SSL/TLS cert for multiple domains?
ras07
Post by ras07 » 2019-04-15 05:52
Do you need to have a multi-domain (SAN) cert if your hmailserver instance supports multiple email domains (and answers to multiple domain names in MX records)? I always assumed yes, and I've always had SAN certs. But I recently added a new domain to my mail server and forgot all about the certificate, and it doesn't appear to have caused any ill effects.
It seems odd that a mail client or an MTA wouldn't complain that a cert was issued to a domain other than what it thinks it's talking to.
Or is TLS support in SMTP (and IMAP) specifically designed to facilitate only encryption, and not authentication? (Although if that's the case, I'm not sure what the point would be for mail clients to complain when a cert expires - which they definitely do.)
Re: SSL/TLS cert for multiple domains?
Post by mattg » 2019-04-15 08:40
ras07 wrote:
2019-04-15 05:52
Correct
You need a cert that matches the 'local host name' in SMTP >> Delivery of email and that is it.
Ideally your domains should each point to the same FQDN as an MX record, and your RDNS should also match this
That's what Outlook365 and gmail both do for hosted domains
ras07
Post by ras07 » 2019-04-16 08:37
2019-04-15 08:40
ras07 wrote:
2019-04-15 05:52
Correct
Hmm, apparently this isn't correct for IMAP ... I imagine it's client-dependent, but at least one email client (Thunderbird) does authenticate the IMAP server. It complains if the IMAP server doesn't have a cert that matches the server name the client is configured for.
Example:
  • hMailServer instance handles mail for both example.com and myorg.org
  • Settings | Protocols | SMTP | Delivery of e-mail | local host name is set to mail.example.com
  • hMailServer is configured with a cert that only lists mail.example.com
  • Both mail.example.com and mail.myorg.org resolve to the hMailServer's IP address
  • User configures IMAP in Thunderbird so that Account Settings | Server Settings |Server Name is set to mail.myorg.org
  • User gets an Security Exception dialog box that says "Legitimate ... sites will not ask you to do this"
Getting a SAN cert that lists both mail.example.com and mail.myorg.org solves the problem.
Post by palinka » 2019-04-16 11:38
ras07 wrote:
2019-04-16 08:37
Example:
It's not "client dependent", it's server dependent. Why would you expect your client to receive mail if you configured it for the wrong address? You may as well put gmail instead of mail.myorg.com.
But yes, a SAN certificate will solve that issue.
ras07
Post by ras07 » 2019-04-16 20:26
2019-04-16 11:38
Well, no, it's client dependent. You can write software to do whatever you want, and if you want it to ignore cert ownership, you certainly can. I know of at least several that do; the one on my Android phone, for instance (that was how this whole conversation started; I added a new domain and forgot about the cert, and was surprised that everything was working). It leaves you open to a combination DNS cache poisoning/MITM attack.
Post by palinka » 2019-04-16 21:49
Alternatively, you could resolve your myorg.com mx to mail.example.com. Then you'd only need one certificate and all connections would be covered.
Your example only applies when you resolve mx records to multiple domains (mail.example.com AND mail.myorg.com), which is fine using SAN certificates. No problem. Having options is good. :D
Post by mattg » 2019-04-22 02:19
ras07 wrote:
2019-04-16 08:37
Which is why I said
2019-04-15 08:40
Thunderbird tries to guess domain names, and does then look for a matching cert to their guess.
autoconfigure stops the guessing, and defines the appropriate responses >> viewtopic.php?f=21&t=31549
