Email sending problem
Dvd+rw
Post by Dvd+rw » 2014-07-29 20:50
hi, i cant send any email from my HMAIL server...
recieving and everything else works fine
LOG:
"DEBUG"	4848	"2014-07-29 20:51:02.059"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	4848	"2014-07-29 20:51:02.423"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	6116	"2014-07-29 20:51:02.523"	"Delivering message..."
"APPLICATION"	6116	"2014-07-29 20:51:02.528"	"SMTPDeliverer - Message 85: Delivering message from  to xxxxxxxxxxx@gmail.com. File: C:\Program Files\hMailServer\Data\{34531158-1137-4A35-B9AE-D9CDDDA2C6CF}.eml"
"DEBUG"	6116	"2014-07-29 20:51:02.530"	"Applying rules"
"DEBUG"	6116	"2014-07-29 20:51:02.532"	"Performing local delivery"
"DEBUG"	6116	"2014-07-29 20:51:02.534"	"Local delivery completed"
"DEBUG"	6116	"2014-07-29 20:51:02.536"	"Performing external delivery"
"SMTPD"	6116	0	"2014-07-29 20:51:02.537"	"TCP"	"DNS - MX Lookup: gmail.com"
"SMTPD"	6116	0	"2014-07-29 20:51:14.541"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: gmail.com, Type: 15, DnsQuery return value: 1460."
"DEBUG"	6116	"2014-07-29 20:51:14.542"	"Failed to resolve email servers (MX lookup). Domain name: gmail.com."
"APPLICATION"	6116	"2014-07-29 20:51:14.544"	"SMTPDeliverer - Message 85: No mail servers could be found for the address xxxxxxxxxxxxxx@gmail.com."
"DEBUG"	6116	"2014-07-29 20:51:14.545"	"Collect delivery result"
"DEBUG"	6116	"2014-07-29 20:51:14.546"	"Collect delivery result - Done"
"DEBUG"	6116	"2014-07-29 20:51:14.547"	"SD::_RescheduleDelivery"
"DEBUG"	6116	"2014-07-29 20:51:14.548"	"Retrieving retry options."
"DEBUG"	6116	"2014-07-29 20:51:14.550"	"Starting rescheduling."
"APPLICATION"	6116	"2014-07-29 20:51:14.551"	"SMTPDeliverer - Message 85: Message could not be delivered. Scheduling it for later delivery in 10 minutes."
"DEBUG"	6116	"2014-07-29 20:51:14.552"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	6116	"2014-07-29 20:51:14.793"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	6116	"2014-07-29 20:51:14.955"	"Message rescheduled for later delivery."
"APPLICATION"	6116	"2014-07-29 20:51:14.956"	"SMTPDeliverer - Message 85: Message delivery thread completed."
can you please help me?
//EDIT: I am not on any spamlist, ( http://mxtoolbox.com/SuperTool.aspx?act ... n=toolpage# )
Re: Email sending problem
Post by percepts » 2014-07-29 23:19
please run hmail diagnostics, use the copy button to copy and post full results here.
Dvd+rw
Post by Dvd+rw » 2014-07-30 22:19
how long it should take? because i press start and wait for 20 minutes and nothing happend :/ so i end it from task manager
is this correct?:
outbond port 25 host: mail.hmailserver.com
Post by percepts » 2014-07-31 01:32
it normally takes less than one second.
Post by percepts » 2014-07-31 01:34
from the drop down on the left select your own local domain and leave mail.hmailserver.com on the right.
Dvd+rw
Post by Dvd+rw » 2014-07-31 07:22
Test: Collect server details
hMailServer version: hMailServer 5.4.2-B1964
Database type: MySQL
Test: Test IPv6
Test: Test outbound port
Trying to connect to TCP/IP address 46.163.109.39 on port 25.
Connected successfully.
Test: Test backup directory
Test: Test MX records
Trying to resolve MX records for shufflex.no-ip.org...
ERROR: MX records for domain shufflex.no-ip.org could not be resolved
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain shufflex.no-ip.org...
ERROR: MX records for local domain shufflex.no-ip.org could not be resolved
Post by mattg » 2014-07-31 12:28
OK
This time,
enable all logging
rename today's log
try to send another message
Wait until you get an error message, or 30 seconds,
and then post ALL logs created
Dvd+rw
Post by Dvd+rw » 2014-07-31 21:24
"TCPIP"	3760	"2014-07-31 21:21:15.744"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"TCPIP"	3440	"2014-07-31 21:21:15.749"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	3760	"2014-07-31 21:21:15.749"	"Creating session 31"
"IMAPD"	3760	31	"2014-07-31 21:21:15.749"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	3760	31	"2014-07-31 21:21:15.794"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	3760	31	"2014-07-31 21:21:15.794"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3848	31	"2014-07-31 21:21:15.994"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	3848	31	"2014-07-31 21:21:16.044"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	2700	31	"2014-07-31 21:21:16.089"	"213.151.213.120"	"RECEIVED: 4 namespace"
"IMAPD"	2700	31	"2014-07-31 21:21:16.094"	"213.151.213.120"	"SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]4 OK namespace command complete"
"IMAPD"	3448	31	"2014-07-31 21:21:16.144"	"213.151.213.120"	"RECEIVED: 5 lsub "" "*""
"IMAPD"	3448	31	"2014-07-31 21:21:16.159"	"213.151.213.120"	"SENT: * LSUB (\HasNoChildren) "." "INBOX"[nl]* LSUB (\HasNoChildren) "." "Trash"[nl]* LSUB (\HasNoChildren) "." "Sent""
"IMAPD"	3448	31	"2014-07-31 21:21:16.164"	"213.151.213.120"	"SENT: 5 OK LSUB completed"
"IMAPD"	3160	31	"2014-07-31 21:21:16.294"	"213.151.213.120"	"RECEIVED: 6 lsub "" "#Public*""
"IMAPD"	3160	31	"2014-07-31 21:21:16.294"	"213.151.213.120"	"SENT: "
"IMAPD"	3160	31	"2014-07-31 21:21:16.294"	"213.151.213.120"	"SENT: 6 OK LSUB completed"
"IMAPD"	3748	31	"2014-07-31 21:21:16.344"	"213.151.213.120"	"RECEIVED: 7 list "" "INBOX""
"IMAPD"	3748	31	"2014-07-31 21:21:16.344"	"213.151.213.120"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]7 OK LIST completed"
"IMAPD"	3160	31	"2014-07-31 21:21:16.424"	"213.151.213.120"	"RECEIVED: 8 select "INBOX""
"IMAPD"	3160	31	"2014-07-31 21:21:16.424"	"213.151.213.120"	"SENT: * 8 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757411] current uidvalidity[nl]* OK [UIDNEXT 9] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]8 OK [READ-WRITE] SELECT completed"
"IMAPD"	3468	31	"2014-07-31 21:21:16.479"	"213.151.213.120"	"RECEIVED: 9 myrights "INBOX""
"IMAPD"	3468	31	"2014-07-31 21:21:16.479"	"213.151.213.120"	"SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]9 OK Myrights complete"
"IMAPD"	2980	31	"2014-07-31 21:21:16.524"	"213.151.213.120"	"RECEIVED: 10 getacl "INBOX""
"IMAPD"	2980	31	"2014-07-31 21:21:16.529"	"213.151.213.120"	"SENT: * ACL "INBOX"[nl]10 OK GetAcl complete"
"IMAPD"	3848	31	"2014-07-31 21:21:16.594"	"213.151.213.120"	"RECEIVED: 11 getquotaroot "INBOX""
"IMAPD"	3848	31	"2014-07-31 21:21:16.594"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]11 OK GETQUOTAROOT completed"
"IMAPD"	3848	31	"2014-07-31 21:21:16.659"	"213.151.213.120"	"RECEIVED: 12 UID fetch 1:* (FLAGS)"
"IMAPD"	3848	31	"2014-07-31 21:21:16.664"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Answered \Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.664"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Answered \Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.664"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.664"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.664"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.664"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.669"	"213.151.213.120"	"SENT: * 7 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.669"	"213.151.213.120"	"SENT: * 8 FETCH (UID 8 FLAGS (\Seen))"
"IMAPD"	3848	31	"2014-07-31 21:21:16.669"	"213.151.213.120"	"SENT: 12 OK UID completed"
"IMAPD"	3760	31	"2014-07-31 21:21:16.804"	"213.151.213.120"	"RECEIVED: 13 IDLE"
"IMAPD"	3760	31	"2014-07-31 21:21:16.804"	"213.151.213.120"	"SENT: + idling"
"APPLICATION"	3440	"2014-07-31 21:21:16.809"	"DALConnection - Reconnecting to the database"
"DEBUG"	3440	"2014-07-31 21:21:17.204"	"Creating session 32"
"IMAPD"	3440	32	"2014-07-31 21:21:17.204"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	652	32	"2014-07-31 21:21:17.244"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	652	32	"2014-07-31 21:21:17.244"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	652	32	"2014-07-31 21:21:17.299"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	652	32	"2014-07-31 21:21:17.359"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	2188	32	"2014-07-31 21:21:17.409"	"213.151.213.120"	"RECEIVED: 4 namespace"
"IMAPD"	2188	32	"2014-07-31 21:21:17.414"	"213.151.213.120"	"SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]4 OK namespace command complete"
"IMAPD"	3336	32	"2014-07-31 21:21:17.484"	"213.151.213.120"	"RECEIVED: 5 lsub "" "*""
"IMAPD"	3336	32	"2014-07-31 21:21:17.484"	"213.151.213.120"	"SENT: * LSUB (\HasNoChildren) "." "INBOX"[nl]* LSUB (\HasNoChildren) "." "Trash"[nl]* LSUB (\HasNoChildren) "." "Sent""
"IMAPD"	3336	32	"2014-07-31 21:21:17.489"	"213.151.213.120"	"SENT: 5 OK LSUB completed"
