Sync of draft on android
gtsolid
Post by gtsolid » 2019-02-26 11:53
Hi everyone!
On my smartphone i'm using outlook official app for syncing the mail with my hmailserver.
Everything works great except timing.
I have to wait minutes even for syncing only few kB of material (example in draft folder). Do you have any suggestion?
Re: Sync of draft on android
Post by Dravion » 2019-02-26 12:34
Try a diffrent Android App for Imap and compare the Sync timing results. If the MS Outlook App for Android is slower as for example Googles builtin Mail App, check uninstall and reinstall theOutlook App and sync again. If its slow again, you should lookup the Microsoft Forum for Users with the same Problem and check in Android Playstore for Users with same Issues.
