
Thanks mate.
Pedja
Post by Pedja » 2019-06-17 09:53
Basicalz, thej jsut have to set From: field appropriately.
Example:
RDadmin
Post by RDadmin » 2019-06-19 01:04
Hi Pedja,
Thanks for your reply.
I didnt quite get what you said.
Could you please elaborate?
