One of the user complains about locked account. He uses mobile devices & desktop and I discovered his network connection is not stable.
That user calls me at every lock and complains about our servers, etc. -because previous mail server software hasn't a lock feature and he had no issues-
How does lock mechanism work? QUIT command unlocks the account? Isn't there any timeout to unlock his account? Or what can I do?
Thanks.
Account locked - again & again
Re: Account locked - again & again
RFC's state only 1 connection per account is allowed when using the POP3 Protocol. If the user has multiple devices connecting to the same account he must use IMAP.
As DooM said IMAP is best option for shared access of a box but there are also work-arounds if IMAP is not possible/desired. One trick I use is a 'mirror' box. Say you have bob@yourdomain.com. You create a box like bob2@yourdomain or bobmobile@ etc. Then you setup a forward & keep copy on bob to bob2. Now you can 2 boxes that get all emails, just make sure you setup the LOGIN as bob2 but have the from email & replyto set as bob so it looks like they are sending from the real box & not the mirror one. Another trick would be to adjust the POP timeout in the hmailserver INI file to something lower so you're less likely to need to wait for the timeout. Granted hmail uses RFC recommended timeout but IMO for POP where there is no public use it should be up to the admin. Just don't complain if you have issues.
Or of course it is safe to just ignore the already locked errors & set your clients to check less frequently as they don't really hurt anything.. They are more of a notice saying 'hey the box is busy right now come back later'.
Ps. Yes once client sends QUIT the box is unlocked. What we see sometimes is bad client or poor connection means QUIT never makes it so then a timeout is needed before it gets unlocked which by default is like 1/2 hr. That's why the INI setting for POP timeout might be a good option if you can't do IMAP.
Thanks for the replies and I found this link http://www.hmailserver.com/forum/viewto ... ut#p140240
Same here, the user uses Apple products, that's what I guessed and adviced him to turn off the devices and test the connectivity.
I can confirm this behaviour, all of my customers with apple devices get mailbox locked messages when checked the emails on say outlook. Swapping the Apple devices to IMAP fixes the problem 100% of the time.
Never had the problem with android devices though.
Suggestion: POP on PC/Laptop, keep on server for 7 days, IMAP on iPhone/iPad Works every time for me.
Sounds like Apple isn't properly QUIT'ing which is against RFC's. While one could set the pop timeout to a shorter time (against rfc's as well) in reality it's unsafe to assume client is done without a proper QUIT.DavidB wrote:I can confirm this behaviour, all of my customers with apple devices get mailbox locked messages when checked the emails on say outlook. Swapping the Apple devices to IMAP fixes the problem 100% of the time.
That being said I've done extensive testing & have many clients who use iCrap and have had maybe 1 or 2 cases of locked boxes IN TWO YEARS. So it makes me wonder what the differentiating factor is since it's certainly not POP vs IMAP. (Understand though that POP spec has locking mechanism & IMAP doesn't so that obviously means POP is AT RISK of stuck-lock but doesn't explain why only some users have issues & MANY others do not)
In the end anyone with unreliable connection (especially mobile) or who run into these locking issues should highly consider using IMAP.
