SENT: 535 Authentication failed. Restarting authentication p
I have setup Hmail on a system. I can send a message from my client to his mail server (and through my own hmail server) and some messages go through to some of his clients. But one of his clients everytime I send a message we get the following error message.
I can't figure it out. works fine in most time but it seems only to this client (who is the owner of the mail server by the way
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "SENT: 220 Welcome to OBC Mail Services"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "RECEIVED: EHLO pop.rsegroup.com"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "SENT: 250-obc3.footsoport.com[nl]250-SIZE[nl]250 AUTH LOGIN"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "RECEIVED: AUTH LOGIN"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "RECEIVED: d2VzQG9jb25vbW93b2Mtd2kuY29t"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "RECEIVED: ***"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "RECEIVED: QUIT"
"SMTPD" 2284 48555 "2009-09-16 02:48:54.617" "63.131.81.207" "SENT: 221 goodbye"
Re: SENT: 535 Authentication failed. Restarting authentication p
If a SMTP client authenticates but the username or password is incorrect, or the account is disabled, hMailServer sends this error message to the client.
Is the address below spelt correctly? is that hyphen supposed to be in there?
wes@oconomowoc-wi.com
Yes the hyphen is supposed to be there.
I am wondering why it needs authentication since I am sending email to wes@oconomowoc-wi?
(I have hmail also and is the pop.rsegroup.com in the message)
and have no problems
I also don't have issues sending mail to anyone else on his server only to that one account
What do you mean you wonder why it needs authentication?
Is that domain on your mail server? Is the account wes disabled?
No the domain oconomowoc-wi is on his mail server. All I am trying to do is send a email to him
so it would be external to local (on his server) which requires no authentication. But it is rejecting it for authentication.
Below is the bounce header I get back from his mail server
Sent: Wed, 16 Sep 2009 07:14:15 -0500
Subject: Re: Fwd: Delivery Failure from David Campbell
Error Type: SMTP
Remote server (67.*.*.*) issued an error.
hMailServer sent: <Password removed>
Remote server replied: 535 Authentication failed. Restarting authentication process.
Error Type: SMTP
Perhaps the settings at the recipient end have been changed from default, and external to local now does require authentication.bescher wrote:so it would be external to local (on his server) which requires no authentication. But it is rejecting it for authentication.
The recipient server should enable all logging, you should re-create the issue, and the recipient server should post their logs here (if indeed the recipient server is a hMailserver install).
Can I ask if he is using hMs on the backup server as well ?bescher wrote: Remote server replied: 535 Authentication failed. Restarting authentication process.
Is his mailserver the hMail server your looking at the logs from? If that domain is not on hMail server why are you trying to authenticate using that domain?No the domain oconomowoc-wi is on his mail server.
We figured it out. I was his backup mail server and I accidently told the mail server(mine) that it needed authentication to send to that specific domain. Once I unchecked that it was fine
Thanks everyone
Thanks everyone
- New user
i am also facing same problem i am sending the mail from one our PLM system in plm log it is showing 535 authentication is required, and in hmail server log it is showing authentication failed restarting authentication process can any one help me.
Thanks & Regards
Gourav Upadhyay
Thanks & Regards
Gourav Upadhyay
PLEASE START A NEW THREAD
My guess is that you are using username in the form 'user' when you should be using 'user@example.com'
PLEASE START A NEW THREAD and show logs plus the results of this >> viewtopic.php?f=20&t=30914
- jimimaseye
- Moderator
(My guess that he is one of our regular spam posters building himself a posting reputation for advertising and spamming. Never had a genuine poster from India that isnt. The 'ban hammer' is polished and ready to fall....)mattg wrote:PLEASE START A NEW THREAD
How to start a new thread, you mean that restart hmailserver service on windows?
ON THIS FORUM
Go to General Discussion then press the NEW TOPIC button
PLEASE STOP re-using old threads.
PLEASE START a new FORUM thread for your questions
(Forth time you have been asked)
The current state of tech support. Heh.jimimaseye wrote: ↑2017-11-24 09:34Never had a genuine poster from India that isnt. The 'ban hammer' is polished and ready to fall....)
Let the hammer fall with maximum energy.
