password change plugin issue
amjath
Post by amjath » 2012-12-13 06:57
I have installed hmail server 5.3.3 in windows 2008 R2 Server. Mysql is connected from different machine and squirrel mail is installed in another machine (1.4.22).
I have added password change plugin in squirrel mail. But it is throwing the below error while changing the password
DCOM error
Source: hMailServer COM library Description: You do not have access to this property / method. Ensure that hMailServer.Application.Authenticate() is called with proper login credentials.
I have followed the below link in hmail server(windows 2008 R2). But no hope
http://www.hmailserver.com/documentatio ... ermissions
If we install hmail and squirrel mail in same machine, it works perfectly.
Please help me to sort out the issue.
hmailserver_changepass.zip
(10.91 KiB) Downloaded 162 times
Re: password change plugin issue
Post by mattg » 2012-12-13 09:55
DCOM normally only works from the local machine that hMailserver is installed on
http://www.hmailserver.com/documentatio ... ter_remote
amjath
Post by amjath » 2012-12-13 16:14
Thanks a lot for the help,
I have done as you said, now the error is changed as below
DCOM error
Source: Unknown Description: Unknown
please help
dzekas
Post by dzekas » 2012-12-14 21:44
2008 R2 is pure 64bit server. hMailServer is 32bit. Are you sure that you can even launch 32bit DCOM application on 64bit OS DCOM environment?
mira.baka
Post by mira.baka » 2013-01-09 00:19
dzekas wrote:2008 R2 is pure 64bit server. hMailServer is 32bit. Are you sure that you can even launch 32bit DCOM application on 64bit OS DCOM environment?
Hi, I have also W2008R2 x64 with hmailserver installed. DCOM works fine.
amjath I believe the issue is in PHP version. I had the same problem with Roundcube hmail_password plugin after update from PHP 5.3.10 to 5.3.16. I had to switch back to 5.3.10 to make it work. You will find many post about DCOM/PHP version issue.
Good luck.
MehmetDelen
Post by MehmetDelen » 2013-04-28 17:38
Why we're doomed to something.
problems that do not fit the version of php.
2008 does not allow authentication problems.
I need to do to overcome them in a software.
Or should not be dependent on so many other software.
For those of you windows 2008 R2 64-bit is not enough.
