How to run three or more instances of hMailServer/different fqdn in HELO. How to?
Borizz.K
Post by Borizz.K » 2018-08-07 13:39
I have 3 domains.
I need to servicing mail for each domain on one virtual machine, bind each domain to a different ip-adressess and each domain used a personal fqdn in HELO when sending messages to outside world.
May be to run 3 instances of hmailserver?
How to?
ThanX
Re: How to run three or more instances of hMailServer/different fqdn in HELO. How to?
Post by jimimaseye » 2018-08-07 17:38
Nope.
You may do as all the mainstream mail providers do and have a single no-personalised host/ip address for SMTP with all PTR etc records pointing to this independant address. (ie even site hosted by Gmail still have 'google' addresses as their address).
If you require 3 instances of Hmailserver because the above is for some reason not suitable then you will need 3 separate VM's running (or a different choice of software).
Borizz.K
Post by Borizz.K » 2018-08-07 21:19
Thanx
what free mail server for Windows can do this?
Post by RvdH » 2018-08-07 22:24
Why do you think you need that functionality/ability?
As long as PTR and all in place and correct it doesn't matter how the server identifies itself.
I usually make simply make CNAME records to mail.something.com to mail.realdeal.com
Post by SorenR » 2018-08-07 22:40
2018-08-07 22:24
Because when one is SPAMlisted, the others are too... You have to get your black hat on when looking at some of these questions.
Either ppl don't know better or they have a different agenda :mrgreen:
Everyone is born good, bad is an acquired skill :twisted:
Post by jimimaseye » 2018-08-07 22:59
You dont only need 3 instances for that - 'blacklisting' will affect all 3 instances if they are still behind the same public IP address.
Post by mattg » 2018-08-07 23:34
2018-08-07 22:40
I think that is a skill that I have to learn...
I'm sure that I'd make more money
Post by SorenR » 2018-08-07 23:37
2018-08-07 23:34
2018-08-07 22:40
Not only that, you'll have more fun doing it :twisted:
Post by palinka » 2018-08-08 01:22
2018-08-07 22:40
Oh! That's not true at all! And that's all I have to say about the matter on this forum.
U-351
Post by U-351 » 2018-08-13 06:31
I have 3 working domain on 1 hmail instance.
Sewrver's A-record point to 1 IP
Each domain has MX record pointing to server's FQDN.
Server's FQDN has 1 PTR pointing to 1 server's IP.
3 instanse of hmail NOT NEEDed!!!
3 IP of hmail NOT NEEDed!!!
EXAMPLE RECORDS FOR DOMAINs:
servers.com:
mail A 123.1.2.3
domain1.com:
@ MX 10 mail.servers.com.
domain2.com:
domain3.com:
hMAil HELO String: "mail.servers.com".
Thats all! All working good!
