PhP 5.4.5 and phpwebadmin
bagu
Post by bagu » 2012-08-09 15:26
If you use php 5.4.5 and see something like :
PHP Fatal error:  Class 'COM' not found in \phpwebadmin\initialize.php on line 13
You must add :
[PHP_COM_DOTNET]
extension=php_com_dotnet.dll
In your php.ini and reload the config.
yon
Re: PhP 5.4.5 and phpwebadmin
Post by yon » 2012-09-27 13:12
thanks.
but it still not normal work.
Failed to create COM object `hMailServer.Application':
This problem is often caused by DCOM permissions not being set.
Post by Bill48105 » 2012-09-27 14:03
yon wrote:thanks.
Looks like different error & likely different problem yon.. Is your script set to login properly? (Correct username & password)
You should start your own thread if you need further help though if your problem isn't related to the OP..
Thx
yon
Post by yon » 2012-09-27 15:45
I am using IIS7.5 +hmail 5.4.1944. I have added
Code:
[PHP_COM_DOTNET]
I can't open the PHPWebAdmin show wrong:
this documentation not work for IIS7.5
http://www.hmailserver.com/documentatio ... ermissions
dzekas
Post by dzekas » 2012-09-27 17:36
yon wrote:this documentation not work for IIS7.5
Which system account you added to hMailServer's DCOM object permissions?
yon
Post by yon » 2012-09-28 05:16
everyone
dzekas
Post by dzekas » 2012-09-28 17:10
everyone
Could you show screenshot of DCOM permissions window and your phpinfo (http://www.php.net/phpinfo) output? Remove all private information. Could you provide more details about your system? OS version, service pack level and platform (x86 or x86_64)
yon
Post by yon » 2012-09-29 12:23
OK
yon
Post by yon » 2012-09-29 12:24
OK.
yon
Post by yon » 2012-09-29 12:25
dzekas
Post by dzekas » 2012-09-29 12:51
You have com.allow_dcom disabled in php configuration
yon
Post by yon » 2012-09-29 15:17
dzekas wrote:You have com.allow_dcom disabled in php configuration
I have try close php.in disable_functions, but hmail web admin still can't normal open.
dzekas
Post by dzekas » 2012-09-29 15:20
Please set com.allow-dcom option to 1 in your php.ini file and recheck phpinfo output. If com.allow-dcom option will remain set to 0, restart your web service.
yon
Post by yon » 2012-09-29 16:20
I do it. but it is not normal work.
Failed to create COM object `hMailServer.Application': 拒绝访问。
dzekas
Post by dzekas » 2012-09-29 16:39
yon wrote:I do it. but it is not normal work
Ok. Next step.
You have Network service and IUSR listed in your permissions window
http://www.hmailserver.com/forum/downlo ... d=1429&t=1
What permissions are set for Network service and IUSR accounts? They have higher priority than "everyone" and it does not matter what you set for "Everyone" account as your PHP 5.4 runs on "Network service" or "IUSR" account.
yon
Post by yon » 2012-09-29 16:58
ok.
dzekas
Post by dzekas » 2012-09-30 14:54
How did you register hMailServer COM object in your setup? Win2008R2 is 64bit only and hMailServer COM object is not displayed in Components manager after default installation.
dzekas
Post by dzekas » 2013-01-03 20:09
janifier kim wrote:
dzekas wrote:How did you register hMailServer COM object in your setup? Win2008R2 is 64bit only and hMailServer COM object is not displayed in Components manager after default installation.
I used it on 32bit and 64bit both were fine
Windows 2008 R2 server is not available in 32bit to public. Could you doublecheck my question. It list very specific Windows release.
yon
Post by yon » 2013-05-04 16:44
what's mean? I am use default install hmail server.
:roll:
yon
Post by yon » 2013-06-28 14:51
still not normal work... :(