"IMAPD"	3468	32	"2014-07-31 21:21:17.604"	"213.151.213.120"	"RECEIVED: 6 lsub "" "#Public*""
"IMAPD"	3468	32	"2014-07-31 21:21:17.604"	"213.151.213.120"	"SENT: "
"IMAPD"	3468	32	"2014-07-31 21:21:17.604"	"213.151.213.120"	"SENT: 6 OK LSUB completed"
"IMAPD"	960	32	"2014-07-31 21:21:17.649"	"213.151.213.120"	"RECEIVED: 7 list "" "INBOX""
"IMAPD"	960	32	"2014-07-31 21:21:17.649"	"213.151.213.120"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]7 OK LIST completed"
"IMAPD"	3848	32	"2014-07-31 21:21:17.754"	"213.151.213.120"	"RECEIVED: 8 select "INBOX""
"IMAPD"	3848	32	"2014-07-31 21:21:17.754"	"213.151.213.120"	"SENT: * 8 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757411] current uidvalidity[nl]* OK [UIDNEXT 9] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]8 OK [READ-WRITE] SELECT completed"
"IMAPD"	3896	32	"2014-07-31 21:21:17.814"	"213.151.213.120"	"RECEIVED: 9 myrights "INBOX""
"IMAPD"	3896	32	"2014-07-31 21:21:17.819"	"213.151.213.120"	"SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]9 OK Myrights complete"
"IMAPD"	3896	32	"2014-07-31 21:21:17.904"	"213.151.213.120"	"RECEIVED: 10 getacl "INBOX""
"IMAPD"	3896	32	"2014-07-31 21:21:17.904"	"213.151.213.120"	"SENT: * ACL "INBOX"[nl]10 OK GetAcl complete"
"IMAPD"	3748	32	"2014-07-31 21:21:17.964"	"213.151.213.120"	"RECEIVED: 11 getquotaroot "INBOX""
"IMAPD"	3748	32	"2014-07-31 21:21:17.964"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]11 OK GETQUOTAROOT completed"
"IMAPD"	3092	32	"2014-07-31 21:21:18.014"	"213.151.213.120"	"RECEIVED: 12 UID fetch 1:* (FLAGS)"
"IMAPD"	3092	32	"2014-07-31 21:21:18.014"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Answered \Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.019"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Answered \Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.019"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.019"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.019"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.019"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.019"	"213.151.213.120"	"SENT: * 7 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.024"	"213.151.213.120"	"SENT: * 8 FETCH (UID 8 FLAGS (\Seen))"
"IMAPD"	3092	32	"2014-07-31 21:21:18.024"	"213.151.213.120"	"SENT: 12 OK UID completed"
"IMAPD"	3468	32	"2014-07-31 21:21:18.119"	"213.151.213.120"	"RECEIVED: 13 IDLE"
"IMAPD"	3468	32	"2014-07-31 21:21:18.119"	"213.151.213.120"	"SENT: + idling"
"IMAPD"	3748	31	"2014-07-31 21:21:20.099"	"213.151.213.120"	"RECEIVED: DONE"
"IMAPD"	3748	31	"2014-07-31 21:21:20.104"	"213.151.213.120"	"SENT: 13 OK IDLE terminated"
"IMAPD"	3336	31	"2014-07-31 21:21:20.154"	"213.151.213.120"	"RECEIVED: 14 noop"
"IMAPD"	3336	31	"2014-07-31 21:21:20.154"	"213.151.213.120"	"SENT: 14 OK NOOP completed"
"IMAPD"	2700	31	"2014-07-31 21:21:20.204"	"213.151.213.120"	"RECEIVED: 15 getquotaroot "INBOX""
"IMAPD"	2700	31	"2014-07-31 21:21:20.204"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]15 OK GETQUOTAROOT completed"
"IMAPD"	3848	31	"2014-07-31 21:21:20.269"	"213.151.213.120"	"RECEIVED: 16 UID fetch 9:* (FLAGS)"
"IMAPD"	3848	31	"2014-07-31 21:21:20.269"	"213.151.213.120"	"SENT: 16 OK UID completed"
"IMAPD"	3448	31	"2014-07-31 21:21:20.339"	"213.151.213.120"	"RECEIVED: 17 IDLE"
"IMAPD"	3448	31	"2014-07-31 21:21:20.339"	"213.151.213.120"	"SENT: + idling"
"TCPIP"	3440	"2014-07-31 21:21:40.149"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	3440	"2014-07-31 21:21:40.154"	"Creating session 33"
"IMAPD"	3440	33	"2014-07-31 21:21:40.154"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	3336	33	"2014-07-31 21:21:40.204"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	3336	33	"2014-07-31 21:21:40.204"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	2700	33	"2014-07-31 21:21:40.259"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	2700	33	"2014-07-31 21:21:40.529"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	652	33	"2014-07-31 21:21:40.574"	"213.151.213.120"	"RECEIVED: 4 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)"
"IMAPD"	652	33	"2014-07-31 21:21:40.579"	"213.151.213.120"	"SENT: * STATUS "Sent" (MESSAGES 2 UNSEEN 0 RECENT 0 UIDNEXT 3)[nl]4 OK Status completed"
"TCPIP"	3440	"2014-07-31 21:21:40.994"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	3440	"2014-07-31 21:21:40.994"	"Creating session 34"
"IMAPD"	3440	34	"2014-07-31 21:21:40.994"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	3896	34	"2014-07-31 21:21:41.054"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	3896	34	"2014-07-31 21:21:41.054"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3092	34	"2014-07-31 21:21:41.119"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	3092	34	"2014-07-31 21:21:41.369"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3760	34	"2014-07-31 21:21:41.409"	"213.151.213.120"	"RECEIVED: 4 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)"
"IMAPD"	3760	34	"2014-07-31 21:21:41.409"	"213.151.213.120"	"SENT: * STATUS "Sent" (MESSAGES 2 UNSEEN 0 RECENT 0 UIDNEXT 3)[nl]4 OK Status completed"
"TCPIP"	2700	"2014-07-31 21:22:03.584"	"TCP - 213.151.213.120 connected to 192.168.1.5:2525."
"DEBUG"	2700	"2014-07-31 21:22:03.584"	"Creating session 35"
"SMTPD"	2700	35	"2014-07-31 21:22:03.584"	"213.151.213.120"	"SENT: 220 A02-635B ESMTP"
"SMTPD"	3160	35	"2014-07-31 21:22:03.634"	"213.151.213.120"	"RECEIVED: EHLO [192.168.1.5]"
"SMTPD"	3160	35	"2014-07-31 21:22:03.634"	"213.151.213.120"	"SENT: 250-A02-635B[nl]250-SIZE 20480000[nl]250 AUTH LOGIN"
"SMTPD"	3468	35	"2014-07-31 21:22:03.679"	"213.151.213.120"	"RECEIVED: AUTH LOGIN"
"SMTPD"	3468	35	"2014-07-31 21:22:03.684"	"213.151.213.120"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	3336	35	"2014-07-31 21:22:03.724"	"213.151.213.120"	"RECEIVED: YWRtaW4="
"SMTPD"	3336	35	"2014-07-31 21:22:03.724"	"213.151.213.120"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	960	35	"2014-07-31 21:22:03.764"	"213.151.213.120"	"RECEIVED: ***"
"SMTPD"	960	35	"2014-07-31 21:22:04.034"	"213.151.213.120"	"SENT: 235 authenticated."
"SMTPD"	652	35	"2014-07-31 21:22:04.089"	"213.151.213.120"	"RECEIVED: MAIL FROM:<admin@shufflex.no-ip.org> SIZE=418"
"SMTPD"	652	35	"2014-07-31 21:22:04.139"	"213.151.213.120"	"SENT: 250 OK"
"SMTPD"	652	35	"2014-07-31 21:22:04.179"	"213.151.213.120"	"RECEIVED: RCPT TO:<shuffle.team@gmai.com>"
"SMTPD"	652	35	"2014-07-31 21:22:04.184"	"213.151.213.120"	"SENT: 250 OK"
"SMTPD"	3748	35	"2014-07-31 21:22:04.234"	"213.151.213.120"	"RECEIVED: DATA"
"SMTPD"	3748	35	"2014-07-31 21:22:04.234"	"213.151.213.120"	"SENT: 354 OK, send."
"SMTPD"	3748	0	"2014-07-31 21:22:16.318"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: 120.213.151.213.in-addr.arpa, Type: 12, DnsQuery return value: 1460."
"DEBUG"	3748	"2014-07-31 21:22:16.318"	"Could not get PTR record for IP (false)! 213.151.213.120"
"DEBUG"	2644	"2014-07-31 21:22:16.583"	"Saving message: {0723E904-D844-44A3-B645-4ABC6D89B54D}.eml"
"DEBUG"	2644	"2014-07-31 21:22:16.678"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2644	35	"2014-07-31 21:22:16.683"	"213.151.213.120"	"SENT: 250 Queued (12.324 seconds)"
"DEBUG"	2520	"2014-07-31 21:22:16.708"	"Delivering message..."
"APPLICATION"	2520	"2014-07-31 21:22:16.713"	"SMTPDeliverer - Message 24: Delivering message from admin@shufflex.no-ip.org to shuffle.team@gmai.com. File: C:\Program Files\hMailServer\Data\{0723E904-D844-44A3-B645-4ABC6D89B54D}.eml"
"DEBUG"	2520	"2014-07-31 21:22:16.713"	"Applying rules"
"DEBUG"	2520	"2014-07-31 21:22:16.713"	"Performing local delivery"
"DEBUG"	2520	"2014-07-31 21:22:16.713"	"Local delivery completed"
"DEBUG"	2520	"2014-07-31 21:22:16.713"	"Performing external delivery"
"SMTPD"	2520	0	"2014-07-31 21:22:16.713"	"TCP"	"DNS - MX Lookup: gmai.com"
"SMTPD"	3748	35	"2014-07-31 21:22:16.823"	"213.151.213.120"	"RECEIVED: QUIT"
"SMTPD"	3748	35	"2014-07-31 21:22:16.823"	"213.151.213.120"	"SENT: 221 goodbye"
"DEBUG"	3748	"2014-07-31 21:22:16.828"	"Closing TCP/IP socket"
"DEBUG"	3748	"2014-07-31 21:22:16.828"	"Ending session 35"
"IMAPD"	3092	33	"2014-07-31 21:22:16.908"	"213.151.213.120"	"RECEIVED: 5 append "Sent" (\Seen) {418}"
"IMAPD"	3092	33	"2014-07-31 21:22:16.913"	"213.151.213.120"	"SENT: + Ready for literal data"
"DEBUG"	652	"2014-07-31 21:22:17.273"	"Saving message: {1826A1D8-B438-4F90-B5FA-509B4BD9F2F9}.eml"
"IMAPD"	652	33	"2014-07-31 21:22:17.588"	"213.151.213.120"	"SENT: 5 OK APPEND completed"
"SMTPD"	2520	0	"2014-07-31 21:22:28.719"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: gmai.com, Type: 15, DnsQuery return value: 1460."
