Firing Order
limestonecoast
Firing Order
Post by limestonecoast » 2013-09-15 00:56
Does anyone know what order 'checks' are done in Hmail ?
An incoming message sender could be whitelisted, the message could have a rule it meets requirements for or could have VBS that fire when it lands ...
If not an order .. what would take precedence over what?
Thanx in Advance
glenluo
Re: Firing Order
Post by glenluo » 2013-09-15 03:56
You have all the log on,then you can know it
Re: Firing Order
Post by mattg » 2013-09-15 11:06
As GlenLou says this can be found by checking your logs.
Mine does checks in this order (I don't use external SpamAssassin or DKIM checks)
DNS blacklists
Test host in HELO command
Test that sender has MX records
Test SPF record
SURBL servers
OnDeliveryStart()
Message is received
OnAcceptMessage()
Global rules (from top down)
OnDeliverMessage()
Auto Reply - This is then a new message
Account Rules (from top down)
Account Level Forward - Back to Global rules for forward
cblaze22
Re: Firing Order
Post by cblaze22 » 2019-05-07 14:07
Does Global Rules after Accept Message get executed before going in Queue? Also does it have a Message ID at that point?
Re: Firing Order
Post by SorenR » 2019-05-07 15:45
cblaze22 wrote:
2019-05-07 14:07
I believe it has been answered elsewhere.
cblaze22
Re: Firing Order
Post by cblaze22 » 2019-05-07 16:11
What kind of answer is that?
