4GB Limit of Microsoft SQL Server Mobile Edition
Melibokus73
Post by Melibokus73 » 2009-07-16 15:28
What happens if I some time reach the internal 4GB limit of the default Microsoft SQL Server Mobile Edition included in hMailServer 5.x
Does somthing bad happen? Do I get a warning before ?
Keba
Re: 4GB Limit of Microsoft SQL Server Mobile Edition
Post by Keba » 2009-07-16 15:57
Given the database holds meta data and not the actual messages (they are stored on disk as individual files) you will be very hard pressed to reach the 4 Gb limit...
Normal operational monitoring should be put in place if you are creating that much database information, and that would catch the database growing near its limit. You could then 'upgrade' to a database engine that doesn't have a 4 Gb limit I guess.
Keba
Melibokus73
Post by Melibokus73 » 2009-07-16 16:14
Keba wrote:Given the database holds meta data and not the actual messages (they are stored on disk as individual files) you will be very hard pressed to reach the 4 Gb limit...
I did read that this 4GB should be reached with about 10Million Mails. In a office with some users that should be not a so far Limit.
How do I have an easy look how big or full my SQL database is?
Post by martin » 2009-07-16 16:19
Use a "real" edition of Microsoft SQL Server if you expect to store more than a million messages on the server.
To determine the database size, look at the SDF file in the \hMailServer\Database folder.
Melibokus73
Post by Melibokus73 » 2009-07-21 08:38
martin wrote:Use a "real" edition of Microsoft SQL Server if you expect to store more than a million messages on the server.
OK .. but I plan to use MySQL.
Some (Dummy) questions ;-)
What should I use as Database engine? MyISAM or InnoDB ? and what default Characterset ?
Post by ^DooM^ » 2009-07-21 09:29
Depends how busy your server will be.
Shiloh wrote:Generally speaking, either use MSSQL2005 or MySQL5 with InnoDB style tables. Either of those will perform well. Just pick the one you have the most experience using. If you use MySQL, do not use MyISAM style tables, because those do table level locking. Table level locking is great for small tasks, but does poorly on large DBs. If you use MyISAM tables, you will wish you had used InnoDB at some point in time as your DB grows. So use InnoDB when you start if you use MySQL.
Post by martin » 2009-07-21 10:45
If you're using MySQL, use InnoDB. Do not use MyISAM.
Even if performance isn't a problem, MyISAM tables does not support database transactions. hMailServer uses database transactions when updating the database to newer versions. Without transactions, there's a risk that the database gets in a state between two different versions. Of course, backups should always be taken prior to upgrading but still..