"DEBUG"	2520	"2014-07-31 21:22:28.719"	"Failed to resolve email servers (MX lookup). Domain name: gmai.com."
"APPLICATION"	2520	"2014-07-31 21:22:28.719"	"SMTPDeliverer - Message 24: No mail servers could be found for the address shuffle.team@gmai.com."
"DEBUG"	2520	"2014-07-31 21:22:28.719"	"Collect delivery result"
"DEBUG"	2520	"2014-07-31 21:22:28.719"	"Collect delivery result - Done"
"DEBUG"	2520	"2014-07-31 21:22:28.719"	"SD::_RescheduleDelivery"
"DEBUG"	2520	"2014-07-31 21:22:28.719"	"Retrieving retry options."
"DEBUG"	2520	"2014-07-31 21:22:28.719"	"Starting rescheduling."
"APPLICATION"	2520	"2014-07-31 21:22:28.719"	"SMTPDeliverer - Message 24: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG"	2520	"2014-07-31 21:22:28.719"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 21:22:28.994"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 21:22:29.024"	"Message rescheduled for later delivery."
"APPLICATION"	2520	"2014-07-31 21:22:29.024"	"SMTPDeliverer - Message 24: Message delivery thread completed."
"DEBUG"	2884	"2014-07-31 21:22:55.109"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	2884	"2014-07-31 21:22:55.364"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 21:22:55.529"	"Delivering message..."
"APPLICATION"	2520	"2014-07-31 21:22:55.529"	"SMTPDeliverer - Message 24: Delivering message from admin@shufflex.no-ip.org to shuffle.team@gmai.com. File: C:\Program Files\hMailServer\Data\{0723E904-D844-44A3-B645-4ABC6D89B54D}.eml"
"DEBUG"	2520	"2014-07-31 21:22:55.529"	"Applying rules"
"DEBUG"	2520	"2014-07-31 21:22:55.529"	"Performing local delivery"
"DEBUG"	2520	"2014-07-31 21:22:55.529"	"Local delivery completed"
"DEBUG"	2520	"2014-07-31 21:22:55.534"	"Performing external delivery"
"SMTPD"	2520	0	"2014-07-31 21:22:55.534"	"TCP"	"DNS - MX Lookup: gmai.com"
"SMTPD"	2520	0	"2014-07-31 21:23:07.538"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: gmai.com, Type: 15, DnsQuery return value: 1460."
"DEBUG"	2520	"2014-07-31 21:23:07.538"	"Failed to resolve email servers (MX lookup). Domain name: gmai.com."
"APPLICATION"	2520	"2014-07-31 21:23:07.538"	"SMTPDeliverer - Message 24: No mail servers could be found for the address shuffle.team@gmai.com."
"DEBUG"	2520	"2014-07-31 21:23:07.538"	"Collect delivery result"
"DEBUG"	2520	"2014-07-31 21:23:07.538"	"Collect delivery result - Done"
"DEBUG"	2520	"2014-07-31 21:23:07.538"	"SD::_RescheduleDelivery"
"DEBUG"	2520	"2014-07-31 21:23:07.538"	"Retrieving retry options."
"DEBUG"	2520	"2014-07-31 21:23:07.538"	"Starting rescheduling."
"APPLICATION"	2520	"2014-07-31 21:23:07.538"	"SMTPDeliverer - Message 24: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG"	2520	"2014-07-31 21:23:07.538"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 21:23:07.853"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 21:23:07.918"	"Message rescheduled for later delivery."
"APPLICATION"	2520	"2014-07-31 21:23:07.918"	"SMTPDeliverer - Message 24: Message delivery thread completed."
Post by percepts » 2014-07-31 22:48
see http://www.hmailserver.com/documentatio ... ssages_dns
did you really mean to be sending to gmai.com or was it supposed to be gmail.com ?
also see http://www.intodns.com/gmai.com
Dvd+rw
Post by Dvd+rw » 2014-07-31 22:54
oh sry .. my mistake .. of course gmail... so new log:
and i forget to mention .. i have 2 DNS records for my IP .. shufflex.info and shufflex.no-ip.org .. both MX records are set
"TCPIP"	2980	"2014-07-31 22:59:41.729"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	2980	"2014-07-31 22:59:41.734"	"Creating session 51"
"IMAPD"	2980	51	"2014-07-31 22:59:41.734"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	2700	51	"2014-07-31 22:59:41.799"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	2700	51	"2014-07-31 22:59:41.799"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"TCPIP"	2980	"2014-07-31 22:59:41.839"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	2980	"2014-07-31 22:59:41.839"	"Creating session 52"
"IMAPD"	2980	52	"2014-07-31 22:59:41.844"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	2980	51	"2014-07-31 22:59:41.879"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	2700	52	"2014-07-31 22:59:41.919"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	2700	52	"2014-07-31 22:59:41.919"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3448	52	"2014-07-31 22:59:41.969"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	2980	51	"2014-07-31 22:59:42.154"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3896	51	"2014-07-31 22:59:42.189"	"213.151.213.120"	"RECEIVED: 4 namespace"
"IMAPD"	3896	51	"2014-07-31 22:59:42.189"	"213.151.213.120"	"SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]4 OK namespace command complete"
"IMAPD"	3448	52	"2014-07-31 22:59:42.194"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3448	51	"2014-07-31 22:59:42.224"	"213.151.213.120"	"RECEIVED: 5 lsub "" "*""
"IMAPD"	3448	51	"2014-07-31 22:59:42.224"	"213.151.213.120"	"SENT: * LSUB (\HasNoChildren) "." "INBOX"[nl]* LSUB (\HasNoChildren) "." "Trash"[nl]* LSUB (\HasNoChildren) "." "Sent""
"IMAPD"	3448	51	"2014-07-31 22:59:42.229"	"213.151.213.120"	"SENT: 5 OK LSUB completed"
"IMAPD"	3748	52	"2014-07-31 22:59:42.229"	"213.151.213.120"	"RECEIVED: 4 namespace"
"IMAPD"	3748	52	"2014-07-31 22:59:42.234"	"213.151.213.120"	"SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]4 OK namespace command complete"
"IMAPD"	2980	52	"2014-07-31 22:59:42.269"	"213.151.213.120"	"RECEIVED: 5 lsub "" "*""
"IMAPD"	2980	52	"2014-07-31 22:59:42.269"	"213.151.213.120"	"SENT: * LSUB (\HasNoChildren) "." "INBOX"[nl]* LSUB (\HasNoChildren) "." "Trash"[nl]* LSUB (\HasNoChildren) "." "Sent""
"IMAPD"	2980	52	"2014-07-31 22:59:42.269"	"213.151.213.120"	"SENT: 5 OK LSUB completed"
"IMAPD"	3160	51	"2014-07-31 22:59:42.304"	"213.151.213.120"	"RECEIVED: 6 lsub "" "#Public*""
"IMAPD"	3160	51	"2014-07-31 22:59:42.304"	"213.151.213.120"	"SENT: "
"IMAPD"	3160	51	"2014-07-31 22:59:42.304"	"213.151.213.120"	"SENT: 6 OK LSUB completed"
"IMAPD"	3448	51	"2014-07-31 22:59:42.354"	"213.151.213.120"	"RECEIVED: 7 list "" "INBOX""
"IMAPD"	3448	51	"2014-07-31 22:59:42.359"	"213.151.213.120"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]7 OK LIST completed"
"IMAPD"	2980	52	"2014-07-31 22:59:42.359"	"213.151.213.120"	"RECEIVED: 6 lsub "" "#Public*""
"IMAPD"	2980	52	"2014-07-31 22:59:42.359"	"213.151.213.120"	"SENT: "
"IMAPD"	2980	52	"2014-07-31 22:59:42.359"	"213.151.213.120"	"SENT: 6 OK LSUB completed"
"IMAPD"	3160	52	"2014-07-31 22:59:42.399"	"213.151.213.120"	"RECEIVED: 7 list "" "INBOX""
"IMAPD"	3160	52	"2014-07-31 22:59:42.399"	"213.151.213.120"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]7 OK LIST completed"
"IMAPD"	3160	51	"2014-07-31 22:59:42.404"	"213.151.213.120"	"RECEIVED: 8 select "INBOX""
"IMAPD"	3160	51	"2014-07-31 22:59:42.404"	"213.151.213.120"	"SENT: * 8 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757411] current uidvalidity[nl]* OK [UIDNEXT 9] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]8 OK [READ-WRITE] SELECT completed"
"IMAPD"	3440	52	"2014-07-31 22:59:42.439"	"213.151.213.120"	"RECEIVED: 8 select "INBOX""
"IMAPD"	3440	52	"2014-07-31 22:59:42.439"	"213.151.213.120"	"SENT: * 8 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757411] current uidvalidity[nl]* OK [UIDNEXT 9] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]8 OK [READ-WRITE] SELECT completed"
"IMAPD"	3440	51	"2014-07-31 22:59:42.449"	"213.151.213.120"	"RECEIVED: 9 myrights "INBOX""
"IMAPD"	3440	51	"2014-07-31 22:59:42.449"	"213.151.213.120"	"SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]9 OK Myrights complete"
"IMAPD"	3468	52	"2014-07-31 22:59:42.489"	"213.151.213.120"	"RECEIVED: 9 myrights "INBOX""
"IMAPD"	3468	52	"2014-07-31 22:59:42.489"	"213.151.213.120"	"SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]9 OK Myrights complete"
"IMAPD"	3092	51	"2014-07-31 22:59:42.494"	"213.151.213.120"	"RECEIVED: 10 getacl "INBOX""
"IMAPD"	3092	51	"2014-07-31 22:59:42.494"	"213.151.213.120"	"SENT: * ACL "INBOX"[nl]10 OK GetAcl complete"
"IMAPD"	3760	52	"2014-07-31 22:59:42.529"	"213.151.213.120"	"RECEIVED: 10 getacl "INBOX""
"IMAPD"	3760	52	"2014-07-31 22:59:42.534"	"213.151.213.120"	"SENT: * ACL "INBOX"[nl]10 OK GetAcl complete"
"IMAPD"	3440	51	"2014-07-31 22:59:42.534"	"213.151.213.120"	"RECEIVED: 11 getquotaroot "INBOX""
"IMAPD"	3440	51	"2014-07-31 22:59:42.539"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]11 OK GETQUOTAROOT completed"
"IMAPD"	2188	52	"2014-07-31 22:59:42.569"	"213.151.213.120"	"RECEIVED: 11 getquotaroot "INBOX""
"IMAPD"	2188	52	"2014-07-31 22:59:42.569"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]11 OK GETQUOTAROOT completed"
"IMAPD"	2188	51	"2014-07-31 22:59:42.574"	"213.151.213.120"	"RECEIVED: 12 UID fetch 1:* (FLAGS)"
"IMAPD"	2188	51	"2014-07-31 22:59:42.579"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Answered \Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.579"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Answered \Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.579"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.584"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.584"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.589"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.589"	"213.151.213.120"	"SENT: * 7 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.589"	"213.151.213.120"	"SENT: * 8 FETCH (UID 8 FLAGS (\Seen))"
"IMAPD"	2188	51	"2014-07-31 22:59:42.594"	"213.151.213.120"	"SENT: 12 OK UID completed"
"IMAPD"	3848	52	"2014-07-31 22:59:42.624"	"213.151.213.120"	"RECEIVED: 12 UID fetch 1:* (FLAGS)"
"IMAPD"	3848	52	"2014-07-31 22:59:42.624"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Answered \Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.629"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Answered \Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.629"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.629"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.634"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.634"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.634"	"213.151.213.120"	"SENT: * 7 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.639"	"213.151.213.120"	"SENT: * 8 FETCH (UID 8 FLAGS (\Seen))"
"IMAPD"	3848	52	"2014-07-31 22:59:42.639"	"213.151.213.120"	"SENT: 12 OK UID completed"
"IMAPD"	652	51	"2014-07-31 22:59:42.674"	"213.151.213.120"	"RECEIVED: 13 IDLE"
"IMAPD"	652	51	"2014-07-31 22:59:42.674"	"213.151.213.120"	"SENT: + idling"
"IMAPD"	960	52	"2014-07-31 22:59:42.719"	"213.151.213.120"	"RECEIVED: 13 IDLE"
"IMAPD"	960	52	"2014-07-31 22:59:42.719"	"213.151.213.120"	"SENT: + idling"
"TCPIP"	2700	"2014-07-31 22:59:52.699"	"TCP - 213.151.213.120 connected to 192.168.1.5:2525."
"DEBUG"	2700	"2014-07-31 22:59:52.704"	"Creating session 53"
"SMTPD"	2700	53	"2014-07-31 22:59:52.704"	"213.151.213.120"	"SENT: 220 shufflex.info"
"SMTPD"	3748	53	"2014-07-31 22:59:52.744"	"213.151.213.120"	"RECEIVED: EHLO [192.168.1.5]"
"SMTPD"	3748	53	"2014-07-31 22:59:52.744"	"213.151.213.120"	"SENT: 250-A02-635B[nl]250-SIZE 20480000[nl]250 AUTH LOGIN"
"SMTPD"	3748	53	"2014-07-31 22:59:52.779"	"213.151.213.120"	"RECEIVED: AUTH LOGIN"
"SMTPD"	3748	53	"2014-07-31 22:59:52.779"	"213.151.213.120"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	960	53	"2014-07-31 22:59:52.824"	"213.151.213.120"	"RECEIVED: YWRtaW4="
"SMTPD"	960	53	"2014-07-31 22:59:52.824"	"213.151.213.120"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	2980	53	"2014-07-31 22:59:52.864"	"213.151.213.120"	"RECEIVED: ***"
"SMTPD"	2980	53	"2014-07-31 22:59:52.894"	"213.151.213.120"	"SENT: 235 authenticated."
"SMTPD"	3336	53	"2014-07-31 22:59:52.929"	"213.151.213.120"	"RECEIVED: MAIL FROM:<admin@shufflex.no-ip.org> SIZE=410"
"SMTPD"	3336	53	"2014-07-31 22:59:52.939"	"213.151.213.120"	"SENT: 250 OK"
"SMTPD"	3160	53	"2014-07-31 22:59:52.974"	"213.151.213.120"	"RECEIVED: RCPT TO:<shuffle.team@gmail.com>"
"SMTPD"	3160	53	"2014-07-31 22:59:52.979"	"213.151.213.120"	"SENT: 250 OK"
"SMTPD"	3896	53	"2014-07-31 22:59:53.014"	"213.151.213.120"	"RECEIVED: DATA"
"SMTPD"	3896	53	"2014-07-31 22:59:53.014"	"213.151.213.120"	"SENT: 354 OK, send."
"TCPIP"	2980	"2014-07-31 22:59:54.444"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	2980	"2014-07-31 22:59:54.444"	"Creating session 54"
"IMAPD"	2980	54	"2014-07-31 22:59:54.444"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	3448	54	"2014-07-31 22:59:54.479"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	3448	54	"2014-07-31 22:59:54.479"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3896	54	"2014-07-31 22:59:54.519"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	3896	54	"2014-07-31 22:59:54.779"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3748	54	"2014-07-31 22:59:54.814"	"213.151.213.120"	"RECEIVED: 4 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)"
"IMAPD"	3748	54	"2014-07-31 22:59:54.814"	"213.151.213.120"	"SENT: * STATUS "Sent" (MESSAGES 5 UNSEEN 0 RECENT 0 UIDNEXT 6)[nl]4 OK Status completed"
"TCPIP"	2980	"2014-07-31 22:59:54.884"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	2980	"2014-07-31 22:59:54.884"	"Creating session 55"
"IMAPD"	2980	55	"2014-07-31 22:59:54.889"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	652	55	"2014-07-31 22:59:54.919"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	652	55	"2014-07-31 22:59:54.924"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	2980	55	"2014-07-31 22:59:54.954"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	2980	55	"2014-07-31 22:59:54.989"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	2980	55	"2014-07-31 22:59:55.024"	"213.151.213.120"	"RECEIVED: 4 select "Sent""
"IMAPD"	2980	55	"2014-07-31 22:59:55.024"	"213.151.213.120"	"SENT: * 5 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757878] current uidvalidity[nl]* OK [UIDNEXT 6] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]4 OK [READ-WRITE] SELECT completed"
"IMAPD"	3336	55	"2014-07-31 22:59:55.064"	"213.151.213.120"	"RECEIVED: 5 myrights "Sent""
"IMAPD"	3336	55	"2014-07-31 22:59:55.064"	"213.151.213.120"	"SENT: * MYRIGHTS "Sent" lrswipkxtea[nl]5 OK Myrights complete"
"IMAPD"	3440	55	"2014-07-31 22:59:55.099"	"213.151.213.120"	"RECEIVED: 6 getacl "Sent""
"IMAPD"	3440	55	"2014-07-31 22:59:55.099"	"213.151.213.120"	"SENT: * ACL "Sent"[nl]6 OK GetAcl complete"
"IMAPD"	3440	55	"2014-07-31 22:59:55.134"	"213.151.213.120"	"RECEIVED: 7 getquotaroot "Sent""
"IMAPD"	3440	55	"2014-07-31 22:59:55.139"	"213.151.213.120"	"SENT: * QUOTAROOT "Sent" ""[nl]* QUOTA "" ()[nl]7 OK GETQUOTAROOT completed"
"IMAPD"	3760	55	"2014-07-31 22:59:55.174"	"213.151.213.120"	"RECEIVED: 8 UID fetch 1:* (FLAGS)"
"IMAPD"	3760	55	"2014-07-31 22:59:55.174"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Seen))"
"IMAPD"	3760	55	"2014-07-31 22:59:55.179"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Seen))"
"IMAPD"	3760	55	"2014-07-31 22:59:55.179"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	3760	55	"2014-07-31 22:59:55.184"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	3760	55	"2014-07-31 22:59:55.184"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	3760	55	"2014-07-31 22:59:55.184"	"213.151.213.120"	"SENT: 8 OK UID completed"
"IMAPD"	3848	55	"2014-07-31 22:59:55.244"	"213.151.213.120"	"RECEIVED: 9 IDLE"
"IMAPD"	3848	55	"2014-07-31 22:59:55.244"	"213.151.213.120"	"SENT: + idling"
"TCPIP"	2980	"2014-07-31 22:59:55.729"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	2980	"2014-07-31 22:59:55.734"	"Creating session 56"
"IMAPD"	2980	56	"2014-07-31 22:59:55.739"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	3848	56	"2014-07-31 22:59:55.769"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	3848	56	"2014-07-31 22:59:55.769"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	2188	56	"2014-07-31 22:59:55.809"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	2188	56	"2014-07-31 22:59:56.069"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3092	56	"2014-07-31 22:59:56.104"	"213.151.213.120"	"RECEIVED: 4 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)"
"IMAPD"	3092	56	"2014-07-31 22:59:56.109"	"213.151.213.120"	"SENT: * STATUS "Sent" (MESSAGES 5 UNSEEN 0 RECENT 0 UIDNEXT 6)[nl]4 OK Status completed"
"TCPIP"	2980	"2014-07-31 22:59:56.179"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	2980	"2014-07-31 22:59:56.184"	"Creating session 57"
"IMAPD"	2980	57	"2014-07-31 22:59:56.184"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	3440	57	"2014-07-31 22:59:56.219"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	3440	57	"2014-07-31 22:59:56.219"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3440	57	"2014-07-31 22:59:56.259"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	3440	57	"2014-07-31 22:59:56.289"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	960	57	"2014-07-31 22:59:56.324"	"213.151.213.120"	"RECEIVED: 4 select "Sent""
"IMAPD"	960	57	"2014-07-31 22:59:56.329"	"213.151.213.120"	"SENT: * 5 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757878] current uidvalidity[nl]* OK [UIDNEXT 6] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]4 OK [READ-WRITE] SELECT completed"
"IMAPD"	3896	57	"2014-07-31 22:59:56.369"	"213.151.213.120"	"RECEIVED: 5 myrights "Sent""
"IMAPD"	3896	57	"2014-07-31 22:59:56.369"	"213.151.213.120"	"SENT: * MYRIGHTS "Sent" lrswipkxtea[nl]5 OK Myrights complete"
"IMAPD"	3748	57	"2014-07-31 22:59:56.409"	"213.151.213.120"	"RECEIVED: 6 getacl "Sent""
"IMAPD"	3748	57	"2014-07-31 22:59:56.409"	"213.151.213.120"	"SENT: * ACL "Sent"[nl]6 OK GetAcl complete"
"IMAPD"	960	57	"2014-07-31 22:59:56.444"	"213.151.213.120"	"RECEIVED: 7 getquotaroot "Sent""
"IMAPD"	960	57	"2014-07-31 22:59:56.449"	"213.151.213.120"	"SENT: * QUOTAROOT "Sent" ""[nl]* QUOTA "" ()[nl]7 OK GETQUOTAROOT completed"
"IMAPD"	652	57	"2014-07-31 22:59:56.479"	"213.151.213.120"	"RECEIVED: 8 UID fetch 1:* (FLAGS)"
"IMAPD"	652	57	"2014-07-31 22:59:56.484"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Seen))"
"IMAPD"	652	57	"2014-07-31 22:59:56.484"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Seen))"
"IMAPD"	652	57	"2014-07-31 22:59:56.489"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	652	57	"2014-07-31 22:59:56.489"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	652	57	"2014-07-31 22:59:56.489"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	652	57	"2014-07-31 22:59:56.494"	"213.151.213.120"	"SENT: 8 OK UID completed"
"IMAPD"	960	57	"2014-07-31 22:59:56.554"	"213.151.213.120"	"RECEIVED: 9 IDLE"
"IMAPD"	960	57	"2014-07-31 22:59:56.559"	"213.151.213.120"	"SENT: + idling"
"SMTPD"	3160	0	"2014-07-31 23:00:05.063"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: 120.213.151.213.in-addr.arpa, Type: 12, DnsQuery return value: 1460."
"DEBUG"	3160	"2014-07-31 23:00:05.063"	"Could not get PTR record for IP (false)! 213.151.213.120"
"DEBUG"	2644	"2014-07-31 23:00:05.063"	"Saving message: {B5D65073-7FFB-4AFF-8FDE-FAD15C528784}.eml"
"DEBUG"	2644	"2014-07-31 23:00:05.433"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2644	53	"2014-07-31 23:00:05.438"	"213.151.213.120"	"SENT: 250 Queued (12.044 seconds)"
"SMTPD"	2700	53	"2014-07-31 23:00:05.468"	"213.151.213.120"	"RECEIVED: QUIT"
"SMTPD"	2700	53	"2014-07-31 23:00:05.473"	"213.151.213.120"	"SENT: 221 goodbye"
"DEBUG"	3848	"2014-07-31 23:00:05.473"	"Closing TCP/IP socket"
"DEBUG"	3848	"2014-07-31 23:00:05.473"	"Ending session 53"
"DEBUG"	2520	"2014-07-31 23:00:05.473"	"Delivering message..."
"APPLICATION"	2520	"2014-07-31 23:00:05.478"	"SMTPDeliverer - Message 30: Delivering message from admin@shufflex.no-ip.org to shuffle.team@gmail.com. File: C:\Program Files\hMailServer\Data\{B5D65073-7FFB-4AFF-8FDE-FAD15C528784}.eml"
"DEBUG"	2520	"2014-07-31 23:00:05.483"	"Applying rules"
"DEBUG"	2520	"2014-07-31 23:00:05.483"	"Performing local delivery"
"DEBUG"	2520	"2014-07-31 23:00:05.483"	"Local delivery completed"
"DEBUG"	2520	"2014-07-31 23:00:05.483"	"Performing external delivery"
"SMTPD"	2520	0	"2014-07-31 23:00:05.488"	"TCP"	"DNS - MX Lookup: gmail.com"
"IMAPD"	652	55	"2014-07-31 23:00:05.508"	"213.151.213.120"	"RECEIVED: DONE"
"IMAPD"	652	55	"2014-07-31 23:00:05.513"	"213.151.213.120"	"SENT: 9 OK IDLE terminated"
"IMAPD"	3896	55	"2014-07-31 23:00:05.543"	"213.151.213.120"	"RECEIVED: 10 append "Sent" (\Seen) {410}"
"IMAPD"	3896	55	"2014-07-31 23:00:05.548"	"213.151.213.120"	"SENT: + Ready for literal data"
"DEBUG"	3440	"2014-07-31 23:00:05.813"	"Saving message: {DD592611-648C-4817-92DD-021C7E6D38DD}.eml"
"DEBUG"	3440	"2014-07-31 23:00:06.218"	"Reading messages from database."
"IMAPD"	3440	55	"2014-07-31 23:00:06.218"	"213.151.213.120"	"SENT: * 6 EXISTS[nl]* 1 RECENT[nl]10 OK APPEND completed"
"IMAPD"	3440	57	"2014-07-31 23:00:06.223"	"213.151.213.120"	"SENT: * 6 EXISTS"
"IMAPD"	3440	57	"2014-07-31 23:00:06.223"	"213.151.213.120"	"SENT: * 1 RECENT"
"IMAPD"	3760	57	"2014-07-31 23:00:06.348"	"213.151.213.120"	"RECEIVED: DONE"
"IMAPD"	3760	57	"2014-07-31 23:00:06.348"	"213.151.213.120"	"SENT: 9 OK IDLE terminated"
"IMAPD"	2188	55	"2014-07-31 23:00:06.358"	"213.151.213.120"	"RECEIVED: 11 IDLE"
"IMAPD"	2188	55	"2014-07-31 23:00:06.358"	"213.151.213.120"	"SENT: + idling"
"IMAPD"	2188	57	"2014-07-31 23:00:06.383"	"213.151.213.120"	"RECEIVED: 10 noop"
"IMAPD"	2188	57	"2014-07-31 23:00:06.383"	"213.151.213.120"	"SENT: 10 OK NOOP completed"
"IMAPD"	2188	57	"2014-07-31 23:00:06.418"	"213.151.213.120"	"RECEIVED: 11 getquotaroot "Sent""
"IMAPD"	2188	57	"2014-07-31 23:00:06.418"	"213.151.213.120"	"SENT: * QUOTAROOT "Sent" ""[nl]* QUOTA "" ()[nl]11 OK GETQUOTAROOT completed"
"IMAPD"	3336	57	"2014-07-31 23:00:06.458"	"213.151.213.120"	"RECEIVED: 12 UID fetch 6:* (FLAGS)"
"IMAPD"	3336	57	"2014-07-31 23:00:06.458"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	3336	57	"2014-07-31 23:00:06.458"	"213.151.213.120"	"SENT: 12 OK UID completed"
"IMAPD"	3848	57	"2014-07-31 23:00:06.528"	"213.151.213.120"	"RECEIVED: 13 UID fetch 6 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type Reply-To)])"
"IMAPD"	3848	57	"2014-07-31 23:00:06.588"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 RFC822.SIZE 412 FLAGS (\Seen) BODY[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type Reply-To)] {257}"
"IMAPD"	3848	57	"2014-07-31 23:00:06.593"	"213.151.213.120"	"SENT: )"
"IMAPD"	3848	57	"2014-07-31 23:00:06.593"	"213.151.213.120"	"SENT: 13 OK UID completed"
"IMAPD"	3448	57	"2014-07-31 23:00:06.673"	"213.151.213.120"	"RECEIVED: 14 UID fetch 6 (UID RFC822.SIZE BODY.PEEK[])"
"IMAPD"	3448	57	"2014-07-31 23:00:06.673"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 RFC822.SIZE 412 BODY[] {412}"
"IMAPD"	3448	57	"2014-07-31 23:00:06.678"	"213.151.213.120"	"SENT: )"
"IMAPD"	3448	57	"2014-07-31 23:00:06.678"	"213.151.213.120"	"SENT: 14 OK UID completed"
"IMAPD"	3336	57	"2014-07-31 23:00:07.008"	"213.151.213.120"	"RECEIVED: 15 IDLE"
"IMAPD"	3336	57	"2014-07-31 23:00:07.008"	"213.151.213.120"	"SENT: + idling"
"SMTPD"	2520	0	"2014-07-31 23:00:17.495"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: gmail.com, Type: 15, DnsQuery return value: 1460."
"DEBUG"	2520	"2014-07-31 23:00:17.495"	"Failed to resolve email servers (MX lookup). Domain name: gmail.com."
"APPLICATION"	2520	"2014-07-31 23:00:17.495"	"SMTPDeliverer - Message 30: No mail servers could be found for the address shuffle.team@gmail.com."
"DEBUG"	2520	"2014-07-31 23:00:17.495"	"Collect delivery result"
"DEBUG"	2520	"2014-07-31 23:00:17.495"	"Collect delivery result - Done"
"DEBUG"	2520	"2014-07-31 23:00:17.500"	"SD::_RescheduleDelivery"
"DEBUG"	2520	"2014-07-31 23:00:17.500"	"Retrieving retry options."
"DEBUG"	2520	"2014-07-31 23:00:17.500"	"Starting rescheduling."
"APPLICATION"	2520	"2014-07-31 23:00:17.500"	"SMTPDeliverer - Message 30: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG"	2520	"2014-07-31 23:00:17.505"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 23:00:17.775"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 23:00:17.815"	"Message rescheduled for later delivery."
"APPLICATION"	2520	"2014-07-31 23:00:17.815"	"SMTPDeliverer - Message 30: Message delivery thread completed."
"DEBUG"	3736	"2014-07-31 23:00:18.345"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	3736	"2014-07-31 23:00:18.585"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 23:00:18.625"	"Delivering message..."
"APPLICATION"	2520	"2014-07-31 23:00:18.630"	"SMTPDeliverer - Message 30: Delivering message from admin@shufflex.no-ip.org to shuffle.team@gmail.com. File: C:\Program Files\hMailServer\Data\{B5D65073-7FFB-4AFF-8FDE-FAD15C528784}.eml"
"DEBUG"	2520	"2014-07-31 23:00:18.630"	"Applying rules"
"DEBUG"	2520	"2014-07-31 23:00:18.635"	"Performing local delivery"
"DEBUG"	2520	"2014-07-31 23:00:18.635"	"Local delivery completed"
"DEBUG"	2520	"2014-07-31 23:00:18.635"	"Performing external delivery"
"SMTPD"	2520	0	"2014-07-31 23:00:18.640"	"TCP"	"DNS - MX Lookup: gmail.com"
"SMTPD"	2520	0	"2014-07-31 23:00:30.640"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: gmail.com, Type: 15, DnsQuery return value: 1460."
"DEBUG"	2520	"2014-07-31 23:00:30.640"	"Failed to resolve email servers (MX lookup). Domain name: gmail.com."
"APPLICATION"	2520	"2014-07-31 23:00:30.640"	"SMTPDeliverer - Message 30: No mail servers could be found for the address shuffle.team@gmail.com."
"DEBUG"	2520	"2014-07-31 23:00:30.640"	"Collect delivery result"
"DEBUG"	2520	"2014-07-31 23:00:30.640"	"Collect delivery result - Done"
"DEBUG"	2520	"2014-07-31 23:00:30.645"	"SD::_RescheduleDelivery"
"DEBUG"	2520	"2014-07-31 23:00:30.645"	"Retrieving retry options."
"DEBUG"	2520	"2014-07-31 23:00:30.645"	"Starting rescheduling."
"APPLICATION"	2520	"2014-07-31 23:00:30.645"	"SMTPDeliverer - Message 30: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG"	2520	"2014-07-31 23:00:30.645"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 23:00:30.925"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-07-31 23:00:30.950"	"Message rescheduled for later delivery."
"APPLICATION"	2520	"2014-07-31 23:00:30.950"	"SMTPDeliverer - Message 30: Message delivery thread completed."
Post by ^DooM^ » 2014-07-31 23:16
Seems your server cannot resolve gmail.com
What DNS servers are you using?
Post by percepts » 2014-07-31 23:30
your MX is shufflex.info which is your website and not hmailserver
you must use a different hostname for hmailserver typically mail.shufflex.info
so change your MX to mail.shufflex.info
delete your cname record which says mail.shufflex.info cname shufflex.info
add an A record
mail.shufflex.info A 95.103.136.167
then in hmail admin set settings/protocols/smtp/delivery of email tab/ local host name to
mail.shufflex.info
and then in your email clients use mail.shufflex.info as your smtp/imap/pop server name
AND
you may need to change your settings at no-ip.com to reflect above changes.
Post by percepts » 2014-08-01 00:01
p.s. if no-ip requires you to use their name in your local host name then follow their instructions but you should do the dns changes I give above for mail.shufflex.info and reflect the mail.shufflex.info at no-ip if thats what they require.
Dvd+rw
Post by Dvd+rw » 2014-08-01 08:34
I set mail.shufflex.info also to no-ip MX record
delivery of email: mail.shufflex.info
can you please look at my settings? i am using godaddy
https://www.dropbox.com/s/ldrda74u0mpnnyv/1.png
https://www.dropbox.com/s/i1rbzjj2dosbll4/2.png
https://www.dropbox.com/s/qzs4tzxqt8u2drc/3.png
is this right?
//EDIT: for ^DooM^ ... i am using my ISP dns ... 195.146.132.58 195.146.128.62
//EDIT2: i change point to: mail .... now it is point to: mail.shufflex.info (pic no.3) now i will wait for a while and then i will write here if it works
//EDIT3: doesnt work :(
Dvd+rw
Post by Dvd+rw » 2014-08-01 09:15
i cant edit my previous post so my current settings:
https://www.dropbox.com/s/gsq896kku654icq/4.png
https://www.dropbox.com/s/db29m5eiv15xu8y/5.png
Post by percepts » 2014-08-01 13:16
in dns where you have
mail.shufflex.info MX mail.shufflex.info
it should be
ALSO
what do no-ip say you should use as your hmail local host name
Post by percepts » 2014-08-01 13:55
AND
make sure that in hmailadmin you have set your local host name correctly
hmailadmin / settings / protocols / smtp / delivery of email tab
set local host name to:
mail.shufflex.info
AND
I just checked at no-ip.
in your email clients your SMTP server name should be
smtp-auth.no-ip.com
port 3325
and your IMAP/POP servername should be
mail.shufflex.info
p.s. I am assuming your ISP has blocked outgoing port 25 and that you have purchased no-ip SMTP port forwarding service.
Post by percepts » 2014-08-01 14:39
NO you have deleted your MX entry completely, put it back.
shufflex.info 10 MX mail.shufflex.info
Dvd+rw
Post by Dvd+rw » 2014-08-01 19:55
I set up MX
localhost name in hmailadmin: mail.shufflex.info
now im setting up only shufflex.info .. i dont care about shufflex.no-ip.org now
i call my ISP and i was told that port 25 is free to use .. no blocking
MX record: https://www.dropbox.com/s/tn1ak3behxa0u ... hot109.png
"@" means shufflex.info
is there any tool to chceck if my MX are correct?
"TCPIP"	3092	"2014-08-01 19:49:45.882"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	3092	"2014-08-01 19:49:45.886"	"Creating session 149"
"IMAPD"	3092	149	"2014-08-01 19:49:45.888"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"TCPIP"	3092	"2014-08-01 19:49:45.931"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	3092	"2014-08-01 19:49:45.933"	"Creating session 150"
"IMAPD"	3092	150	"2014-08-01 19:49:45.934"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	960	149	"2014-08-01 19:49:45.981"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	960	149	"2014-08-01 19:49:45.985"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	652	150	"2014-08-01 19:49:46.014"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	652	150	"2014-08-01 19:49:46.016"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3160	149	"2014-08-01 19:49:46.185"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	3760	150	"2014-08-01 19:49:46.188"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	3160	149	"2014-08-01 19:49:46.467"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3760	150	"2014-08-01 19:49:46.497"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	652	149	"2014-08-01 19:49:46.550"	"213.151.213.120"	"RECEIVED: 4 namespace"
"IMAPD"	3760	150	"2014-08-01 19:49:46.550"	"213.151.213.120"	"RECEIVED: 4 namespace"
"IMAPD"	652	149	"2014-08-01 19:49:46.552"	"213.151.213.120"	"SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]4 OK namespace command complete"
"IMAPD"	3760	150	"2014-08-01 19:49:46.553"	"213.151.213.120"	"SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]4 OK namespace command complete"
"IMAPD"	3760	149	"2014-08-01 19:49:46.606"	"213.151.213.120"	"RECEIVED: 5 lsub "" "*""
"IMAPD"	652	150	"2014-08-01 19:49:46.606"	"213.151.213.120"	"RECEIVED: 5 lsub "" "*""
"IMAPD"	3760	149	"2014-08-01 19:49:46.608"	"213.151.213.120"	"SENT: * LSUB (\HasNoChildren) "." "INBOX"[nl]* LSUB (\HasNoChildren) "." "Trash"[nl]* LSUB (\HasNoChildren) "." "Sent""
"IMAPD"	652	150	"2014-08-01 19:49:46.609"	"213.151.213.120"	"SENT: * LSUB (\HasNoChildren) "." "INBOX"[nl]* LSUB (\HasNoChildren) "." "Trash"[nl]* LSUB (\HasNoChildren) "." "Sent""
"IMAPD"	3760	149	"2014-08-01 19:49:46.609"	"213.151.213.120"	"SENT: 5 OK LSUB completed"
"IMAPD"	652	150	"2014-08-01 19:49:46.611"	"213.151.213.120"	"SENT: 5 OK LSUB completed"
"IMAPD"	3748	149	"2014-08-01 19:49:46.707"	"213.151.213.120"	"RECEIVED: 6 lsub "" "#Public*""
"IMAPD"	960	150	"2014-08-01 19:49:46.708"	"213.151.213.120"	"RECEIVED: 6 lsub "" "#Public*""
"IMAPD"	3748	149	"2014-08-01 19:49:46.709"	"213.151.213.120"	"SENT: "
"IMAPD"	960	150	"2014-08-01 19:49:46.710"	"213.151.213.120"	"SENT: "
"IMAPD"	960	150	"2014-08-01 19:49:46.712"	"213.151.213.120"	"SENT: 6 OK LSUB completed"
"IMAPD"	3748	149	"2014-08-01 19:49:46.711"	"213.151.213.120"	"SENT: 6 OK LSUB completed"
"IMAPD"	960	150	"2014-08-01 19:49:46.764"	"213.151.213.120"	"RECEIVED: 7 list "" "INBOX""
"IMAPD"	3748	149	"2014-08-01 19:49:46.764"	"213.151.213.120"	"RECEIVED: 7 list "" "INBOX""
"IMAPD"	960	150	"2014-08-01 19:49:46.766"	"213.151.213.120"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]7 OK LIST completed"
"IMAPD"	3748	149	"2014-08-01 19:49:46.767"	"213.151.213.120"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]7 OK LIST completed"
