Backup MX and Mail Relay
aschinnerl
Post by aschinnerl » 2012-05-23 22:55
I have installed hmailserver and everything works fine.
Now i have got a few questions - is it Possible to use hMailServer as a Backup MX for other Mailserver?
I also tried to configure hmailserver, so that it is possible to use hmailserver as mail relay for other Servers without authentication, put only for one ip adresse! Now worry i know what no authentification for spammers means.
Re: Backup MX and Mail Relay
Post by mattg » 2012-05-24 07:48
MX Backup >> http://www.hmailserver.com/documentatio ... _mx_backup
relay>> yes this is possible.
Use an IP range to achieve this.
test using open relay >> http://www.hmailserver.com/documentatio ... elay_tests
aschinnerl
Post by aschinnerl » 2012-05-24 12:56
Thank you for your Email.
Is it possible to configure the backup mx for more Domains at one domain.
I mean the domain server name ist test.yxz.com, and this one receives emails for the domains abc.com, bcd.com and so on?
Post by mattg » 2012-05-24 14:26
yes that is possible
aschinnerl
Post by aschinnerl » 2012-05-24 16:09
Hi, thanks.
Happens this automaticly or have i configure for each domain a route?
Post by mattg » 2012-05-25 01:49
How could hMailserver know to do this automatically?
You will need to configure for each domain a route
