hMailServer 5.7.0-B2428 x64 - Failed to create COM object `hMailServer.Application': Access is denied.
JensBanzhaf
Post by JensBanzhaf » 2019-05-24 15:37
I have installed hms 5.7.0-B2428 64Bit on Server 2016 and everything looks fine beside PHPWebAdmin.
I tried with PHP 5.6.40 and 7.1.29
PHP extension php_com_dotnet is enabled and com.allow_dcom is set to true
I gave permission for IIS_IUSRS, NetworkService, IWPD_2... (the user, under wich php-cgi Application pool is running) rights to the hMailServer DCOM for local start, local activation and local access.
When i try to access the PHPWebAdmin-Site, I will get this error:
This problem is often caused by DCOM permissions not being set.
Any help would be appreciated
Jens
Re: hMailServer 5.7.0-B2428 x64 - Failed to create COM object `hMailServer.Application': Access is denied.
Post by mattg » 2019-05-24 16:56
Add IUSR to the list of users that has dcom access
JensBanzhaf
Post by JensBanzhaf » 2019-05-28 15:51
Hi mattg,
did that but nothing changed.
Now the following Users/Groups have Start- and Activation-Rights (lokal): IUSR, SYSTEM, NETWORK-SERVICE, IWPG_..., IWPD_1...., IWPD_2..., Administrators, IIS_IUSRS, INTERACTIVE
Any further hint?
Jens
Post by mattg » 2019-05-28 16:37
That's one of @Dravions private builds
We should ask Dravion for help on this
JensBanzhaf
Post by JensBanzhaf » 2019-05-28 17:32
How to get help from him?
Post by Dravion » 2019-05-28 20:58
Its a General DCOM Permission thing.
Check the Docs, its all documented and step by step Guide avaiable to solve this issue
https://www.hmailserver.com/documentati ... ermissions
JensBanzhaf
Post by JensBanzhaf » 2019-07-11 06:46
Hi Dravion,
I did that. But nothing changed. Maybe I used a incomplete download for installation because the include_versioncheck.php was missing. I copied it from an old installtion and changed it manually.
Jens
Post by RvdH » 2019-07-14 18:10
If I remember right i had to give dcom the right permission for the iis application pool the website is running under, eg: Iis appool/apppoolname
Example:
iis apppool/defaultapppool
Iisuser permission, that was for iis 6.x and before
Iusr permission is only for classic application pools I believe