"IMAPD"	3748	150	"2014-08-01 19:49:46.811"	"213.151.213.120"	"RECEIVED: 8 select "INBOX""
"IMAPD"	960	149	"2014-08-01 19:49:46.811"	"213.151.213.120"	"RECEIVED: 8 select "INBOX""
"IMAPD"	960	149	"2014-08-01 19:49:46.814"	"213.151.213.120"	"SENT: * 12 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757411] current uidvalidity[nl]* OK [UIDNEXT 13] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]8 OK [READ-WRITE] SELECT completed"
"IMAPD"	3748	150	"2014-08-01 19:49:46.813"	"213.151.213.120"	"SENT: * 12 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1406757411] current uidvalidity[nl]* OK [UIDNEXT 13] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]8 OK [READ-WRITE] SELECT completed"
"IMAPD"	3160	149	"2014-08-01 19:49:46.857"	"213.151.213.120"	"RECEIVED: 9 myrights "INBOX""
"IMAPD"	3160	149	"2014-08-01 19:49:46.859"	"213.151.213.120"	"SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]9 OK Myrights complete"
"IMAPD"	2700	150	"2014-08-01 19:49:46.873"	"213.151.213.120"	"RECEIVED: 9 myrights "INBOX""
"IMAPD"	2700	150	"2014-08-01 19:49:46.874"	"213.151.213.120"	"SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]9 OK Myrights complete"
"IMAPD"	2700	149	"2014-08-01 19:49:46.922"	"213.151.213.120"	"RECEIVED: 10 getacl "INBOX""
"IMAPD"	2700	149	"2014-08-01 19:49:46.924"	"213.151.213.120"	"SENT: * ACL "INBOX"[nl]10 OK GetAcl complete"
"IMAPD"	3160	150	"2014-08-01 19:49:46.928"	"213.151.213.120"	"RECEIVED: 10 getacl "INBOX""
"IMAPD"	3160	150	"2014-08-01 19:49:46.930"	"213.151.213.120"	"SENT: * ACL "INBOX"[nl]10 OK GetAcl complete"
"IMAPD"	3440	149	"2014-08-01 19:49:46.971"	"213.151.213.120"	"RECEIVED: 11 getquotaroot "INBOX""
"IMAPD"	3440	149	"2014-08-01 19:49:46.973"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]11 OK GETQUOTAROOT completed"
"IMAPD"	2188	150	"2014-08-01 19:49:46.985"	"213.151.213.120"	"RECEIVED: 11 getquotaroot "INBOX""
"IMAPD"	2188	150	"2014-08-01 19:49:46.987"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]11 OK GETQUOTAROOT completed"
"IMAPD"	2188	149	"2014-08-01 19:49:47.032"	"213.151.213.120"	"RECEIVED: 12 UID fetch 1:* (FLAGS)"
"IMAPD"	2188	149	"2014-08-01 19:49:47.034"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Answered \Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.036"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Answered \Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.038"	"213.151.213.120"	"RECEIVED: 12 UID fetch 1:* (FLAGS)"
"IMAPD"	2188	149	"2014-08-01 19:49:47.038"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.040"	"213.151.213.120"	"SENT: * 1 FETCH (UID 1 FLAGS (\Answered \Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.041"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.043"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.042"	"213.151.213.120"	"SENT: * 2 FETCH (UID 2 FLAGS (\Answered \Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.045"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.046"	"213.151.213.120"	"SENT: * 3 FETCH (UID 3 FLAGS (\Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.047"	"213.151.213.120"	"SENT: * 7 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.048"	"213.151.213.120"	"SENT: * 4 FETCH (UID 4 FLAGS (\Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.050"	"213.151.213.120"	"SENT: * 8 FETCH (UID 8 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.051"	"213.151.213.120"	"SENT: * 5 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.054"	"213.151.213.120"	"SENT: * 6 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.056"	"213.151.213.120"	"SENT: * 7 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.058"	"213.151.213.120"	"SENT: * 8 FETCH (UID 8 FLAGS (\Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.052"	"213.151.213.120"	"SENT: * 9 FETCH (UID 9 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.060"	"213.151.213.120"	"SENT: * 9 FETCH (UID 9 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.063"	"213.151.213.120"	"SENT: * 10 FETCH (UID 10 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.064"	"213.151.213.120"	"SENT: * 11 FETCH (UID 11 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.066"	"213.151.213.120"	"SENT: * 12 FETCH (UID 12 FLAGS (\Seen))"
"IMAPD"	3440	150	"2014-08-01 19:49:47.068"	"213.151.213.120"	"SENT: 12 OK UID completed"
"IMAPD"	2188	149	"2014-08-01 19:49:47.062"	"213.151.213.120"	"SENT: * 10 FETCH (UID 10 FLAGS (\Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.071"	"213.151.213.120"	"SENT: * 11 FETCH (UID 11 FLAGS (\Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.073"	"213.151.213.120"	"SENT: * 12 FETCH (UID 12 FLAGS (\Seen))"
"IMAPD"	2188	149	"2014-08-01 19:49:47.074"	"213.151.213.120"	"SENT: 12 OK UID completed"
"IMAPD"	652	149	"2014-08-01 19:49:47.144"	"213.151.213.120"	"RECEIVED: 13 IDLE"
"IMAPD"	652	149	"2014-08-01 19:49:47.146"	"213.151.213.120"	"SENT: + idling"
"IMAPD"	3760	150	"2014-08-01 19:49:47.174"	"213.151.213.120"	"RECEIVED: 13 IDLE"
"IMAPD"	3760	150	"2014-08-01 19:49:47.175"	"213.151.213.120"	"SENT: + idling"
"IMAPD"	3440	150	"2014-08-01 19:49:49.133"	"213.151.213.120"	"RECEIVED: DONE"
"IMAPD"	3440	150	"2014-08-01 19:49:49.134"	"213.151.213.120"	"SENT: 13 OK IDLE terminated"
"IMAPD"	652	150	"2014-08-01 19:49:49.187"	"213.151.213.120"	"RECEIVED: 14 noop"
"IMAPD"	652	150	"2014-08-01 19:49:49.188"	"213.151.213.120"	"SENT: 14 OK NOOP completed"
"IMAPD"	3760	150	"2014-08-01 19:49:49.233"	"213.151.213.120"	"RECEIVED: 15 getquotaroot "INBOX""
"IMAPD"	3760	150	"2014-08-01 19:49:49.235"	"213.151.213.120"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]15 OK GETQUOTAROOT completed"
"IMAPD"	3760	150	"2014-08-01 19:49:49.276"	"213.151.213.120"	"RECEIVED: 16 UID fetch 13:* (FLAGS)"
"IMAPD"	3760	150	"2014-08-01 19:49:49.277"	"213.151.213.120"	"SENT: 16 OK UID completed"
"IMAPD"	960	150	"2014-08-01 19:49:49.323"	"213.151.213.120"	"RECEIVED: 17 IDLE"
"IMAPD"	960	150	"2014-08-01 19:49:49.324"	"213.151.213.120"	"SENT: + idling"
"TCPIP"	3092	"2014-08-01 19:50:09.299"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	3092	"2014-08-01 19:50:09.302"	"Creating session 151"
"IMAPD"	3092	151	"2014-08-01 19:50:09.303"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	960	151	"2014-08-01 19:50:09.358"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	960	151	"2014-08-01 19:50:09.360"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3760	151	"2014-08-01 19:50:09.401"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	3760	151	"2014-08-01 19:50:09.449"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	3760	151	"2014-08-01 19:50:09.491"	"213.151.213.120"	"RECEIVED: 4 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)"
"IMAPD"	3760	151	"2014-08-01 19:50:09.495"	"213.151.213.120"	"SENT: * STATUS "Sent" (MESSAGES 12 UNSEEN 0 RECENT 0 UIDNEXT 13)[nl]4 OK Status completed"
"TCPIP"	3092	"2014-08-01 19:50:09.732"	"TCP - 213.151.213.120 connected to 192.168.1.5:143."
"DEBUG"	3092	"2014-08-01 19:50:09.735"	"Creating session 152"
"IMAPD"	3092	152	"2014-08-01 19:50:09.737"	"213.151.213.120"	"SENT: * OK IMAPrev1"
"IMAPD"	3440	152	"2014-08-01 19:50:09.775"	"213.151.213.120"	"RECEIVED: 1 capability"
"IMAPD"	3440	152	"2014-08-01 19:50:09.776"	"213.151.213.120"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	652	152	"2014-08-01 19:50:09.817"	"213.151.213.120"	"RECEIVED: 3 login "admin" ***"
"IMAPD"	652	152	"2014-08-01 19:50:09.860"	"213.151.213.120"	"SENT: 3 OK LOGIN completed"
"IMAPD"	652	152	"2014-08-01 19:50:09.900"	"213.151.213.120"	"RECEIVED: 4 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)"
"IMAPD"	652	152	"2014-08-01 19:50:09.902"	"213.151.213.120"	"SENT: * STATUS "Sent" (MESSAGES 12 UNSEEN 0 RECENT 0 UIDNEXT 13)[nl]4 OK Status completed"
"TCPIP"	2700	"2014-08-01 19:50:18.110"	"TCP - 213.151.213.120 connected to 192.168.1.5:2525."
"DEBUG"	2700	"2014-08-01 19:50:18.112"	"Creating session 153"
"SMTPD"	2700	153	"2014-08-01 19:50:18.113"	"213.151.213.120"	"SENT: 220 shufflex.info"
"SMTPD"	2700	153	"2014-08-01 19:50:18.158"	"213.151.213.120"	"RECEIVED: EHLO [192.168.1.8]"
"SMTPD"	2700	153	"2014-08-01 19:50:18.159"	"213.151.213.120"	"SENT: 250-mail.shufflex.info[nl]250-SIZE 20480000[nl]250 AUTH LOGIN"
"SMTPD"	2700	153	"2014-08-01 19:50:18.199"	"213.151.213.120"	"RECEIVED: AUTH LOGIN"
"SMTPD"	2700	153	"2014-08-01 19:50:18.200"	"213.151.213.120"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	3468	153	"2014-08-01 19:50:21.725"	"213.151.213.120"	"RECEIVED: YWRtaW4="
"SMTPD"	3468	153	"2014-08-01 19:50:21.726"	"213.151.213.120"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	2700	153	"2014-08-01 19:50:21.767"	"213.151.213.120"	"RECEIVED: ***"
"SMTPD"	2700	153	"2014-08-01 19:50:22.033"	"213.151.213.120"	"SENT: 235 authenticated."
