Slowly working hmail server
assorti
Post by assorti » 2016-08-08 08:46
The server is installed Windows Server 2012 R2, Hmailserver 5.6.4-B2283.
On the server, 600 users created. When connecting 200 ( 100 pop3 and 100 IMAP) server users begins to slow down, go to the mailbox really is almost impossible and you have to restart the service.
Help me please.
on the distribution of the flow as follows:
На сервере созданы 600 пользователей. При подключении 200 (100 поп3 и 100 IMAP) пользователей сервер начинает тормозить, зайти в почтовый ящик очень практически невозможно и приходится перезапускать службу.
Re: Slowly working hmail server
Post by Dravion » 2016-08-08 09:29
Some ideas...
Easiest way to increase I/O speed is to use 3 diffrent SSD Harddrives:
SSD 1) for Windows (important for swapping)
SSD 2) for hMailServer and its Datadirectory
SSD 3) Database instance files
(regardles of MSSQL, MySQL, PostgreSQL) or install the SQL-Server on a diffrent computer on your local network. Also remember. A decent amount of memory (test it / use mem86+ test software) with 32 GBytes RAM or better) will speed up the OS in entirely.
Keep in mind:
Error in RAM chips can slow down and delay operations as well dramatically or can lead to crashes and unexpected restarts (for instance: i test the ram chips on every new server computer before start working with it because even brand new ram chips are often damaged).
Also use a good CPU like intel core i7/Xeon with a decent cooling system. DONT overclock shit, your server is not a Gaming system).
The next thing is your local network. Ask some electrician with proper network testing equipment about collisions and failures on the Ethernet layer in you local network and fix/replace crapoy cables, network cards and routers and switches if needed, this can boost your internal network speed enormously.
The other options out there are to recompile OpenSSL libs with NI-AES Hardware acceleration support to increase encryption/decryption speed of hMailServer in general and set any possible Compiler/Linker performance optimization flags like SIMD and AVX instructionset and profile guided instrumentation. Make at least sure you have enabled NI-AES Hardware acceleration with the openssl configure script.
You also should install the latest avaiable, stable drivers for your Mainboard, Networkcard and even your Audio and Graphiccards because a bad Audiodriver for example can occupy 100% cpu processing time (or simply disable audio, printer and other not needed drivers on your hMailServer Computer).
Take a look into taskmanager which processes occupy the most of processing time and if possible kill them, disable unneded services and background processes like Adobe ipdater ect.
Install all avaiable Updates and servicepacks.
Make also sure that your network/hMailServer
computer isnt affected from outside DOS/DDOS traffic and if possible buy a cheap CISCO Hardware appliance (arround 300$)to filter out the dirt or use a diffrent linux computed to filter incomning, not Email related tcp/udp/icmp packers in the first place.
assorti
Post by assorti » 2016-08-08 09:45
Good afternoon.
On the server, set Xeon E5-2620 2.1 GHz
RAM 16 GB
RAID Stripe.
MySQL 5.5
Like a powerful server. Why else, he can be very long handles requests?
Post by Dravion » 2016-08-08 10:08
Hmm if this is your hMailServer computer its verry strange because MySQL and hMailServer doesnt do heavy work and 14% overall usage is not verry much..
Can you do some isolated testing?
1)
Grab one of the client computers/laptops with poor Inbox performance and connect it directly with a Ethernet cable to the Switch where your server is connected.
2)
Report back your findings with screenshot/logs
assorti
Post by assorti » 2016-08-08 10:37
We have all of the computers connected to the same network to the mail server.
I took the video. Look.
https://youtu.be/fwcmTbgJ7yw
Add another 16 GB of memory. Total 32. =)
Post by Dravion » 2016-08-08 11:38
Ok, i think now its clear.
Its not an
Windows,
hMailServer,
MySQL-Server,
Network,
Hardware
Problem at all.
Its simply Roundcube (i had some verry similar problems with it and now using Rainloop Webmail
and verry happy with it).
Just for testing.Can you connect to hMailServer with Thunderbird and/or Outlook or booth
just to nail it? Report back if you checked you EMail on hMailServer with Thunderbird, i bet its lightning fast while Roundcube takes forever...
Update: I see in your Video Thunderbird is having speed problems at send
as well... Can you please recheck the Taskmanager if you send the EMail with thunderbird? Sorry my explanation didnt match the problem right now it seems.
Post by Dravion » 2016-08-08 11:58
It just manually used telnet to type a plain text/ascii message
to you address it@assorti-express.ru
The processing was verry fast, so i assume it could be some DNS-Server problem...
