Instal websitepanel and hmailserver with domain in namechip
logikmkd
Post by logikmkd » 2012-12-15 16:29
I have instal win server 2012 and i install hmail server my domain is on namechip. in my dns a set mx, A etc
but not work ... domain mail is mail.mkdhost.info
logikmkd
Re: Instal websitepanel and hmailserver with domain in namec
Post by logikmkd » 2012-12-15 17:10
help plase!
Conzi
Post by Conzi » 2012-12-15 18:49
A record and mx record are correct.
but when I type "telnet mail.mkdhost.info 25" everything is black...
so, something responds to telnet... but what is it?
logikmkd, inside your lan if you telnet on port 25 (from another computer in lan to mailserver) works correctly?
logikmkd
Post by logikmkd » 2012-12-15 21:52
no when i test mail.mkdhost.info i have this problem
http://mxtoolbox.com/SuperTool.aspx?act ... dhost.info#
logikmkd
Post by logikmkd » 2012-12-15 21:55
in protocol > smtp > routes i crete domain and in general > target smtp host input mail.mkdhost.inf that is corect?
Conzi
Post by Conzi » 2012-12-16 00:32
logikmkd wrote:in protocol > smtp > routes i crete domain and in general > target smtp host input mail.mkdhost.inf that is corect?
no, isn't correct, remove the route.
did you read this?
http://www.hmailserver.com/documentatio ... figuration
logikmkd
Post by logikmkd » 2012-12-16 01:29
yes i read this tutorial.
Conzi
Post by Conzi » 2012-12-16 03:29
logikmkd
Post by logikmkd » 2012-12-16 15:50
how to test
Conzi
Post by Conzi » 2012-12-16 22:44
from another computer in lan open prompt command and type:
telnet [local_ip_address_mailserver] 25
without bracket...
press enter and post the result..
logikmkd
Post by logikmkd » 2012-12-17 00:23
telnet : The term 'telnet' is not recognized as the name of a cmdlet, function, script file, or operable program. Check
the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ telnet 92.53.31.22 25
+ CategoryInfo : ObjectNotFound: (telnet:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
random
Post by random » 2012-12-17 00:39
logikmkd wrote:telnet : The term 'telnet' is not recognized as the name of a cmdlet, function, script file, or operable program.
plz try it with cmd.exe, not powershell.
telnet is an "old fashion" command line tool. :)
Or use 64-bit powershell, telnet seems only be unknown by powershell x86.
lg
random
logikmkd
Post by logikmkd » 2012-12-17 01:14
also in cmd not work
random
Post by random » 2012-12-17 01:30
Sorry, I didn't realize that you are using Windows Server 2012.
In W2k8R2 you have to install the telnet client using the server manager ->features.
Don't know server 2012, may have changed.
lg
random
logikmkd
Post by logikmkd » 2012-12-17 02:04
ok, when input telnet mail.... 25
print
220 hello
DavidB
Post by DavidB » 2012-12-31 04:28
so Hmail is responding internally, now try the same from outside your network
logikmkd
Post by logikmkd » 2013-01-03 17:29
ok, thanks!!!
