MS Outlook 2010
mns17
MS Outlook 2010
Post by mns17 » 2010-09-21 10:16
Hi, all.
hMailServer 5.3.3 - Build 1879 + Outlook 2010 + IMAP + SSL + 993 port + #Public = dont sinhroniz a folders.
hMailServer 5.3.3 - Build 1879 + Outlook 2010 + IMAP + 143 port + #Public = dont sinhroniz a folders.
hMailServer 5.3.3 - Build 1879 + Outlook 2003 + IMAP + SSL + 993 port + #Public = OK
hMailServer 5.3.3 - Build 1879 + Outlook 2003 + IMAP + 143 port + #Public = OK
hMailServer 5.3.3 - Build 1879 + Outlook 2007 + IMAP + SSL + 993 port + #Public = OK
hMailServer 5.3.3 - Build 1879 + Outlook 2007 + IMAP + 143 port + #Public = OK
Do you know, why ?
Re: MS Outlook 2010
Post by ^DooM^ » 2010-09-21 10:38
Enable IMAP logging only.
Clear the log file.
Replicate the issue with 2007 and 2010 then see what if anything is different between the two log files.