220 SRV01 ESMTP
EHLO post.assorti-express.ru
250-SRV01
250-SIZE 51200000
250-AUTH LOGIN
250 HELP
MAIL FROM:<dravion.smith@gmx.net>
250 OK
RCPT TO:<it@assorti-express.ru>
250 OK
DATA
354 OK, send.
Hi, iam Dravion from hmailserver.com Forum. I just test if this telnet typed mail can be delivered.
250 Queued (39.141 seconds)
quit
221 goodbye
Connection to host lost.
C:\>
Try to talk to the admins of the DNS-Servers for
ns2.hosting.reg.ru.
ns1.hosting.reg.ru.
It looks like DNS-Roudtrips takes forever. You may could setup your own caching DNS-Server
(i like Bind9 even on windows checkout https://www.isc.org/downloads/)
to speedup DNS-Lookups for hMailServer in you local Network.
assorti
Post by assorti » 2016-08-08 13:13
The problem is not in the Roundcube.
Look at the video. There are now on the server about 90-100 people and the entrance to Rundkyuve not difficult.
But at the last video at the entrance there are delays, letters are sent to Tanderbird slowly.
https://youtu.be/nRKmZQTxdlE
Post by mattg » 2016-08-09 13:50
Looks to me like certificate verification going wrong...
What type of connections do you accept (ssl / STartTLS etc) and on what ports?
Try on an unencrypted port
assorti
Post by assorti » 2016-08-09 15:12
mattg wrote:Looks to me like certificate verification going wrong...
How do you decide that a certificate verification is going wrong?
I use 465 - SSL/TSL - SMTP
587 - SSL/TLS - SMTP
993 - SSL/TLS IMAP
995 - SSL/TLS - POP3.
Most of the users configured but not encrypted channel 143 and 25.
Not encrypted protocol also slows.
Post by mattg » 2016-08-10 00:55
Just looked like that from the video...
Navigation around hmailserver GUI seems fine, the server is not working very hard and everything seems to work smoothly, except mail client connections...
DO you have large numbers of undelivered mail in the queue? (I wouldn't suspect so)
Also I use Baretail to view hmailserver logs in real time, you could try that and see where it stops / slows down...
assorti
Post by assorti » 2016-08-10 13:42
mattg wrote:Just looked like that from the video...
Good afternoon. E-mail messages are delivered to all.
And what in the logs to see?
assorti
Post by assorti » 2016-08-11 13:23
Good afternoon.
Today tested the file system. But I well udalos achieve the moment when the server will slow down.
I made a test file with 150 active sessions.
(Let me remind you that starting with access problems in more than 200 sessions)
I'll tell you about my file system and installed programs:
Disk C: System, 250 GB Raid mirror.
Drive E: mail server, database, web server. The volume of 3.8 TB Raid mirror.
Once again I say that today tested at partial load. 150 people. With more than 200 people - the problems begin.
Tests.
The first picture. Test the system drive. Windows.
system disk monitoring for 8 minutes
Test drive E
Monitoring Disk E within 9 minutes. (Disk to the mail server, database and web server. The average load of 150 active sessions)
assorti
Post by assorti » 2016-08-11 13:24
When the more than 200 people, I try to run the monitor and understand whether there is a difficulty in the file system and the mail server.
As far as I seem to slow mail server is not connected with the possibility of equipment.
(Sorry for my English, I use a translator)
Post by Dravion » 2016-08-11 16:19
Did you test connecting to the server using Thunderbirdbird installed on your hMailServer Computer?
Pleaye report back if a local installed Thunderbird
on the server is slow to.
ps: I Telneted your SMTP server and sended
a test email to it@assorti-express.ru and it was
fast without hanging or delays.
Is this only an IMAP or SMTP problem?
Looks like its especialy IMAP related for me right now.
assorti
Post by assorti » 2016-08-11 16:49
Dravion wrote:Did you test connecting to the server using Thunderbirdbird installed on your hMailServer Computer?
did not quite understand what you wanted to write)))
Write details) (this translation difficulties)
Post by Dravion » 2016-08-11 17:07
Install Thunderbird on the hMailServer computer and connect to a Mailbox.
1) See if its fast or slow
2) Report back
assorti
Post by assorti » 2016-08-11 20:03
Dravion wrote:Install Thunderbird on the hMailServer computer and connect to a Mailbox.
2) Report back
Installed on a server - sending emails is instantaneous (1 second).
From another PC on the local network sending a letter is delayed 4-9 seconds.
Post by Dravion » 2016-08-11 20:37
2) Report back
Ok, but sending is ONE thing, receiving EMails os a ANOTHER thing!!!
We need to findout if only the SMTP part (sending EMails) or the IMAP part (Receiving EMails)
or both sections of your hMailServer are slow.
Regarding your last post, it looks like the sending part (SMTP) "on your hMailServer Computer using
Thunderbird) is fast, but how fast is it to receive and open so you can read the EMail in Thunderbird (IMAP)?
If both (SMTP and IMAP/POP3) is fast on your hMailServer Computer locally, there is an Problem
with Cables, old Networkcard drivers.
Try the following to increase a common bottleneck in slow Windows LAN's
1) Change your Network Card drivers LOS value from Enabled to Disable and restart
2) Report back
assorti
Post by assorti » 2016-08-12 09:42
2) Report back
2) Report back
Parameters set in the NIC. Mail is also sent with a delay ..
I can give you e-mail account for the test.
Post by Dravion » 2016-08-12 10:45
assorti wrote:
Dravion wrote:
assorti wrote:
2) Report back
I checked the account you sended me privately and found some issues with it.
1) Your DNS-Server entries are wrong and pointing to 220-relay7.hosting.reg.ru ESMTP Postfix
2) If your connection is slow you will rejected with 521 5.7.1 Service unavailable; client [xxxx] blocked using zen.spamhaus.org
3) Any mail (like hmail@assorti-express.ru) will not reach post.assorti-express.ru rathern then
220-relay7.hosting.reg.ru because the mx enties at your DNS-Server
assorti-express.ru. 14399 IN NS ns2.hosting.reg.ru.
assorti-express.ru. 14399 IN NS ns1.hosting.reg.ru.
pointing simply not to your hMailServer computer (post.assorti.express)
3) There is no connection security whatso ever, no SSL/TLS no Senderid/SPF at IMAP and SMTP
and the Comodo wildcard certificate is wrongly configured for hMailServer.
Solution:
1)
DNS-Server mx entries has to be updated so post.assortig-express.ru can receive and send
emails from the outside
2)
Encryption errors needs to be adressed and fixed.
assorti
Post by assorti » 2016-08-12 11:00
Dravion wrote:
assorti wrote:
Dravion wrote: Parameters set in the NIC. Mail is also sent with a delay ..
Solution:
1)
2)
Try it now again.
(Our mail server is set up so that it takes a letter from external boxes to himself.
A user now connects to my server.)
Post by Dravion » 2016-08-12 11:40
Now it works (with little delay) because your postfix needs a while for relaying.
assorti
Post by assorti » 2016-08-12 11:44
Dravion wrote:Now it works (with little dely) because your postfix needs a while for relaying.
What ? little did not understand you. Postfix is not present with us.
You have mail forwarded without delay?
You use Thunderbird as your mail client?
Post by Dravion » 2016-08-12 11:54
Your hMailServer doesnt do the Mailserver on its self. It sends and receices all incomning
and outgoing EMails via a POSTFIX SMTP Server.
Received: from SRV01 (unknown [213.241.204.228])
(Authenticated sender: it@assorti-express.ru)
by spl63.hosting.reg.ru (Postfix) with ESMTPSA id AFEB9182505E
for <dravion.smith@gmx.net>; Fri, 12 Aug 2016 12:37:54 +0300 (MSK)
This means your hMailServer uses this Relayserver with the Account it@assorti-express.ru
to send Emails via the Postfix server.
Your hMailServer is NOT independent, it uses a thirdparty Emailserver (Postfix)
for sending and receiving EMails. If you are the Administrator of this hMailServer you should
know this...
assorti
Post by assorti » 2016-08-12 12:19
Dravion wrote:Your hMailServer doesnt do the Mailserver on its self. It sends and receices all incomning
know this...
Yes that's right, but why when there are delays sending and the server is no delay?
Post by Dravion » 2016-08-12 12:32
assorti wrote: Yes that's right, but why when there are delays sending and the server is no delay?
Because the processing between your hMailServer and the Postfix server needs some time to
deliver the emails. Check your postfix logs /var/logs/messages and maillog for problems
on your Linux server (and you should set a MySQL Password on your two DNS-Servers, there
is NO password and if someone can spoof a fake ip address your both DNS-Servers are doomed.
assorti
Post by assorti » 2016-08-12 14:06
Not quite probably understand how our mailing arranged.
Led diagram below.
The delay occurs at the stage of the PC and the HmailServer
The second mistake is slow down the mail server. This happens when the server 200 of the active user sessions.
DNS server on our servers are configured correctly. Posta runs correctly.
The problem sending long letters to tanderbirde and slow work hMailServer server when logging more than 200 members.
Post by Dravion » 2016-08-12 22:37
If its like you saym then its not a hMailServer rather then a local network problem on your company.
hMailServer needs a correct, working LAN in the firstplace and it looks like your PC to Server
Network is causing the slow network performance.
assorti
Post by assorti » 2016-08-15 08:51
Dravion wrote:If its like you saym then its not a hMailServer rather then a local network problem on your company.
Good afternoon.
It is not in the network. Between the server and the LAN are communicating at 100 Mbps speeds.
It's all about the number of users. When there are more than 200 that is slowing down the mail server.
Post by mattg » 2016-08-15 13:56
Where are the SSL certificates installed?
assorti
Post by assorti » 2016-08-15 14:35
mattg wrote:Where are the SSL certificates installed?
Locally on the server.
Post by mattg » 2016-08-15 23:14
do the logs show normal connections at less then 200 users?
What if users are only POP3 users rather than IMAP users?
How many access via web mail, how many via mail clients, which mail clients (thunderbird / outlook)
Can you check the permissions for the certificate file for the specific user that the hmailserver SERVICE runs under please
Is this 'locally on the server' location the same as the hmailserver install directory, or elsewhere 'locally on the server'?
FYI there are reports of some hmailserver installations having hundreds of thousands of accounts, processing millions of email each day...
Post by Dravion » 2016-08-16 01:04
100 MBits is not nowdays standard.
1000 MBits (Giga-Ethernet) is.
Your error description makes no sense at all.
As Matt allready described: Your version of hMailServer is used in situations where hundred and thousands of connections on a daily basis is handled and you are the first one reporting about a 200 connection slowdown bug.
The boost ASIO Networksubsystem which is used for this part works asynchronously and pauses any thread which doesnt needs attention.
Its designed to serve millions of concurrent connections on modern hardware. Your own Taskmanager screenshots proves that hMailServer.exe almost working near idle status without much ram or net bandwhich usage, so its allmost impossible hMailServer can cause this sort of problems, neither does my connectiontests with the credential you provided reflects such claims.
Post by mattg » 2016-08-16 01:37
Another thought, what inline antivirus scanning is being done on the server?
assorti
Post by assorti » 2016-08-16 07:52
mattg wrote:do the logs show normal connections at less then 200 users?
1. The logs show the normal connection when more than 200 users.
2. There is no way protestirovta only POP3 or IMAP users.
3. 300 polhovateley aktiynyh POP3 check mail and connect to the server about once every 300 seconds. IMAP users access through a web interface. The web interface is on the same host where the mail server. (Ie roundcube locally connected to the mail server.) 30 users IMAP podlklyuchayutsya or from the local network or from the Internet.
4. Rights to read folder with certificates there.
5. The Server service is running with system privileges
assorti
Post by assorti » 2016-08-16 07:55
Dravion wrote:100 MBits is not nowdays standard.
I do not quite understand what we ... Apparently this translation difficulties. :)
assorti
Post by assorti » 2016-08-16 07:57
mattg wrote:Another thought, what inline antivirus scanning is being done on the server?
Check for viruses, we disabled. It was to this antivirus ClamAV.
When checking each letter he held 300 MB of RAM and CPU load at 100%. So we turned off.
assorti
Post by assorti » 2016-08-16 08:04
I want to say that in the Mail Server logs are mistakes, but I suspect that they do not affect the server begins to slow down when more than 200 members.
File ERROR_hmailserver_2016-08-15.log:
"ERROR"	4852	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	8204	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	5256	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	4588	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	6948	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	8060	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	7108	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	7860	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	7720	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	4580	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	8648	"2016-08-15 01:03:14.796"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-ExternalFetchTask'"
"ERROR"	4852	"2016-08-15 01:03:15.751"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010314_{B0248273-E66A-4037-B167-30F267B46233}.dmp"
"ERROR"	7108	"2016-08-15 01:03:15.880"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010315_{900AB0DE-67EE-4622-BE13-64EE949F5CC7}.dmp"
"ERROR"	8204	"2016-08-15 01:03:16.003"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010315_{D1D800DC-40FD-4869-836C-E2C2F694353F}.dmp"
"ERROR"	5256	"2016-08-15 01:03:16.128"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010316_{FD3C067A-B21E-43BE-AFFC-972700163CA2}.dmp"
"ERROR"	8648	"2016-08-15 01:03:16.256"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010316_{DA240324-9E47-419C-933F-52101F2A7F20}.dmp"
"ERROR"	6948	"2016-08-15 01:03:16.381"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010316_{04289A82-613C-4541-9D6B-2EB9C2A5DF3C}.dmp"
"ERROR"	4588	"2016-08-15 01:03:16.508"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010316_{54636106-7B8F-47AE-83FF-47CC693D9521}.dmp"
"ERROR"	8060	"2016-08-15 01:03:16.631"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010316_{ED1A4AA4-4433-49AB-97A3-77C3B80B0DC1}.dmp"
"ERROR"	7720	"2016-08-15 01:03:16.755"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010316_{0C479025-2320-4A7A-9309-93A6E99275E6}.dmp"
"ERROR"	4580	"2016-08-15 01:03:16.881"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to D:\Mail\hMailServer\Logs\minidump_2016-08-15 010316_{4A930734-623E-4883-86C3-92255B16A651}.dmp"
"ERROR"	3964	"2016-08-15 04:49:25.330"	"Severity: 2 (High), Code: HM5032, Source: DALConnection::Execute, Description: MySQL: Incorrect string value: '\xF0\x9F\x92\xB0\xF0\x9F...' for column 'metadata_subject' at row 1 (Additional info: INSERT INTO hm_message_metadata (metadata_accountid, metadata_folderid, metadata_messageid, metadata_dateutc, metadata_from, metadata_subject, metadata_to, metadata_cc) VALUES (4, 4, 285793, '2016-06-16 09:34:09', 'Softline <mail@softline.ru>', '"ERROR"	8228	"2016-08-15 10:08:23.154"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\53\{537A5CD7-E644-4E9B-96E3-F22EC0D96CEB}.eml did not exist."
