Mail blocked by Spamhaus
Technoman
Post by Technoman » 2019-06-04 08:08
   Sent: Tue, 4 Jun 2019 01:41:32 -0400
   Subject: testing
person@hotmail.com
   Error Type: SMTP
   Remote server (x.x.x.x) issued an error.
   hMailServer sent: MAIL FROM:<mail@mydomain.com>
   Remote server replied: 550 5.7.1 Service unavailable, Client host x.x.x.x] blocked using Spamhaus. To request removal from this list see https://www.spamhaus.org/query/ip/[x.x.x.x] (AS3130). [HE1EUR02FT004.eop-EUR02.prod.protection.outlook.com]
hMailServer
Only when i send email to HOTMAIL
How do i disable spamhaus? I never even enabled it. :roll:
johang
Re: Mail blocked by Spamhaus
Post by johang » 2019-06-04 10:07
not sure if the Rolling Eyes means you are sarcastic about your own post or something else
yes i wouldnt like to be registered with spamhaus either ...
have you tried the link ? have you asked the provider of IP and other related services you use to get out of spamhaus listing .. ?
/j
Post by palinka » 2019-06-04 11:12
Technoman wrote:
2019-06-04 08:08
If you sent mail to me you would be blocked AND receive a more generic message that wouldn't explain why you were blocked. Hotmail really did you a favor by telling you the exact reason why.
You can't "disable" spamhaus. It's a blacklist of IPs reported to have sent spam. Administrators chose to use spamhaus or not. Hotmail does, i do too. It's very effective. I haven't received any complaints about false positives since i started using it to reject mail (only 2 months ago).
If you're not a spammer, it's likely one of your account passwords was guessed and used to send spam. OR, your IP is blocked by PBL which is a function of your ISP policy. For example, my IP is in the PBL because I'm on a dynamic IP range and my ISP reported to spamhouse that my range should not be sending mail. It doesn't affect me because they also block port 25 and I'm forced to use a relay. My relay is not affected so mail goes through. But you get the point.
You can try to delist yourself from the PBL, but i wouldn't do anything until you know for sure that any compromised accounts have been fixed and you are definitely NOT sending any spam.
Post by SorenR » 2019-06-04 13:12
2019-06-04 11:12
Technoman wrote:
2019-06-04 08:08
You can ask Spamhaus to remove you from the PBL if you subscribe to "fixed IP" with your provider. I did ... and I'm gone :mrgreen:
Post by palinka » 2019-06-04 13:33
2019-06-04 13:12
I would, but I'm too cheap. The relay is less expensive than a static IP. Plus, they get to deal with reputational issues instead of me. :mrgreen:
Post by RvdH » 2019-06-04 14:44
2019-06-04 13:12
ditto
Technoman
Post by Technoman » 2019-06-04 20:15
Thanks guys for the answers!
I will contact them and see where it goes from there. No I have never spammed or done anything wrong with my IP so it must of been the person who had it before i assume.
Technoman
Post by Technoman » 2019-06-04 21:15
https://www.abuseat.org/lookup.cgi Removal of x.x.x.x completed
https://www.spamhaus.org/pbl/removal/verify/ Removal Control: Request Accepted
Blocklist Lookup Results
x.x.x.x is not listed in the SBL
x.x.x.x is not listed in the PBL
x.x.x.x is not listed in the XBL
finally sorted above out
The only thing left is "If you are the administrator of the IP block of your mail server, simply change the DNS zone records in such a way that the rDNS query responds properly."
https://spfbl.net/en/rdns/ Anyone here has done this and if so how to do with cloudflare? Remember im using a windows server.
Post by palinka » 2019-06-05 11:56
Technoman wrote:
2019-06-04 21:15
Just make sure hmailserver settings > protocols > smtp > welcome message matches your mx record - mail.yourdomain.com or whatever your mx is.
nitro
Post by nitro » 2019-06-05 12:56
I think it refers to the inverse resolution of the DNS, except for some cloud services, if you use a physical server on a fixed ip, you must request your internet provider to associate your ip with a name in such a way that:
1.1.1.1 = mail.domain.com
and
mail.domain.com = 1.1.1.1
Post by SorenR » 2019-06-05 13:06
nitro wrote:
2019-06-05 12:56
and
FQDN (Fully Qualified Domain Name) => mail.domain.com
FCRDNS (Forward Confirmed Reverse DNS) => (A) mail.domain.com = (PTR) 1.1.1.1 = (A) mail.domain.com
Before (and according to RFC) the MX must reference an A record, but with the shortage of IP address it has been acceptable to reference a CNAME, unfortunately that will break FCRDNS and some hardcore sites will report as SPAM.
nitro
Post by nitro » 2019-06-05 13:30
In theory, in practice you will get a nice: :(
Error Type: SMTP
   Remote server (2.2.2.2) issued an error.
   hMailServer sent: RCPT TO: <user@domain.com>
   Remote server replied: 450 4.7.1 Client host rejected: can not find your hostname, [1.1.1.1]
Post by SorenR » 2019-06-05 14:45
Walter J. Savitch, An Introduction to the Art and Science of Programming (1984), wrote: .
In theory, there is no difference between theory and practice. But, in practice, there is.
My server is FCRDNS and also sending mail to e.g. "root@[1.1.1.1]" works if we assume 1.1.1.1 is the ptr of the FQDN that services my MX... :mrgreen:
Useful if hackers should kill the important DNS servers 8)
Post by palinka » 2019-06-05 23:01
hmmm... never looked at this before. I just ran ptr against my host name and since I'm on a dynamic residential IP, it returned some gibberish my ISP gives as my FQDN. I'm using a relay so a ptr check against them must work fine since I don't get bounced messages. Still so much to learn, apparently. :mrgreen:
Technoman
Post by Technoman » 2019-06-06 01:27
Alright i guess I am fine then guys since mail.mydomain.com points to IP in A record
johang
Post by johang » 2019-06-07 01:10
Technoman wrote:
2019-06-06 01:27
1st step. you point your mail.domain.com IN A X.X.X.X
2nd step you point emaildomain.com IN MX mail.domain.com
3rd step at operators get them to change dns that handles reverse ip to name to match your A record
( they put in Y/x.x.x.in-addr.arpa IN PTR mail.domain.com )
check here
https://mxtoolbox.com/ReverseLookup.aspx
IF you cant get them to change .. you have to think out of the box ..
and they have a provided PTR record ... ( some service providers havent set up PTR )
so the IP x.x.x.x you get from your provider translates to .. ( ex) rental.cloud-service.ip.provider.com ( what you get from your check with mxtoolbox )
then in your domain .. ADD : domain.com IN MX rental.cloud-service.ip.provider.com
( so you turn it around and let them decide the mailserversname due to their namestandars.. it will still work as intended for you )
Post by mattg » 2019-06-07 01:55
Technoman wrote:
2019-06-06 01:27
Except as shown elsewhere in your diagnostics, your server won't actually accept any external mail due to your IP range settings.
So every time a server tries to contact your server, your server just rejects the connection
Technoman
Post by Technoman » 2019-06-07 04:14
2019-06-07 01:55
Technoman wrote:
2019-06-06 01:27
Thanks for pointing that out, can you tell me by the diagonals what the problem is? I thought i had everything sorted out but i guess not :(
Post by mattg » 2019-06-07 06:39
2019-06-07 01:55
There is a 'default' button on the IP ranges page - pressing that will fix
Specifically you asking external mail to authenticate when sending to local recipients, and they can't (hence why they are 'external')
