Mail Server not Listening Correctly
caleb.baker194
Post by caleb.baker194 » 2018-08-01 20:13
I cannot Get the hmail to receive mail. I attached a Picture of a trace file "PublicServerConfig" and that shows that it is not a firewall problem. The capture was taken on the machine running HMailServer. It says its "listening. listeners.png" shows the result of netstat -a and all the listed listeners are hmail. I can send out mail just fine so I know the service is running.
Test: Collect server details
Database type: PostgreSQL
Test: Test IPv6
Test: Test outbound port
Local address is 192.168.2.79.
Connected successfully.
Test: Test backup directory
Backup directory C:\Backup is writable.
Test: Test MX records
Trying to resolve MX records for smsmail.pittsburgfoundry.com...
Host name found: smsmail.pittsburgfoundry.com
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain smsmail.pittsburgfoundry.com...
Trying to connect to host smsmail.pittsburgfoundry.com...
Trying to connect to TCP/IP address 12.5.172.17 on port 25.
ERROR: Was not able to open connection.
Re: Mail Server not Listening Correctly
Post by jimimaseye » 2018-08-01 20:25
Question: is 12.5.172.17 your external IP address?
If NO: your DNS records are wrong and this is why nothing is connecting
IF YES: you have a firewall problem. Windows firewall, Router - incorrect routing, or ISP port blocking. OR you have misconfigured HMS. Please run this and post the results: viewtopic.php?f=20&t=30914
caleb.baker194
Post by caleb.baker194 » 2018-08-01 21:39
That is my external IP,
Windows Firewall is disabled. Its not a ISP firewall problem as this is a commercial internet connection.
2018-08-01   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - smxxxxx.pixxxxxxxxxxxxxx.com   Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
     POP3:   True                              Antivirus:  False
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins: 60   Plain Text:        False  Bind: 192.168.2.79
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2018-08-01.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2018-08-01.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
HMAILSERVER.INI
Database folder:
Type=              PostgreSQL
Username=          postgres
Port=              5432
Server=            127.0.0.1
Internal=          0
Generated by HMSSettingsDiagnostics v1.92, Hmailserver Forum.
Post by Dravion » 2018-08-01 22:06
The Error message means that the resolved DNS IP lookup was perormed correctly but the IP Address hMailServer has received durning the DNS MX lookup Query isnt routable on the internet.
Post by jimimaseye » 2018-08-01 22:15
caleb.baker194 wrote:
2018-08-01 21:39
So it is a block of port somewhere else because your server is uncontactable from wan side. However you look at it it is a routing error. Check your router forwarding.
P.s just because it's a commercial connection, don't assume they don't make mistakes or that port 25 INBOUND is open.
caleb.baker194
Post by caleb.baker194 » 2018-08-02 15:12
That's why i took the packet capture screen shot. It clearly shows the connection request from the external gmail on my computers network card. So my hardware is getting the request. how can it be a routing error if I see the packet?
Post by palinka » 2018-08-02 15:46
2018-08-01 22:15
I see from IP lookup that you have att for service. I Googled "att blocking port 25 static IP" and found many results with business accounts having port 25 blocked. You should call your ISP.
caleb.baker194
Post by caleb.baker194 » 2018-08-02 16:34
2018-08-02 15:46
This is what I get if I Stop the hmail service and launch a custom jetty server on port 25. with the hmail service running and the jetty server not running The test fails
EDIT:
Here is the same test with hmail running
caleb.baker194
Post by caleb.baker194 » 2018-08-02 17:20
2018-08-01 22:15
I would think that, But its just the hmail service. I can put other services in its place and they work fine On port 25
Post by palinka » 2018-08-02 17:43
A long shot: delete bind IP in SMTP settings.
Is any software firewall running? They often go with services rather than ports.
Post by jimimaseye » 2018-08-02 18:06
2018-08-02 17:43
Bind: 192.168.2.79
Ah yes. Good call. Remove the bind entry (unless you have multiple NICs you dont need to state it).
caleb.baker194
Post by caleb.baker194 » 2018-08-02 18:28
2018-08-02 17:43
Windows Defender had apparently blocked the service from running some time back. I had since then disabled windows defender but forget that It re-enables itself after some time. Thanks All so much for the help :mrgreen:
PS.
I also removed the bind Address but cant confirm weather or not that was a piece of it
Post by palinka » 2018-08-02 18:45
That'll do it.
Better to leave bind IP blank unless there a good reason for it. Could make other services looking for localhost:25 etc not find HMS if it only listens on the lan IP. Just another complication to sort out in future troubleshooting.
And windows firewall is trash. On my win 10 box I couldn't make an exception for RDC work AT ALL. Something buggy or broken. I finally gave up and tried a couple other software firewalls. They all have issues as far as I can tell.
Post by jimimaseye » 2018-08-02 23:26
2018-08-02 18:45
It worked here, though, didn't it. :mrgreen:
Post by palinka » 2018-08-02 23:33
2018-08-02 23:26
2018-08-02 18:45
It certainly did. It worked for me too. Kept me out completely!
Post by jimimaseye » 2018-08-02 23:44
2018-08-02 18:45
I certainly have windows firewall enabled and rdp forwarding on my server 2008 r2 without a problem.
Post by palinka » 2018-08-03 02:44
I have no idea why it didn't work but it was the only exception that didn't work. I goolaged it and nothing really came up, so either something got seriously messed up somewhere or I had a conflict. But I couldn't find anything so I have up and blamed Microsoft.
Post by palinka » 2018-08-03 09:35
Renewed interest led me to find an issue with group policy. Not sure why this wouldn't affect everyone since the default values were untouched. Anyway, I'll test next week. Leaving for a long weekend. :-)