"ERROR"	8228	"2016-08-15 10:08:23.502"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\BE\{BEE80CE9-1BCA-4D2F-BC07-D1CC036AB7E1}.eml did not exist."
"ERROR"	3056	"2016-08-15 10:08:23.821"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\58\{58716B2B-4C17-4273-A646-8C7C053E55AE}.eml did not exist."
"ERROR"	8784	"2016-08-15 10:08:24.140"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\4E\{4E398C05-0E47-4E28-965D-A74CF4340083}.eml did not exist."
"ERROR"	4228	"2016-08-15 10:08:24.462"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\DC\{DC19BEE2-3E12-4D9C-BC97-148294C018A7}.eml did not exist."
"ERROR"	9112	"2016-08-15 10:08:24.831"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\39\{39E6C81D-45CD-4907-A73B-C94B9ADCD5D8}.eml did not exist."
"ERROR"	6960	"2016-08-15 10:08:25.162"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\25\{258D9F89-D3DC-4AC5-BFA1-2B5405B5FBEF}.eml did not exist."
"ERROR"	9112	"2016-08-15 10:08:25.497"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\4D\{4D3D9B03-BC7E-4C1A-9F99-367E365F8E87}.eml did not exist."
"ERROR"	9112	"2016-08-15 10:08:25.825"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\8F\{8FE854EE-C6D7-4067-98D5-9C901C1881FA}.eml did not exist."
"ERROR"	5296	"2016-08-15 10:08:26.140"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\3A\{3A237A31-7463-413A-A9E9-B59940DEFA20}.eml did not exist."
"ERROR"	5076	"2016-08-15 10:08:26.438"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\34\{349C72D9-E9EA-49B5-AB46-E8ABCB014841}.eml did not exist."
"ERROR"	5296	"2016-08-15 10:08:26.797"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\22\{22B6EC23-B470-405E-AC9D-537EDEE876BB}.eml did not exist."
"ERROR"	4540	"2016-08-15 10:08:27.109"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\24\{248D8653-9B85-4F3A-86C4-7DCC2E76A5B9}.eml did not exist."
"ERROR"	4540	"2016-08-15 10:08:27.435"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\8D\{8D28C705-D51C-4765-B103-EEA409FC72BD}.eml did not exist."
"ERROR"	8808	"2016-08-15 10:08:27.742"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\26\{26DE2FCB-1577-421C-834B-5C73C2EF67B6}.eml did not exist."
"ERROR"	6444	"2016-08-15 10:08:28.069"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\9F\{9F054849-DABE-4809-BCA1-BF36B09DE3C4}.eml did not exist."
"ERROR"	8992	"2016-08-15 10:08:28.384"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\8C\{8C532B59-894C-40DA-BD22-17DD80848CC8}.eml did not exist."
"ERROR"	4572	"2016-08-15 10:08:28.719"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\35\{35D2E650-EC39-4CE0-B391-0432BF492558}.eml did not exist."
"ERROR"	5404	"2016-08-15 10:08:29.030"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\ED\{ED4A1589-AA5B-4AE5-A090-2378E0F6D090}.eml did not exist."
"ERROR"	952	"2016-08-15 10:08:29.362"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\2A\{2A23A91D-3882-48E4-BB20-7FE5D26383BE}.eml did not exist."
"ERROR"	868	"2016-08-15 10:08:29.759"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\D1\{D16B9ED4-6D23-48D3-9A59-3B5A8FC77A45}.eml did not exist."
