The connection to the database is not available.
vornik
Post by vornik » 2019-04-05 11:37
Hello. Im trying to get hmail server to work for the first time, but I got this error, when I tried to connect to localhost: "The connection to the database is not available. Please check the hmailServer error log for details.
My logs folder is empty.
Virinum
Re: The connection to the database is not available.
Post by Virinum » 2019-04-05 11:52
Which database do you use?
vornik
Post by vornik » 2019-04-05 12:01
I use built-in database engine (Microsoft SQL Compact)
Post by Dravion » 2019-04-05 22:12
In most cases its because the OLDEDB Provider for MS-SQL-Server CE isnt registered anymore.
Try a reinstall about your existing hMailServer Installation, this should do the trick.
