SA temp files under Windows-Temp Folder
thomas10
Post by thomas10 » 2020-10-06 08:39
Hi All,
I found that there are a lot of SA temporary files under Windows- Temp folder with the name such as .spamassassin-3836lxD7Fatmp, .spamassassin-4600XKpxQStmp, etc.
Some files have old modified date which seems didn't being removed. :?
Can I clear them manually? or is there any kind of .bat code that can be scheduled to run by Task Scheduler?
Re: SA temp files under Windows-Temp Folder
Post by mattg » 2020-10-07 10:59
yes you can clear them manually (unless they are for NOW)
thomas10
Post by thomas10 » 2020-10-08 06:20
2020-10-07 10:59
ok, Thanks for clarfying. I found these old temp files when I ran full scan using antivirus software and it detected that there were some of these files infected. Cool, I will delete them and only keep the today's temp file. :lol:
Thanks again.
Post by mattg » 2020-10-09 03:21
That might be why they were still there
The AV may have scanning the file a SpamAssassin was dealing with it, and it got 'locked' by the AV
