dzekas wrote:
Maikl wrote:
Any other ideas around here?
Please provide more details about your setup. OS, IIS and PHP versions, used PHP setup (ISAPI, CGI or other).
Win 2k3 SP 2 (Windows NT 5.2 build 3790)
IIS 6
PHP 5.2.6
ISAPI
Here is the result of my configtest:
SquirrelMail configtest
This script will try to check some aspects of your SquirrelMail configuration and point you to errors whereever it can find them. You need to go run conf.pl in the config/ directory first before you run this script.
SquirrelMail version: 1.4.16
Config file version: 1.4.0
Config file last modified: 18 October 2008 09:08:31
Checking PHP configuration...
PHP version 5.2.6 OK.
display_errors:
error_reporting: 6143
variables_order OK: GPCS.
PHP extensions OK. Dynamic loading is enabled.
Checking paths...
Data dir OK.
Attachment dir OK.
Plugins are not enabled in config.
Themes OK.
Default language OK.
Base URL detected as: *** removed *** (location base autodetected)
Checking outgoing mail service....
SMTP server OK (220 HELO FROM *** REMOVED ***)
Checking IMAP service....
IMAP server ready (* OK IMAPrev1)
Capabilities: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT
Checking internationalization (i18n) settings...
gettext - Gettext functions are available. On some systems you must have appropriate system locales compiled.
mbstring - Mbstring functions are available.
recode - Recode functions are unavailable.
iconv - Iconv functions are available.
timezone - Webmail users can change their time zone settings.
Checking database functions...
not using database functionality.
Congratulations, your SquirrelMail setup looks fine to me!
Still... I cannot login. I know this is not the squirrelmail site, but I cannot find a forum there. I (think I) did everything I found there, but it still does not work. I'm a bit frustrated, and I hope to find a solution here as I have the idea that here are some people who can help. Thanks very much for your understanding...
(Anyway, I would prefer a webmail solution that runs under ASP.Net. I don't have too much experience with PHP... so if anyone knows something, I would be thankful - most preferred would be a DNN module)
Anything else? Thanks for the help...
Michael
