Is there a solution to delete all mails received in Turkish, Chinease and others non-european alphabet ? They are always spams....
Thank you
Thomas
filter to delete mail not in English/French...
- Normal user
- Contact:
Interrested by Law & new technologies ?
Intéressé par le droit de l'internet et des nouvelles technologies ?
Visit/Visitez http://www.droit-technologie.org
Re: filter to delete mail not in English/French...
You could check for specific charsets in the header and delete with a rule using custom header field.
- Normal user
- Contact:
I tried as follow on this image. I'm not sure it works fine.^DooM^ wrote:You could check for specific charsets in the header and delete with a rule using custom header field.
Can you confirm ?
Tx
Thomas
Are you still receiving emails with that content type?
- Normal user
- Contact:
yes because I also discover that charset header is not often present in mail's header ! sometimes this is in the mail's body:^DooM^ wrote:You could check for specific charsets in the header and delete with a rule using custom header field.
I've maybe to add others filters for body's messageReturn-Path: <urzalezzetavi@gmail.com>
Received: from pc.local ([78.188.138.135])
by serveur.maxetzoe.com
with hMailServer ; Thu, 4 Dec 2008 05:47:16 +0100
Received: from pc.local[127.0.0.1] by pc.local[127.0.0.1]
(SMTPD32); Thu, 4 Dec 2008 06:47:10 +0200
Reply-To: urzalezzetavi@gmail.com
Message-ID: <616d050fa5ce5a311792a9731fb8821d@gmail.com>
From: "=?iso-8859-9?B?VVJaQSAgQef9bGT9Li4=?=" <urzalezzetavi@gmail.com>
To: <thomas -at- parvais.com>
Subject: =?iso-8859-9?B?VVJaQSAgQef9bGT9Li4=?=
Date: Thu, 4 Dec 2008 06:45:28 +0200
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=SPLITOR00A_001_21662953D"
This is a multi-part message in MIME format.
------=SPLITOR00A_001_21662953D
Content-Type: text/plain;
charset="iso-8859-9"
I'll try
Thomas
it is in the From line as well by the looks.
