Error Type: SMTP 'Connection to recipients server failed'
kientv
Post by kientv » 2018-08-15 15:26
I'm still can not send email to external domain. :( (Port 25 is not blocked, firewall & antispam, antivirus was turn off)
Sent: Wed, 15 Aug 2018 19:39:44 +0700
Subject: Chúc thành công.
kientv@sieuthiquakho.com
Error Type: SMTP
Connection to recipients server failed.
Error: Host name: 65.154.166.203, message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Tried 6 time(s)
hMailServer
This is my diagnostics information:
2018-08-15   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - vixxxxxxxxx.com.vn             Enabled: True
      |- "Alias1.com" - wwx.vixxxxxxxxx.com.vn
  Enabled: True    Max size:            51200   Enabled: False
  IF NONE          Max message size:     1024                      Plus addressing: False
  Replies:  True   Max size of accounts: 1024
  Local:   False                                                   Greylisting:     False
RULES
IP RANGES
     POP3:   True                              Antivirus:  False
     External To External - False
IP: 0.0.0.0 - 255.255.255.255     Priority: 10     Name: Custom
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "EXTERNAL.TLD"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      5
INCOMING RELAYS
   No entries
MIRRORING         kientranvan@gmxxx.com
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  5 Mins:  5   Plain Text:         True  Bind: 127.0.0.1
                     (none entered)            Disc. on invalid:  False  Delivered-To hdr:  True
        Loop limit:           5
        Recipient hosts:     15
  Routes:
    Domain1.com              - S: Local   R: Local  - Addr: All         !! TARGET RESOLVES TO SELF !!
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 3    Use Spamassassin:   False
  Add X-HmailServer-Spam:    False    Check HELO host:    True - 2
  Add X-HmailServer-Reason:  False    Check MX records:   True - 2
  Add X-HmailServer-Subject: False    Verify DKIM:        True - 5
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
             TLS 1.2 :   True                Verify Remote SSL/TLS Certs:  False
SslCipherList  :
  Paths:-
    Current:  C:\Program Files\hMailServer\Logs\hmailserver_2018-08-15.log
    Error:    C:\Program Files\hMailServer\Logs\ERROR_hmailserver_2018-08-15.log
    Event:    C:\Program Files\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  C:\Program Files\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
IPv6 support is not available in operating system.
Backup directory C:\Inetpub\vinaconsult_mail_bk is writable.
HMAILSERVER.INI
Program folder:  C:\Program Files\hMailServer\
Database folder: C:\Program Files\hMailServer\Database
Data folder:     C:\Program Files\hMailServer\Data
Log folder:      C:\Program Files\hMailServer\Logs
Temp folder:     C:\Program Files\hMailServer\Temp
Event folder:    C:\Program Files\hMailServer\Events
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v1.92, Hmailserver Forum.
murdoch201
Re: Error Type: SMTP 'Connection to recipients server failed'
Post by murdoch201 » 2018-08-15 18:34
Not sure whether the domain mentioned is the one in question, but if it is: port 25 is definitely not responding.
Incase it's not: some ISPs block outgoing connections on port 25 aswell (something to keep in mind)
Post by palinka » 2018-08-15 21:32
Routes:
Is the sender of your example email "Domain1.com" - vixxxxxxxxx.com.vn?
kientv
Post by kientv » 2018-08-16 05:04
Yes, Target server name in my route is mail.vinaconsult.com.vn (this is smtp & pop server)
Post by jimimaseye » 2018-08-16 08:54
1, So you have a route pointing to your own server?! Remove that route.
2, Also, your system is an open spambot (if it gets attacked).:
ENABLE AUTHNTICATION on you 'Internet' ip range for all of the above shown (omitting 'External to Local'). And delete the duplicate 'Custom' range.
3, And remove the DEFAULT DOMAIN. (Why have you set it? And why set it as something you are not?!)
4, and this is pointless:
May I ask, what is the purpose of this mailserver? Is it for sending out marketing and advertising?
kientv
Post by kientv » 2018-08-16 09:32
I only want to setup a email server for business. (not for email marketing or ads)
I don't understand this point. can you take a screenshot?.
kientv
Post by kientv » 2018-08-16 10:29
2018-08-16   Hmailserver: 5.6.7-B2425
DOMAINS
IP RANGES
     External To Local    -  True           !! External To Local    -  True !!
       !! EXTERNAL INBOUND ON SUB IP RANGES OR EXTERNAL DOWNLOADS ONLY !!
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files\hMailServer\Logs\hmailserver_2018-08-16.log
    Error:    C:\Program Files\hMailServer\Logs\ERROR_hmailserver_2018-08-16.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by jimimaseye » 2018-08-16 11:13
This is wrong. See the warning. I explained to you in my previous post what to do. (Unless you are only collecting incoming email by pop3 external download)
Remove it on Smtp protocol. (Settings).
Enable Application logging (and Disable imap and pop3 logging), attempt to send an email, wait 1 minute and post the resultant log.
kientv
Post by kientv » 2018-08-16 20:27
Error Type: SMTP
Tried 6 time(s)
Please help me take a look:
2018-08-17   Hmailserver: 5.6.7-B2425
DOMAINS
IP RANGES
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files\hMailServer\Logs\hmailserver_2018-08-17.log
    Error:    C:\Program Files\hMailServer\Logs\ERROR_hmailserver_2018-08-17.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by jimimaseye » 2018-08-16 21:30
Remove the bind entry. And do as i said previously.
kientv
Post by kientv » 2018-08-16 21:56
Thanks @jimimaseye and others
Now I can received and sent my email to external from hmailserver successfully.
These are something that I do with hmailserver:
1. Remove default domain on settings/advanced.
2. Remove bind entry.
3. Remove routes.
4. Update 'Internet IP Range'.
5. Remove SMTP relayer
6. Set local host name is root domain (not subdomain)
7. Remove alias domain ( www.example.com)
