Mail disappears for one email account
bescher
Post by bescher » 2013-07-23 04:07
Hi all, haven't posted in a while haven't needed to.
Have one account, uses imap generally or webmail.
But suddenly all of his incoming email started disappearing with no in bound email
We watched on webmail where a MSG would come in but then disappear. I figured it was the database so I installed newest version, checked webmail and no messages but all of a sudden squirrel mail is acting like a regular login into a computer
I checked permissions, checked the database was running, sync the database with mail still nothing.
Windows 2003 server
Newest non beta build of hmailserver
Re: Mail disappears for one email account
Post by mattg » 2013-07-23 06:53
G'day Bob,
Are the messages in the data folder?
Sounds like they are being marked for deletion as they arrive, and then Squirrelmail is not displaying them
DO NOT PURGE until you are sure that they are NOT marked for deletion, or they will be deleted
bescher
Post by bescher » 2013-07-23 13:29
Hi
No they are not being marked for deletion
As soo as they are sent they set in the in box for about two seconds then they are gone
All of his sent mails are there
Will double check with him though as I run Trojan horse and antivirus checks
Bob
Post by mattg » 2013-07-23 13:57
Other thought is perhaps some automated client is POPping these mail as well and removing them as soon as they are downloaded. (ie not leaving copy on server)
bescher
Post by bescher » 2013-07-23 14:29
Will check that also but I dot thinks so
Other than squirrell mail, php, and hmailserver those are the only things running on it
