Am I paying AWS to let people try and hack my server?
bigted
Post by bigted » 2019-01-03 11:42
I use AWS to host hMailServer exclusively and at the begining (post honeymoon) the charges were around $10 a month.
These have been creeping up and currenly run at $18 a month.
I'm looking at the growing list of AutoBans on the server (~50) and I'm thinking "am I paying for these hackers to attempt to login?"
So I started to think I should use the AWS network rules to stop them before they get to the server.
So I thought I could restrict SMTP Auth to a certain port then configure my clients to use this port, I was hoping to then restrict AWS to only allow connections on this SMPT Auth port from my two IP addresses - but this is complicated by the mobile/cell phone working over 4G (or dipping in and out of WIFI) and being assigned different IP addresses.
Any one got any ideas?
Cheers
BigTed.
Re: Am I paying AWS to let people try and hack my server?
Post by Dravion » 2019-01-03 13:48
Youre rught.
The more traffic, the more your pay :lol:
Post by palinka » 2019-01-03 16:13
There are a few scripts in the scripting forum that automate putting the autoban list into windows firewall. Perhaps you can do the same with AWS?
insomniac2k2
Post by insomniac2k2 » 2019-01-03 17:41
I highly recommend using SorenR's showshoe logic with windows firewall ban scripting. I have at least 50,000 bans from this alone. Here is a snippet of the code that I use on my servers (Not all my code. Many deserve credit.):
Note that you will need to have a version of Hmailserver that supports OnHELO if you use my scripting the way it is. But im sure that you can just do the same from OnClientConnect as well.
Sub OnHELO(oClient)
	If(Left(oClient.IPAddress, 8) = "127.0.0.") Then Exit Sub ' Webmail should not process
	Dim oRegEx
	oRegEx.IgnoreCase = True
	oRegEx.Global = False
	oRegEx.Pattern = "^(User)$|^(ylmf-pc)$|^(Welcome-PC)$|^(THP-PC)$|^(Administrator)$|^(localhost\.localdomain)$|^(127\.0\.0\.1)$"
	If oRegEx.Test(oClient.HELO) Then Call AutoBan(oClient.IPAddress, oClient.HELO, 2, "d")
	Set oRegEx = Nothing
   ' SnowShoe SPAM detection
      Result.Value = 2
      Result.Message = "5.7.1 CODE01 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
	Dim objShell
	Dim objExec
	Dim strPSResults
	Dim ip
	ClientIp				= oClient.IpAddress			'Connecting remote IP address
	' Add to firewall rule
		' Create shell object
		Set objShell = CreateObject("Wscript.Shell")
		' Execute the combined command
		Set objExec = objShell.Exec("powershell -windowstyle hidden -command (Get-NetFirewallRule -DisplayName Hmailblock | Get-NetFirewallAddressFilter ).RemoteAddress")
		' Read output into VBS variable
		strPSResults = objExec.StdOut.ReadAll
		ip = ClientIP
		' Replace in output powershell
		strPSResults = Replace(strPSResults, chr(13), ",",1,1000)
		strPSResults = Replace(strPSResults, chr(10), "",1,1000)
		' Add detected ip to output powershell
		ip = strPSResults + ip
		' Send old ip's and new ip to Firewall Rule
		Set objExec = objShell.Exec("powershell -windowstyle hidden -command Set-NetFirewallRule -DisplayName Hmailblock -RemoteAddress"&" "&ip)
		Set objShell = Nothing
		' End Add to firewall
	EventLog.Write("SnowShoeBAN: " & ClientIp & "")
		.Run """C:\Program Files (x86)\hMailServer\Events\Disconnect.exe"" " & ClientIp & "", 0, True 'optional
      Exit Sub
Function IsSnowShoe(strIP) : IsSnowShoe = False
   Dim a
   a = Split(strIP, ".")
      strIP = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".sbl.spamhaus.org")
   If (strIP = "127.0.0.3") Then IsSnowShoe = True
Give it a week, and your servers will never talk to the spammers again :)
Post by mattg » 2019-01-03 23:56
bigted wrote:
2019-01-03 11:42
In your hMaislerver.ini
at the bottom add
[settings]
DisableAUTHList=25
Keep port 25 open, just don't all any AUTH on that port
Change your clients to use port 587 (submission via StartTLS)
What are your AutoBan Settings?
