PHPWebAdmin for hMailServer Version 5.4.1-B1951
aschinnerl
Post by aschinnerl » 2014-04-21 00:10
Where can i download the PHPWebAdmin for my hMailServer Version 5.4.1-B1951?
A actual become the following error:
The hMailServer version does not match the WebAdmin version.
hMailServer version: 5.4.1-B1951
WebAdmin version: 5.3.3-B1879
Please make sure you are using the PHPWebAdmin version which came with your hMailServer installation.
Is the german language for hMailserver 5.4.1-B1951 also avaliable?
Is it also possible to remove the W003 Configuration Warnings at Server Status?
Thx
Re: PHPWebAdmin for hMailServer Version 5.4.1-B1951
Post by percepts » 2014-04-21 01:11
when you installed 5.4.1-B1951 it should have created folder hmailserver/PHPWebAdmin
that folder should contain the latest files for version 5.4.1-B1951
look at file include_versioncheck.php and it should contain the line:
define('REQUIRED_VERSION', '5.4.1-B1951');
if that is what it says then that is the correct set of files for 5.4.1-B1951
Post by Bill48105 » 2014-04-21 05:18
Did you upgrade to B1951 or did you clean install? The version should auto-update but perhaps it was missed in the b1951 build. Or if you upgraded you would need to replace or edit the version file since upgrading hmail does not upgrade the php admin IN YOUR WEB FOLDER. It just updates the copy in hmail folder.
As far as languages you can get them here:
http://www.hmailserver.com/documentatio ... t_language
http://www.hmailserver.com/devnet/?page ... ion_status
Here is German:
http://www.hmailserver.com/devnet/trans ... age=german
aschinnerl
Post by aschinnerl » 2014-04-21 20:07
Thx, all works fine now.
Is it possible to delete the W003 Errors at the Server status?
I use hmailserver also for an mailrelay.
Post by percepts » 2014-04-21 21:21
not to my knowledge except by setting the relevant setting in protocols / smtp / rfc compliance I think. The message is only a warning not an error.
Post by Bill48105 » 2014-04-21 22:43
aschinnerl wrote:Thx, all works fine now.
Some errors are shown on status screen no matter what. Such as if you follow the directions to add an ip range for webmail. No way to disable or not show them except to 'fix' the problem. If you are OK with what it is warning you about then safe to ignore the error. :)
