DB setup step 6
Jdinaparek
DB setup step 6
Post by Jdinaparek » 2013-04-22 15:41
Hi, I have this error:
Starting task...
Please wait while updating database settings...
Error:
The MySQL client (libmysql.dll, 32 bit) could not be loaded.
hMailServer needs this file to be able to connect to MySQL.
The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.
Path: C:\Program Files (x86)\hMailServer\Bin\libmysql.dll
I tried to copy my libmysql.dll file from bin forlder of my MySQL, but it didn't help... Can you help me?
Re: DB setup step 6
Post by Bill48105 » 2013-04-22 16:04
Looks like you're on 64bit windows. Did you try the 64bit mysql dll? hmail is 32bit but you need to match your OS
Jdinaparek
Re: DB setup step 6
Post by Jdinaparek » 2013-04-22 16:22
Yeah I have 64 bit OS. So I have to download 32 bit dll file from internet or what? The one that I have there now is from MySQL, which run on the same PC
Re: DB setup step 6
Post by mattg » 2013-04-22 16:29
Jdinaparek wrote:Yeah I have 64 bit OS. So I have to download 32 bit dll file from internet or what?
Yes, and the error message tells you that
There are some copies saved on these forums so do a search
we are not allowed to include it because hMailserver 5.x <5.4 wasn't open source and it was against the EULA of MySQL to include the 32 bit dll
Jdinaparek
Re: DB setup step 6
Post by Jdinaparek » 2013-04-23 09:49
I download it from here http://vertstudios.com/blog/libmysqldll ... -download/ and now I get error:
Starting task...
Settings updated.
Restarting server...
Database initialization failed.
Jdinaparek
Re: DB setup step 6
Post by Jdinaparek » 2013-04-23 16:52
Does anyone have libmysql.dll for 32 bit OS? It seems like this one doesn't work...
Re: DB setup step 6
Post by mattg » 2013-04-24 01:24