I currently have around 170, but mine goes as high as 400, but I only Autoban for a week (and I Autoban via a script for any overseas access via POP or IMAP and more) Someone the other day said that they had thousands of Autoban Entries
insomniac2k2
Post by insomniac2k2 » 2019-01-04 02:30
I used to have 40000 per serveruntil I purged them and moved bans to to windows firewall. While hmail seemed OK with this many bans, the client did not like to enumerate and crashed a lot towards the end. Banning at the server level drastically reduced the load and traffic on hmail.
bigted
Post by bigted » 2019-01-04 10:59
Thanks for the suggestions.
I had a quick look to see if there was some sort of API for AWS console but couldn't turn up anything promising.
I found some reference to "AWS WAF by Using AWS Lambda" but this looked like I'd end up buying more appliances from AWS and was really all about websites.
My AutoBan settings are 1,3600,3600 at the moment - I did wonder how big and integer variable was behind the ban times the other day.
I'll have a go with port 25/587 setup as well.
I was also thinking about writing the banned IPs out to a file so I could look for duplication over time - and manually add these into the AWS setup.
Cheers
BigTed
PS Thanks Matt for this software - I gave a donation via PayPal yesterday.
Post by SorenR » 2019-01-04 11:03
I have found that "shoot first, ask questions later" is not good with banning. A huge "banning list" on a small server really kills performance.
Sooo many "attacks" are 1-2 attempts every 8-12 hours so I have my banning set up differentiated.
- SnowShoe SPAM is only rejected as I only see recurring connects from same IP 1-2 times a week.
- 4-letter TLD's I ban instantly. 99% is SPAM anyways in my part of the world.
- Non-compliant HELO/EHLO greetings are rejected. Not very frequent anyways. Usually bots trying first EHLO, then HELO and never seen again.
- Like Matt I also only allow client connections from a limited geographic region. Attempts are banned for 7 days when registered 3 times in a 3 hour window.
- I also have an IDS system where ANY SMTP traffic not resulting in an email is banned for 7 days when registered 3 times in a 3 hour window.
- I have found that a 20 second delay of SMTP traffic in Sub OnClientConnect(oClient), Sub OnHELO(oClient) and Sub OnSMTPData(oClient, oMessage) have eliminated to need for GreyListing completely.
As from other posts here it is obviousthat there is no "default set of rules" to combat SPAM and BOT's. The best way is to spend a month or so monitoring the server - add a lot of "EventLog.Write" to log events and build your defence from there :mrgreen:
Post by mattg » 2019-01-04 23:36
bigted wrote:
2019-01-04 10:59
Just for the record, Martin is the owner / developer of hMailserver. I'm sure that he will appreciate the donation - thanks
2019-01-04 11:03
+1
bigted wrote:
2019-01-04 10:59
I'd probably make the 1 into a 2 or 3
My Autoban settings are 3,30,10080 (10080 is 7 days) but it rarely gets triggered. I mostly ban for X days using scripts.
insomniac2k2
Post by insomniac2k2 » 2019-01-05 00:06
2019-01-04 11:03
I definitely did experience this in the end by using Hmailserver bans. Although, now that I switched bans to my firewall, my servers are screaming fast and much less busy
2019-01-04 11:03
Man I wish that was the case for me. I think my companies are on every spam list world wide! I see constant contact from the same IP's all day long
2019-01-04 11:03
This one didn't work well for me in the past. I'll have to try it now after I have all my firewall bans up. I really wanted this one to work for me.
2019-01-04 11:03
Couldn't agree more on that one!
Post by SorenR » 2019-01-05 16:37
insomniac2k2 wrote:
2019-01-05 00:06
2019-01-04 11:03
2019-01-04 11:03
2019-01-04 11:03
2019-01-04 11:03
Ah, well I only host one public domain (5 users) and my fake "acme.inc" domain so that's why numbers are low. Also I have been actively fighting SPAM for a very long time so I am probably taken off of a few lists for being "a black hole" and/or a "slow responder".
Anything that affects their distribution speed is costing them money. :mrgreen:
