Not receiving mail
picho
Not receiving mail
Post by picho » 2019-06-07 08:27
Dear Team,
I am having trouble with my hmailserver,
Last week i had my domain hosting provider transferred to another host and since then, i have been receiving fewer mails than usual with many mails not being received by my email accounts.
I have restarted the server.
I now don't know what to do, how can i find out what is wrong with my system.
I will be glad for your assistance,
regards,
Picho
nitro
Re: Not receiving mail
Post by nitro » 2019-06-07 09:09
I would start with the simplest:
- Is it the same IP address?
- Can you make a telnet connection to port 25?
It is common for hosting providers to disable port 25.
Use this diagnostic tool.
https://mxtoolbox.com/diagnostic.aspx
picho
Post by picho » 2019-06-07 09:47
Thank u Nitro for your response.
I used the tool from the link and below are the results from the tool:
Test Result
SMTP Banner Check Reverse DNS does not match SMTP banner
SMTP TLS Warning - does not support TLS
SMTP Server Disconnected May be an open relay
SMTP Reverse DNS mismatch OK X.X.X.X resolves to X.X.X.X
SMTP Valid hostname Ok Reverse DNS is a valid hostname
it then says you hung up on us after we connected. Please whitelist us (connection lost)
what could be the problem ?
picho
Post by picho » 2019-06-07 09:51
when i run diagnostics on the hmailserver utility, it resolves perfectly to mail.hmailserver.com without any errors
nitro
Post by nitro » 2019-06-07 12:06
SMTP Banner Check Reverse DNS does not match SMTP banner <- Bad HELO
https://www.hmailserver.com/documentati ... elay_tests
My server:
SMTP Reverse DNS Mismatch OK - 1.1.1.1 resolves to mail.domain.es
SMTP Valid Hostname OK - Reverse DNS is a valid Hostname
SMTP Connection Time 0 seconds - Good on Connection time
SMTP Open Relay OK - Not an open relay.
It is important to know if the IP has changed.
If you have changed, you should analyze if the DNS is changed and if it has propagated correctly.
https://www.whatsmydns.net/
Post by palinka » 2019-06-07 12:59
nitro wrote:
2019-06-07 12:06
Not necessarily. I recently learned that PTR resolves to an FQDN that your ISP has assigned to you. Checking PTR wil tell you for sure. The fix is to ask your ISP to update their DNS to reflect your mx FQDN.
For example, I'm on a dynamic residential ip. I cannot ask my ISP to update anything because of that but it makes a good example despite that.
My helo banner: mail.domain.com
My mx record: mail.domain.com
My ip: 12.34.56.78
PTR checks IP which resolves to pool-12-34-56-78.nycmny.fios.verizon.net
No match.
Doesn't affect me because i use a relay and receiving servers check reverse dns against the relay and not my ip.
I hope i got all that right. :mrgreen:
nitro
Post by nitro » 2019-06-07 13:05
2019-06-07 12:59
nitro wrote:
2019-06-07 12:06
My ip: 12.34.56.78
No match.
For my server +2 in the spam score :twisted:
Post by palinka » 2019-06-07 13:36
nitro wrote:
2019-06-07 13:05
Me too. Plus i noticed that a lot of bot spam comes in on residential IPs with FQDN in helo as i showed for mine. They pass reverse DNS check. So i check helo for IP matches within the helo. If there's a match, i reject. "Real" mail servers don't have helo banners that look like a residential ip PTR. :mrgreen:
picho
Post by picho » 2019-06-07 18:11
Hi Nitro i ran the diagnostic test using DNSGoodies.com the open relay test is taking too long, what should i do to configure on my hmailserver
picho
actually the open relay test aborted
Post by mattg » 2019-06-09 01:23
picho wrote:
2019-06-07 09:47
Test Result
Enable all logging in hMailserver and repeat the above test, and the show ALL logs created, and the exact (screen shot) error message that you receive.
Also show the results of these diagnostics >> viewtopic.php?f=20&t=30914
picho
Post by picho » 2019-06-10 11:47
thank you members for all your support,
i realised the culprit was auto ban, because of attempts by spammers to hijack our systems, hmail would trigger autoban after 3 failed logon attempts and it would autoban our gateway ip address and so that kept us from receiving mail until the ban would be lifted and soon after it would autoban again.
so what i did, i disabled autoban, i have also configured antispam settings on our firewall to handle spam coming into our network, also i have enabled intrusion protection and intrusion detection.
My system is running smoothly, what a relief for me, i almost gave up on hmailserver :P :D :D :D
Post by mattg » 2019-06-10 12:34
Why your gateway IP address?
It obviously isn't NATting, and is likely doing some mail inspection.
This also means that you probably can't do SSL or StartTLS connections
There may be a security issue there (despite the intent).
picho
Post by picho » 2019-06-10 13:26
yes my gateway ip address is on the firewall and it does mail inspection, intrusion detection
Post by mattg » 2019-06-10 23:35
2019-06-10 12:34
