Rule to forward all emails from one domain to an account
FiShBuRn
Post by FiShBuRn » 2011-07-08 13:55
hey,
Ive created a rule to forward all email from a specific domain like @testforward.com to a specific account but the problem is that the rule creates a loop reciving 5 equal emails on that specific account.
Example:
TO contains @testforward.com forward email to xpto@anotherlocaldomain.com
I dont understand why the loop is created...
Any help is welcome.
Thanks in advance
Re: Rule to forward all emails from one domain to an account
Post by Bill48105 » 2011-07-08 14:12
Setting up the 2nd domain as a domain alias ("Names" tab) won't work?
And the loop occurs because whatever criteria you are testing matches the result as well.
FiShBuRn
Post by FiShBuRn » 2011-07-08 15:12
For this case no, it was like a "unique" request from administration.
Yes, but i send a email to fishburn@testforward.com and the xpto@anotherlocaldomain.com recieves like 5 equal emails, i think this is weird and makes no sense i guess :s
Is there another way to do this?
Edit: I could add the email in forward tab but the user would see this setting and that is not very good....:s and i could not forward email sent just recevied.
Post by Bill48105 » 2011-07-08 15:41
So this is for 1 address not an entire domain? We'd need to see your rule settings/values..
FiShBuRn
Post by FiShBuRn » 2011-07-08 15:44
thanks bill for your helping :)
One address will recieve all sent and recieve mails from a specific domain.
Ive posted and example, it works but enter in a loop.
Post by ^DooM^ » 2011-07-08 16:37
You need to add a second criteria
From not contains forward@emailaddress.com
Post by Bill48105 » 2011-07-08 17:07
^DooM^ wrote:You need to add a second criteria
And stop rule processing as action I'd assume.
dzekas
Post by dzekas » 2011-07-08 17:11
Why are you using rules? What's wrong with catchall?
FiShBuRn
Post by FiShBuRn » 2011-07-08 18:17
dzekas wrote:Why are you using rules? What's wrong with catchall?
I think with catchall i only getting the messages to unknow email address.
dzekas
Post by dzekas » 2011-07-08 18:48
how about http://www.hmailserver.com/documentatio ... nce_mirror
FiShBuRn
Post by FiShBuRn » 2011-07-08 20:27
that will mirror all domains :/ but thanks anyway...
Post by mattg » 2011-07-11 01:13
FiShBuRn
Post by FiShBuRn » 2011-07-11 15:24
I know mattg im only trying to figure out my problem with hmail crashing and then i will have a look at this...its secundary for now.
Post by Bill48105 » 2011-07-11 16:20
FiShBuRn wrote:I know mattg im only trying to figure out my problem with hmail crashing and then i will have a look at this...its secundary for now.
You consider screwy rules could somehow be cause of your crashes? You certainly have something odd going on there. ;)
mirfan
Post by mirfan » 2013-08-12 15:16
Hi FiShBuRn,
Try changing "Rule loop Limtt" in SMTP settings .. default it is set to "5"
Open Hmail Server > Settings > Protocol > SMTP > Advanced = Other ->Rule loop Limit '5'
Read below or visit url for more information:
Rule loop count
This option lets you prevent hMailServer from creating endless message delivery loops. As an example, it's possible to set up an account rule that forwards message from one user (UserA) to another (UserB), and then another rule that forwards the message back from UserB to UserA. To prevent this from resulting in an endless loop, hMailServer limits the number of automatic forwards to the value defined by Rule loop count. (hMailServer 4.2 and later.)
http://www.hmailserver.com/documentatio ... rence_smtp
Irfan