"SMTPD"	2980	153	"2014-08-01 19:50:22.067"	"213.151.213.120"	"RECEIVED: MAIL FROM:<admin@shufflex.info> SIZE=395"
"SMTPD"	2980	153	"2014-08-01 19:50:22.070"	"213.151.213.120"	"SENT: 250 OK"
"SMTPD"	3448	153	"2014-08-01 19:50:22.107"	"213.151.213.120"	"RECEIVED: RCPT TO:<shuffle.team@gmail.com>"
"SMTPD"	3448	153	"2014-08-01 19:50:22.112"	"213.151.213.120"	"SENT: 250 OK"
"SMTPD"	2700	153	"2014-08-01 19:50:22.145"	"213.151.213.120"	"RECEIVED: DATA"
"SMTPD"	2700	153	"2014-08-01 19:50:22.148"	"213.151.213.120"	"SENT: 354 OK, send."
"SMTPD"	2700	0	"2014-08-01 19:50:34.217"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: 120.213.151.213.in-addr.arpa, Type: 12, DnsQuery return value: 1460."
"DEBUG"	2700	"2014-08-01 19:50:34.218"	"Could not get PTR record for IP (false)! 213.151.213.120"
"DEBUG"	2644	"2014-08-01 19:50:34.222"	"Saving message: {EA8E0CEB-0664-4DA4-A97D-AACF1B81EE2E}.eml"
"DEBUG"	2644	"2014-08-01 19:50:34.424"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2644	153	"2014-08-01 19:50:34.425"	"213.151.213.120"	"SENT: 250 Queued (12.074 seconds)"
"DEBUG"	2520	"2014-08-01 19:50:34.465"	"Delivering message..."
"APPLICATION"	2520	"2014-08-01 19:50:34.469"	"SMTPDeliverer - Message 54: Delivering message from admin@shufflex.info to shuffle.team@gmail.com. File: C:\Program Files\hMailServer\Data\{EA8E0CEB-0664-4DA4-A97D-AACF1B81EE2E}.eml"
"DEBUG"	2520	"2014-08-01 19:50:34.470"	"Applying rules"
"DEBUG"	2520	"2014-08-01 19:50:34.471"	"Performing local delivery"
"DEBUG"	2520	"2014-08-01 19:50:34.472"	"Local delivery completed"
"DEBUG"	2520	"2014-08-01 19:50:34.473"	"Performing external delivery"
"SMTPD"	2520	0	"2014-08-01 19:50:34.474"	"TCP"	"DNS - MX Lookup: gmail.com"
"SMTPD"	652	153	"2014-08-01 19:50:34.486"	"213.151.213.120"	"RECEIVED: QUIT"
"SMTPD"	652	153	"2014-08-01 19:50:34.487"	"213.151.213.120"	"SENT: 221 goodbye"
"DEBUG"	960	"2014-08-01 19:50:34.489"	"Closing TCP/IP socket"
"DEBUG"	960	"2014-08-01 19:50:34.490"	"Ending session 153"
"IMAPD"	3760	152	"2014-08-01 19:50:34.559"	"213.151.213.120"	"RECEIVED: 5 append "Sent" (\Seen) {395}"
"IMAPD"	3760	152	"2014-08-01 19:50:34.561"	"213.151.213.120"	"SENT: + Ready for literal data"
"DEBUG"	3748	"2014-08-01 19:50:34.950"	"Saving message: {48A5F0E8-47EE-4804-95BF-4EA3A8102239}.eml"
"IMAPD"	3748	152	"2014-08-01 19:50:35.269"	"213.151.213.120"	"SENT: 5 OK APPEND completed"
"DEBUG"	3236	"2014-08-01 19:50:39.712"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	3236	"2014-08-01 19:50:39.788"	"PersistentMessage::~SetNextTryTime()"
"SMTPD"	2520	0	"2014-08-01 19:50:46.488"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: gmail.com, Type: 15, DnsQuery return value: 1460."
"DEBUG"	2520	"2014-08-01 19:50:46.489"	"Failed to resolve email servers (MX lookup). Domain name: gmail.com."
"APPLICATION"	2520	"2014-08-01 19:50:46.491"	"SMTPDeliverer - Message 54: No mail servers could be found for the address shuffle.team@gmail.com."
"DEBUG"	2520	"2014-08-01 19:50:46.492"	"Collect delivery result"
"DEBUG"	2520	"2014-08-01 19:50:46.493"	"Collect delivery result - Done"
"DEBUG"	2520	"2014-08-01 19:50:46.495"	"SD::_RescheduleDelivery"
"DEBUG"	2520	"2014-08-01 19:50:46.496"	"Retrieving retry options."
"DEBUG"	2520	"2014-08-01 19:50:46.498"	"Starting rescheduling."
"APPLICATION"	2520	"2014-08-01 19:50:46.499"	"SMTPDeliverer - Message 54: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG"	2520	"2014-08-01 19:50:46.500"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	2520	"2014-08-01 19:50:46.572"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-08-01 19:50:46.625"	"Message rescheduled for later delivery."
"APPLICATION"	2520	"2014-08-01 19:50:46.626"	"SMTPDeliverer - Message 54: Message delivery thread completed."
"DEBUG"	240	"2014-08-01 19:50:47.916"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	240	"2014-08-01 19:50:48.201"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-08-01 19:50:48.246"	"Delivering message..."
"APPLICATION"	2520	"2014-08-01 19:50:48.248"	"SMTPDeliverer - Message 54: Delivering message from admin@shufflex.info to shuffle.team@gmail.com. File: C:\Program Files\hMailServer\Data\{EA8E0CEB-0664-4DA4-A97D-AACF1B81EE2E}.eml"
"DEBUG"	2520	"2014-08-01 19:50:48.249"	"Applying rules"
"DEBUG"	2520	"2014-08-01 19:50:48.250"	"Performing local delivery"
"DEBUG"	2520	"2014-08-01 19:50:48.251"	"Local delivery completed"
"DEBUG"	2520	"2014-08-01 19:50:48.253"	"Performing external delivery"
"SMTPD"	2520	0	"2014-08-01 19:50:48.254"	"TCP"	"DNS - MX Lookup: gmail.com"
"SMTPD"	2520	0	"2014-08-01 19:51:00.257"	"TCP"	"DNS - Query failure. Treating as temporary failure. Query: gmail.com, Type: 15, DnsQuery return value: 1460."
"DEBUG"	2520	"2014-08-01 19:51:00.258"	"Failed to resolve email servers (MX lookup). Domain name: gmail.com."
"APPLICATION"	2520	"2014-08-01 19:51:00.259"	"SMTPDeliverer - Message 54: No mail servers could be found for the address shuffle.team@gmail.com."
"DEBUG"	2520	"2014-08-01 19:51:00.260"	"Collect delivery result"
"DEBUG"	2520	"2014-08-01 19:51:00.261"	"Collect delivery result - Done"
"DEBUG"	2520	"2014-08-01 19:51:00.262"	"SD::_RescheduleDelivery"
"DEBUG"	2520	"2014-08-01 19:51:00.263"	"Retrieving retry options."
"DEBUG"	2520	"2014-08-01 19:51:00.264"	"Starting rescheduling."
"APPLICATION"	2520	"2014-08-01 19:51:00.265"	"SMTPDeliverer - Message 54: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"DEBUG"	2520	"2014-08-01 19:51:00.266"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	2520	"2014-08-01 19:51:00.649"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	2520	"2014-08-01 19:51:00.849"	"Message rescheduled for later delivery."
"APPLICATION"	2520	"2014-08-01 19:51:00.850"	"SMTPDeliverer - Message 54: Message delivery thread completed."
Re: Email sending problem
Post by percepts » 2014-08-01 20:09
goto mxtoolbox.com and put in your domain name ( shufflex.info )
when it comes back do the smtp test.
I have done all the test and they are all fine. A couple of warning but nothing that will cause problems.
So it all looks good now.
please run hmail diagnostics. select shufflex.info from left drop down and leave hmailserver.com on right
use copy button after it runs and post results here.
Dvd+rw
Post by Dvd+rw » 2014-08-01 20:13
Test: Collect server details
hMailServer version: hMailServer 5.4.2-B1964
Database type: MySQL
Test: Test IPv6
Test: Test outbound port
Trying to connect to TCP/IP address 46.163.109.39 on port 25.
Connected successfully.
Test: Test backup directory
Backup directory C:\Users\eee\Desktop\hmanil backup 2 is writable.
Test: Test MX records
Trying to resolve MX records for shufflex.info...
ERROR: MX records for domain shufflex.info could not be resolved
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain shufflex.info...
ERROR: MX records for local domain shufflex.info could not be resolved
Post by percepts » 2014-08-01 20:17
ALSO
start windows command prompt and type in
ipconfig /flushdns
and then try sending mail again
AND
do you have a static IP or a dynmaic IP ?
Dvd+rw
Post by Dvd+rw » 2014-08-01 20:21
i have dynamic IP
after flush.. the same error :/
Post by percepts » 2014-08-01 20:30
dynamic is a problem. DNS system resolves to a specific IP and it will change every time you connect so the address of hmailserver changes each time you connect to to ISP. That is BAD BAD BAD.
Best solution is to upgrade to a static IP with your ISP if you want run a mail server otherwise you will need to use another paid for service such as No-IP in which case you must follow their instructions on how to get it working and discuss it with them.
But your hmailadmin settings are now good :D
Dvd+rw
Post by Dvd+rw » 2014-08-02 10:42
my IP change only when i restart my router
thank you very much for your time and advices :)
i think i am coursed and i will never have mail server :D