"ERROR"	4736	"2016-08-15 10:08:30.069"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\AD\{AD584C6C-E42F-4622-99AD-33ACAEACBAD7}.eml did not exist."
"ERROR"	868	"2016-08-15 10:08:30.358"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\FB\{FB54D7AF-45ED-4713-B654-A9B86B6F42A7}.eml did not exist."
"ERROR"	868	"2016-08-15 10:08:30.728"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\AC\{AC120036-268C-4E20-AB52-51F869951904}.eml did not exist."
"ERROR"	4592	"2016-08-15 10:08:31.051"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\49\{49FDA2AC-9252-420F-939C-9C7B7ADDF406}.eml did not exist."
"ERROR"	4592	"2016-08-15 10:08:31.385"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\85\{85834FC7-351B-4027-B4ED-943B9E2C165E}.eml did not exist."
"ERROR"	4516	"2016-08-15 10:08:31.683"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\50\{505B1D9C-1029-4ABC-8203-7CA36973D8D6}.eml did not exist."
"ERROR"	8212	"2016-08-15 10:08:32.047"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\0C\{0CD96656-8E2D-472D-BD37-3C84FF50B3EF}.eml did not exist."
"ERROR"	4668	"2016-08-15 10:08:32.375"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\1F\{1F30C33B-94F4-4F91-857E-D294E3FB9653}.eml did not exist."
"ERROR"	3056	"2016-08-15 10:08:32.735"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\AD\{AD0300E5-F11C-43DE-8093-354AC288941B}.eml did not exist."
"ERROR"	1256	"2016-08-15 10:08:33.116"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\DB\{DB9C356E-19A3-4D5E-802B-AC8E918989BB}.eml did not exist."
"ERROR"	4228	"2016-08-15 10:08:33.488"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\DB\{DB24FC8E-2930-4D5B-9507-1AF84B31554D}.eml did not exist."
"ERROR"	1256	"2016-08-15 10:08:33.803"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\EC\{ECE18C1C-E611-4ACE-BBA8-CEFAFF9D9F4B}.eml did not exist."
"ERROR"	7900	"2016-08-15 10:08:34.138"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\A4\{A441ECEB-D3B3-46E9-B09C-57DB3A4B230E}.eml did not exist."
"ERROR"	4228	"2016-08-15 10:08:34.515"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\4C\{4CBAEEF0-B378-42A9-8A1B-59D2D62CF0C6}.eml did not exist."
"ERROR"	4228	"2016-08-15 10:08:34.829"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\90\{9029D3EA-DF40-4D0D-B0CA-79673F98621E}.eml did not exist."
"ERROR"	6960	"2016-08-15 10:08:35.145"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\92\{92506D39-52EB-45CC-8657-2090E36A7AE6}.eml did not exist."
"ERROR"	8916	"2016-08-15 10:08:35.447"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\2B\{2B05CADA-51DA-4939-9F0A-7D37EA392E25}.eml did not exist."
"ERROR"	7932	"2016-08-15 10:08:35.765"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\B9\{B94B3C3C-0A8D-4F74-BE2E-3F8C7F20AF0C}.eml did not exist."
"ERROR"	4680	"2016-08-15 10:08:36.096"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\C9\{C91FECED-19EB-4CDB-81B6-161517B6F701}.eml did not exist."
"ERROR"	8576	"2016-08-15 10:08:36.452"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\43\{43AB0F37-CE93-46A0-B4DA-96DEAD973205}.eml did not exist."
"ERROR"	8748	"2016-08-15 10:08:36.792"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\E6\{E635C387-4F24-4099-9935-2DEACBED7B69}.eml did not exist."
"ERROR"	8576	"2016-08-15 10:08:37.135"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\E7\{E743572C-E208-4365-81B0-065AAE49C992}.eml did not exist."
"ERROR"	9000	"2016-08-15 10:08:37.442"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\DD\{DD96075C-3D4A-4C94-B26F-BE207FFCC04E}.eml did not exist."
"ERROR"	792	"2016-08-15 10:08:37.765"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\43\{43D550D3-99DF-4B11-A133-038390DAF578}.eml did not exist."
"ERROR"	8516	"2016-08-15 10:08:38.108"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\22\{22BE1461-3007-4206-BEE9-D68D9B32E124}.eml did not exist."
"ERROR"	8228	"2016-08-15 10:08:38.477"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\B7\{B78F13B9-B399-4A37-B53F-DCE2B8A73E0E}.eml did not exist."
"ERROR"	1116	"2016-08-15 10:08:38.803"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\A2\{A2C2E2AB-6BAF-48E9-BE23-CC1B5B48EAFE}.eml did not exist."
