SENT: 550 Delivery is not allowed to this address
Matt.Paisley
Post by Matt.Paisley » 2011-11-05 02:02
When I attempt to send and email I get the above message on my client and it also appears in the logs.
Any help will be greatly appreciated.
Regards,
Matt Paisley
armo
Re: SENT: 550 Delivery is not allowed to this address
Post by armo » 2011-11-05 03:18
Looks like authentication problem. Make sure that your client is configured properly to authenticate against the smtp server (hmailserver).
Post by ^DooM^ » 2011-11-05 13:25
Please show diagnostics and enable SMTP logging, replicate the issue, then post the log.
Matt.Paisley
Post by Matt.Paisley » 2011-11-07 17:12
HERE IS THE LOGS THAT DOOM REQUESTED. IT APPEARS THAT I AM AUTHENTICATING, THE MESSAGE IS RECEIVED, BUT CAN'T BE DELIVERED. ..... REGARDS. MATT.
"DEBUG" 6412 "2011-11-04 19:50:57.278" "Creating session 21"
"SMTPD" 6412 21 "2011-11-04 19:50:57.278" "127.0.0.1" "SENT: 220 localhost ESMTP"
"SMTPD" 7104 21 "2011-11-04 19:50:57.278" "127.0.0.1" "RECEIVED: EHLO kofax-1"
"SMTPD" 7104 21 "2011-11-04 19:50:57.278" "127.0.0.1" "SENT: 250-localhost[nl]250-SIZE 20480000[nl]250 AUTH LOGIN"
"SMTPD" 7104 21 "2011-11-04 19:50:57.278" "127.0.0.1" "RECEIVED: AUTH login ZGVtby51c2VyQGtvZmF4ZGVtby5jb20="
"SMTPD" 7104 21 "2011-11-04 19:50:57.278" "127.0.0.1" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 6320 21 "2011-11-04 19:50:57.278" "127.0.0.1" "RECEIVED: ***"
"SMTPD" 6320 21 "2011-11-04 19:50:57.278" "127.0.0.1" "SENT: 235 authenticated."
"SMTPD" 7104 21 "2011-11-04 19:50:57.278" "127.0.0.1" "RECEIVED: MAIL FROM:<MortgageMessenger@kofaxdemo.com>"
"SMTPD" 7104 21 "2011-11-04 19:50:57.278" "127.0.0.1" "SENT: 250 OK"
"SMTPD" 6320 21 "2011-11-04 19:50:57.278" "127.0.0.1" "RECEIVED: RCPT TO:<Demo.User@kofaxdemo.com>"
"SMTPD" 6320 21 "2011-11-04 19:50:57.278" "127.0.0.1" "SENT: 550 Delivery is not allowed to this address."
"DEBUG" 6320 "2011-11-04 19:50:57.278" "Deleting message file"
"DEBUG" 6320 "2011-11-04 19:50:57.278" "Ending session 21"
Post by ^DooM^ » 2011-11-07 17:55
http://www.hmailserver.com/documentatio ... sages_smtp
This error means that the sender is trying to send an email to an address which he is not allowed to send to. This message is generated after hMailServer has checked the IP range settings. As an example, the default IP range configuration does not allow external users to send messages to other external users. This is to prevent people from using your server to send spam. So if an external user tries to send a message to another external user, he will get this message.
In other words You are trying to send from an account that does not exist on your mailserver. You logged in as demo.user@kofaxdemo.com so that account is legitimate but you are trying to send as MortgageMessenger@kofaxdemo.com which is not an account on your server.
armo
Post by armo » 2011-11-07 18:24
I'm a bit confused here, is that domain (kofaxdemo.com) a local domain on hmailserver? Are you trying to relay?
