The mail server sent an incorrect greeting: * OK IMAPrev1
Gatzu78
Post by Gatzu78 » 2013-03-02 00:12
Hi Guys,
I have just installed a new server with hmailserver 5.4 - 1946.
I created a self signed certificate and added the ports 993 for IMAPS and 465 for SMTPS.
I can connect with IMAPS, of course I get the exception, but it was expected.
When I try to send mails I get the expetion again, because it is on the SMTPS, but even after I accepted the security exection I get the following error:
An error occurred sending mail: The mail server sent an incorrect greeting: * OK IMAPrev1
If I use the regular port 25 without SSL everything works fine.
Any idea?
Gatzu78
Re: The mail server sent an incorrect greeting: * OK IMAPre
Post by Gatzu78 » 2013-03-02 00:37
I tried to activate logs only for SMTP and DEBUG.
This is the only contents of the log:
"DEBUG" 4576 "2013-03-01 23:31:40.444" "Creating session 71"
"DEBUG" 2460 "2013-03-01 23:31:42.254" "Ending session 71"
dzekas
Post by dzekas » 2013-03-02 07:37
Gatzu78 wrote:Hi Guys,
Any idea?
you setup IMAP service on 465 port and not SMTP. Remove it and setup new SMTP service instance on 465 port. Or you have other service locked on this port.
Gatzu78
Post by Gatzu78 » 2013-03-03 14:16
Thanks,
I am a moron. :?
Post by mattg » 2013-03-04 00:06
We all make those kind of mistakes
Well perhaps not Dzekas, but the rest of do. :)