"ERROR"	792	"2016-08-15 10:08:39.135"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\73\{7345FD7F-5FC8-47D4-B928-9832AA90A23B}.eml did not exist."
"ERROR"	8604	"2016-08-15 10:08:39.482"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\FC\{FCF1F646-71C3-479F-8CA8-CBC56B570431}.eml did not exist."
"ERROR"	4572	"2016-08-15 10:08:39.913"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\B5\{B546370D-14F5-4054-A4F4-6730B7354C06}.eml did not exist."
"ERROR"	6136	"2016-08-15 10:08:40.331"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\EE\{EEADDB01-625C-48CB-B9D8-1A565DCB32D2}.eml did not exist."
"ERROR"	8020	"2016-08-15 10:08:40.687"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\C7\{C7446CED-EA99-4928-BA29-B625D01FF0E5}.eml did not exist."
"ERROR"	7872	"2016-08-15 10:08:41.043"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\EB\{EBCF10A7-891F-403D-8D0D-144561D93B84}.eml did not exist."
"ERROR"	4696	"2016-08-15 10:08:41.441"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\81\{8103927E-2163-46B0-A2AB-0B394C62025C}.eml did not exist."
"ERROR"	4732	"2016-08-15 10:08:41.780"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\97\{97DC75D2-E93F-425B-A5A3-6BAC5CCEC1E3}.eml did not exist."
"ERROR"	6624	"2016-08-15 10:08:42.120"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\2A\{2A08C411-B8E1-4A4A-8EE1-92FA014E606D}.eml did not exist."
"ERROR"	8096	"2016-08-15 10:08:42.455"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\AC\{ACADBB50-A7B2-47F5-A5AA-52BD6C5CB0FC}.eml did not exist."
"ERROR"	7084	"2016-08-15 10:08:42.819"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\67\{674C9BC8-041C-45C3-8F72-B968B2499D45}.eml did not exist."
"ERROR"	5004	"2016-08-15 10:08:43.154"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\5C\{5CC40EDF-0495-4DB5-93EB-F4C9456D9E3C}.eml did not exist."
"ERROR"	5004	"2016-08-15 10:08:43.490"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\ED\{ED04F50C-8AE6-49F8-BA4E-C2F3822DAA5A}.eml did not exist."
"ERROR"	8004	"2016-08-15 10:08:43.821"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\AC\{AC617BCB-AD3B-464A-ABE2-BFB732BF601F}.eml did not exist."
"ERROR"	6444	"2016-08-15 10:08:44.185"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\96\{96F4C1F5-198E-4676-8D4E-A79A23DB57EB}.eml did not exist."
"ERROR"	6664	"2016-08-15 10:08:44.558"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\96\{96ED0FE8-F338-4B3B-BB63-835E82694B81}.eml did not exist."
"ERROR"	4680	"2016-08-15 10:08:44.864"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\FE\{FEED9C0C-EFCA-445E-B43B-D56B806D4D5B}.eml did not exist."
"ERROR"	4680	"2016-08-15 10:08:45.191"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\D8\{D8B23313-8DB2-4E61-B27D-EC190261CB13}.eml did not exist."
"ERROR"	8644	"2016-08-15 10:08:45.510"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\CB\{CB7947FF-C824-4384-8760-70CFF0F7B1A3}.eml did not exist."
"ERROR"	4680	"2016-08-15 10:08:45.888"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\A9\{A9198FFE-2F33-4F0A-872F-8DFEC532A0F7}.eml did not exist."
"ERROR"	6528	"2016-08-15 10:08:46.206"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\AC\{AC5ACA84-349B-48C3-9EA4-1D1FA3AF78F9}.eml did not exist."
"ERROR"	3964	"2016-08-15 16:57:42.620"	"Severity: 2 (High), Code: HM5032, Source: DALConnection::Execute, Description: MySQL: Incorrect string value: '\xF0\x9F\x92\xB0\xF0\x9F...' for column 'metadata_subject' at row 1 (Additional info: INSERT INTO hm_message_metadata (metadata_accountid, metadata_folderid, metadata_messageid, metadata_dateutc, metadata_from, metadata_subject, metadata_to, metadata_cc) VALUES (4, 4, 285793, '2016-06-16 09:34:09', 'Softline <mail@softline.ru>', '
If you want I can give access to the server through a program TeamViver.
assorti
Post by assorti » 2016-08-16 08:59
assorti wrote:I want to say that in the Mail Server logs are mistakes, but I suspect that they do not affect the server begins to slow down when more than 200 members.
If you want I can give access to the server through a program TeamViwer.
Post by Dravion » 2016-08-16 09:11
assorti wrote: I do not quite understand what we ... Apparently this translation difficulties. :)
Ok.
