Static IP changed
gtsolid
Static IP changed
Post by gtsolid » 2018-04-08 17:16
my provider changed my IP address. Now, when i'm outside of office, i cannot enter into hmail using the new IP.
Maybe have i to change something in configuration?
i think port forwarding must be the same
Re: Static IP changed
Post by Dravion » 2018-04-08 18:03
Thats why u should use DNS Domain and Hostnames instead of IPs at all.
Post by mattg » 2018-04-09 00:06
Or perhaps your DNS records need to be updated
gtsolid
Post by gtsolid » 2018-04-09 08:42
Now i installed the client software who updates the IP continuosly. In my phone i'm using that DDNS name but it doesn't work. The ping is working.
i also changed the A record for my domain
Post by mattg » 2018-04-09 08:50
Does that DDNS service (which ever it is) handle MX records? Most don't
gtsolid
Post by gtsolid » 2018-04-09 08:59
how can i check? i only know the location of A record. MX record is provived by who?
Post by mattg » 2018-04-09 09:29
You will need to check with your DDNS service
Most online services don't lookup sub domains
Post by Dravion » 2018-04-09 09:43
A MX Record is a DNS-Entry which points to a A Record.It is required for other SMTP-Servers to find out which A Record is the correct Email Server for your DNS-Domain. Its only required for SMTP, not IMAP or POP3.
Typically your Dynamic DNS Provider should give you the option to setup a MX Entry in its Webinterface.
However:
Other SMTP-Server Providers like GMail or Hotmail will check if your IP-Address is Dynamic or not and if its not Static or if it is Blacklisted you will be blocked or rejected with a Errormessage in your hMailServer logs that Dynamic IP-Addresses for SMTP-Traffic is not allowed.
Solution:
Use a Thirdparty SMTP-Relayserver/Smarthost for your hMailServer as SMTP Proxy.
