Again on ip ranges: help!
rodolfor
Post by rodolfor » 2014-03-04 12:52
I noticed a lot of logs like:
"Client connection from x.x.x.x was not accepted. Blocked either by IP range or by connection limit."
The address x.x.x.x become to my Internet range.
My internet range allow imap, SMTP and pop3 and do not activate Anti-spam nor Antivirus.
I have triple-checked x.x.x.x does not became to an intervae with priorirty higher than Internet.
whath can I do?
thanks
edit: could it be the option "disconnect client after too many invalid commands" ? But this option does not add an ip range?
Hmailserver [lastversion] + MSSQL
Re: Again on ip ranges: help!
Post by percepts » 2014-03-04 14:30
If I have interpreted this correctly, some autobans have been created due to login attempts which have failed.
If the autoban entries ( the ones in Red) are your own IP number then you can just delete them. They only only happen when attempt to autheticate fails x times over a short period of time as per your autoban settings. They will auto clear after a period of time according to your autoban settings but you can manually delete too.
rodolfor
Post by rodolfor » 2014-03-04 16:16
No.
the problem is: I have not autoban in ip ranges, autoban is disabled, antispam is disabled but some clients have "Client connection from x.x.x.x was not accepted. Blocked either by IP range or by connection limit."
I also restarted service
Post by mattg » 2014-03-04 16:23
Well if you don't have autoban enabled, it must be connection limit
On the general tab for each protocol >> Maximum simultaneous connections
rodolfor
Post by rodolfor » 2014-03-05 11:56
one million of thanks matt.
Resolved :D