Its simple.
If hMailServer.exe doesnt use many CPU and Memory and Network and Disk resources this cannot
be a 200 users slow down problem caused by hMailServer.exe
The mosttimes a server slows down is if there is an bottleneck to a program (limited CPU, Memory, Disk
or avaiable Network bandwich.
Your own Screenshots proves hHmailServer uses 14% CPU verry few MBytes RAM (90 MBytes or so)
and Network isnt exausted. You also sy you are using a RAID System with good I/O performance.
In this case, the chances hMailServer.exe causes this sort of trouble is almost zero. I could be
wrong but iam pretty confident this is not a hMailServer Error.
assorti
Post by assorti » 2016-08-16 10:18
Ok.
Its simple.
Then why hMailServer slows its work with more than 200 users?
Post by Dravion » 2016-08-16 11:42
assorti wrote: Then why hMailServer slows its work with more than 200 users?
Tell me in details why you came to this conclusion.
Can you simulate this?
Can you measure the slowing down
of operations speed and which command token is responsible for it?
I think you should recheck your d:\ drive performance using parkdale speed test and reporting the speedtest data.
Post by Dravion » 2016-08-16 11:48
Here you can download parkdale disk speedtest
just start parkdale.exe and clicl quicktest for drive d:\ and report back.
http://www.the-sz.com/products/parkdale/
assorti
Post by assorti » 2016-08-16 11:51
Dravion wrote:Here you can download parkdale disk speedtest
The statement above, I have already done a test drive D.
assorti
Post by assorti » 2016-08-16 11:56
Test drive D
Post by Dravion » 2016-08-16 13:31
Hmm, ok, the result is ok (should be arround 100 - 150) for normal SATA Harddrives.
Just for completlyness, can you do the Harddisk Speeddest
for all your Drives?
assorti
Post by assorti » 2016-08-16 14:02
Dravion wrote:Hmm, ok, the result is ok (should be arround 100 - 150) for normal SATA Harddrives.
Yes.
Disk C:
Disk E:
Drive E is not used for the mail server, it is for backups.
Can put in the future, here are the wheels as the picture along the C drive (system).
Post by mattg » 2016-08-16 14:47
assorti wrote:"ERROR" 8228 "2016-08-15 10:08:23.502" "Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file D:\Mail\hMailServer\Data\assorti-express.ru\pobedi65b\BE\{BEE80CE9-1BCA-4D2F-BC07-D1CC036AB7E1}.eml did not exist."
These are NORMALLY caused by Anti virus removing the file from the disk
You should add the data path as an exclusion to Anti virus scanning
ALSO, what are your thread settings in Performance > Threading
And is Roundcube on IIS, appache or ...??
assorti
Post by assorti » 2016-08-16 15:05
1. Antivirus does not work as file monitor. I can turn off the antivirus software at all because there is no sense of it.
I looked antivirus logs for the last week and have not seen reports that he was removing something in the mail server folder.
2.
3. Apache2.2, PHP -5.4. (I use LAMP Open Server 5.2.5)
Post by mattg » 2016-08-16 15:13
Change the asynchronous task threads from 70 to 170 or perhaps higher still (I think these are used by IMAP connections)
assorti
Post by assorti » 2016-08-16 15:40
mattg wrote:Change the asynchronous task threads from 70 to 170 or perhaps higher still (I think these are used by IMAP connections)
Right here?
What is the value?
Post by Dravion » 2016-08-16 17:51
change the field to 170
assorti
Post by assorti » 2016-08-17 13:57
Dravion wrote:change the field to 170
I change the setting. Watch the video that turned out. With more than 300 members - the server starts running slowly.
https://youtu.be/B6o_J3SHaJ0
Post by Dravion » 2016-08-17 17:00
Well, then increase from 170 to 400 and check again
assorti
Post by assorti » 2016-08-18 10:42
Dravion wrote:Well, then increase from 170 to 400 and check again
the maximum number of threads are not to change?
Post by mattg » 2016-08-18 11:47
Sorry my bad....
Command threads is the one to change as per the documentation >> https://www.hmailserver.com/documentati ... erformance
Asynchrononous task threads is connections to spamassassin it can probably go back to 70
Make the commands threads 500 and see if that fixes what you are experiencing
assorti
Post by assorti » 2016-08-18 11:54
mattg wrote:Sorry my bad....
vot tak.PNG (10.94 KiB) Viewed 16214 times
Did I understand you correctly? (look at the picture)
Post by mattg » 2016-08-18 12:31
Yes
Does that make a difference
assorti
Post by assorti » 2016-08-18 13:46
mattg wrote:Yes
Number of asynchronous streams do not change?
