Disallow users to send mail to the internet
andydld
Post by andydld » 2013-02-06 15:43
i just played around with rules to disallow some users to send mails outside our mail-domain.
It works great with single recipients, but with more then one recipient (name@ourdomain.tld; name@externaldomain.tld) it doesn't work.
Tested with hMS 5.3.3 (1879) and 5.4 (1945).
I definied a global rule like this:
Criteria: (Use AND)
From - contains - UsersMailAddress
To - Recipient list (tested with "To", too) - Not Contains - @OurMailDomain
Action:
Reply
Delete e-mail
Best regards,
Andy
www.andysblog.de
Re: Disallow users to send mail to the internet
Post by ^DooM^ » 2013-02-06 15:55
Recipient list Not Contains - OurMailDomain
Should work (dont use an @ symbol) and make sure it's a global rule.
andydld
Post by andydld » 2013-02-06 16:10
It's a global rule and with no @-symbol it still not work correctly.
Tested with Thunderbird as mailclient (if that helps).
The order of the recipient-mailaddresses doesn't matter, too.
Tested with:
and
name@externaldomain.tld; name@ourdomain.tld
www.andysblog.de
Post by mattg » 2013-02-07 00:13
andydld wrote:It works great with single recipients, but with more then one recipient (name@ourdomain.tld; name@externaldomain.tld) it doesn't work.
Step through what you are asking...
FROM contains (=match)
Recipient list contains any non-local recipient (=match)
Then
reply and delete email
The only way to achieve the functionality you want for selected senders is via scripts
Here's one I prepared earlier (read the whole thread)
http://www.hmailserver.com/forum/viewto ... =9&t=17190
andydld
Post by andydld » 2013-02-07 09:38
Thanks for the answer.
Well, that's strange (i think), because with single recipients ("To" or "Recipient list") it works, only more then one recipient per mail doesn't work like expected.
Maybe it's a good feature request to add a possibility to accounts configuration to disallow users to send mails outside their own maildomain (like other mailservers do).
www.andysblog.de
Post by mattg » 2013-02-07 11:45
can be achieved with scripting (like most things in hMailsevrer) and a sample script provided.
This is unlikely to be added as a feature request, but if you wish to make a feature request for this, then please do so.
