my ip is getting auto ban several times in a day
kafuidarkey
Post by kafuidarkey » 2019-06-12 12:31
I have been using hmailserver for 3 years now and for the past days my ip address is getting auto -ban each day and i dont know what is causing it .Can any body suggest something i am not doing. i just updated spamassin but still..
kafui
Re: my ip is getting auto ban several times in a day
Post by mattg » 2019-06-12 13:11
Not related to SPamAssassin
If it is genuinely your IP address, I'd guess that you have a device with a dud password saved.
Create a new IP range for your IP address upper and lower IP, and set a priority to say 25 (Anything higher than 20) and it will ALWAYS override the Autoban settings
kafuidarkey
Post by kafuidarkey » 2019-06-12 13:39
2019-06-12 13:11
Please do you mean that p i need to change the password i am using to login into the hmailserver? . I do get Ip Auto-ban sexybaby@mydomain.com . Which is not even part of any of account on my hmailserver. .find attach picture of my ip range and advice.
thanks kafui
Post by jimimaseye » 2019-06-12 14:26
kafuidarkey
Post by kafuidarkey » 2019-06-12 16:42
2019-06-12   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - myxxxxxxx.com                  Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
GLOBAL RULES
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:    100
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  6 Mins: 60   Plain Text:         True  Bind:
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Subject: False    Verify DKIM:        True - 5    Use SA score:        True
DNSBL ENTRIES:
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:   True       Defer mins: 30       Days Unused: 1      Days Used: 36
                            Bypass SPF: True     Bypass A/MX: False
Greylist WHITELIST ENTRIES:
   No entries
Greylist DOMAINS enabled:
  !! No active domains enabled - GREYLISTING INEFFECTIVE !!
WHITELISTING
   No entries
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: False,  Notify Receiver: False
  Max Message Size: 0
     CLAM AV:   True   !!!! CONFLICT !!!!   !! MULTIPLE AV !!       Hostname: localhost    Port: 3310
     CLAMWIN:   True   !!!! CONFLICT !!!!   !! MULTIPLE AV !!       Executable: C:\Program Files (x86)\ClamWin\bin\clamscan.exe    Path: C:\ProgramData\.clamwin\db
     CUSTOMAV:  True   !! MULTIPLE AV !!       Executable:
                                               ReturnValue: 0
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-06-12.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-06-12.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\Backup\DataBackup\DataBackup is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by mattg » 2019-06-13 01:20
kafuidarkey wrote:
2019-06-12 13:39
No I don't mean that you need to change your password.
(You should always have strong passwords though)
What you describe with 'I do get Ip Auto-ban sexybaby@mydomain.com' is EXACTLY Autoban doing it's job
You Autoban settings are very lax. A hacker can try 100 times before they are autobanned. I normally allow 3. Also I normally block for far longer than an hour.
You said earlier 'and for the past days my ip address is getting auto -ban each day'
That doesn't appear to be the case when your screen shot was taken. There are no autobans then.
When you get an autoban, what IP address is it for? is it YOUR ip address
Post by palinka » 2019-06-13 02:57
2019-06-13 01:20
What is the IP address getting banned? WAN IP? LAN IP? Localhost? Mobile phone IP?
kafuidarkey
Post by kafuidarkey » 2019-06-13 10:33
2019-06-12 14:26
2019-06-13   Hmailserver: 5.6.7-B2425
DOMAINS
        Greylisting:     False
GLOBAL RULES
IP RANGES
    No entries
AUTOBAN
There is a total of 1 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
   No entries
WHITELISTING
   No entries
ANTIVIRUS
GENERAL:
  Max Message Size: 0
                                               ReturnValue: 0
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-06-13.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-06-13.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
kafuidarkey
Post by kafuidarkey » 2019-06-13 10:35
2019-06-13 02:57
2019-06-13 01:20
My WAN IP get banned
Post by palinka » 2019-06-13 12:14
kafuidarkey wrote:
2019-06-13 10:35
Users get banned. Create an IP range for your wan ip and set it to 25 (higher than autoban 20). The next time someone starts trying to guess user/pass, that user - nonexistent or otherwise - will get banned without affecting any other operations.
Also, as Matt said, change your autoban settings to 2 or 3 tries. Someone might actually guess a password in 100 tries.
Lastly, how in the heck is your wan ip even a factor here? Are you on a double nat? Do you see any activity from actual outside IPs?
kafuidarkey
Post by kafuidarkey » 2019-06-13 12:22
i am not on double Nat
kafuidarkey
Post by kafuidarkey » 2019-06-13 12:33
2019-06-13 12:14
kafuidarkey wrote:
2019-06-13 10:35
Find attach my configuration to see if it the correct thing i have done
Post by palinka » 2019-06-13 13:08
Looks good. But seeing the wan ip there is very strange. Can you look in your logs to see if ANY outside IP has ever contacted you? Or is it strictly your WAN IP and localhost? Are you in a DMZ?
kafuidarkey
Post by kafuidarkey » 2019-06-13 13:18
2019-06-13 13:08
I am not in DMZ
Post by palinka » 2019-06-13 13:21
Did you check your logs for outside IPs?
Post by mattg » 2019-06-13 13:53
My guess is that the WAN edge device (firewall / router / modem) is doing mail inspection, and creating this issue inadvertently
