(RULE) Only registered email addres can send email
leesauran
Post by leesauran » 2019-06-11 07:58
Dear All,
I need some help, i have bad user can change the name and mail address on outlook and the user send the bad things to other people.
can i protect with make some rule on hmail server only registered email addres can send email ?
or have another solution?
Regards
Jimmy
Re: (RULE) Only registered email addres can send email
Post by RvdH » 2019-06-11 08:22
leesauran
Post by leesauran » 2019-06-11 10:14
thanks , are u already tested and working ?
Post by palinka » 2019-06-11 11:50
Trust me, he wouldn't have posted it unless it's working.
You should enforce strong passwords even if you implement one if these scripts.
Post by mattg » 2019-06-11 14:05
There is also these couple of scripts >> viewtopic.php?p=68117#p68117
leesauran
Post by leesauran » 2019-06-12 06:52
Thanks Matt, i have tried form viewtopic.php?p=68117#p68117 and its works, i have tried the first code from https://vdhout.nl/2015/04/hmailserver-d ... ed-account its no working.
Post by RvdH » 2019-06-12 08:13
leesauran wrote:
2019-06-12 06:52
I call that BS, take a closer look,it is literally 99% the same code :lol: :lol:
The only reason why it should not work could be if very old version of hMailserver is used, one that doesn't support OnSMTPData Event trigger
