Spam Mail not detected by SpamAssassin
LVTS
Post by LVTS » 2019-05-31 20:28
Hello there,
I have recently installed SpamAssassin on my server. This has been working perfectly and blocking spam. however, I recently received a spoofed email from myself.
The actual contents of the email in this specific case was actually an image, and therefore is this the reason that it was not detected as spam? Here is the record when I view the source of the email:
Return-Path: charlie@skypoints.cn
X-Spam-Checker-Version: SpamAssassin 3.4.2 (svnunknown) on
	WIN-B38K5UG15FK.LVNET.NET
X-Spam-Level: *
X-Spam-Status: No, score=1.1 required=5.0 tests=DKIM_SIGNED,DKIM_VALID,
	HTML_IMAGE_ONLY_04,HTML_MESSAGE,LOCALPART_IN_SUBJECT,SPF_HELO_PASS,
	TVD_SPACE_RATIO autolearn=no autolearn_force=no version=3.4.2
Received: from Skypoints.cn (skypoints.cn [121.196.233.78])
Many Thanks.
Re: Spam Mail not detected by SpamAssassin
Post by palinka » 2019-06-01 00:05
When everything else is good (spf pass in this case), there's not much else to score. If it came from an actual spammer, the likely would be other rule hits, like helo not matching, relay in blacklist, etc.
There was a recent discussion on the spamassassin mail list about the possibility of OCR'ing the image for text rule hits but it was determined that it's just not worth the effort and cpu cycles to do the OCR.
LVTS
Post by LVTS » 2019-06-01 09:37
The email was completely spoofed and looked like it came from my own Email Address.
Post by RvdH » 2019-06-01 13:18
In that case you should require SMTP authentication for "Local to local e-mail addresses" for the "Internet" range, which is the default i believe....don't touch anything you don't know anything about :!:
Post by jimimaseye » 2019-06-01 13:26
2019-06-01 13:18
He already has. https://www.hmailserver.com/forum/viewt ... 09#p212209
I don't think we can judge this based on the headers he had shown, we need all the headers.... and an ideas of what his domain is.
Post by RvdH » 2019-06-01 13:28
2019-06-01 13:26
Than it couldn't have come from his own Email Address, spoofed or not...
Post by palinka » 2019-06-01 22:22
I get spoofed messages all the time.
"My Real Name" <randomuser@somespamdomain.com>
As Jimi said, we need all the headers.
Post by RvdH » 2019-06-02 02:09
What?
Your name can be spoofed...sure...but you are a fool if you don't notice that, no?
What i meant to say if you have require SMTP authentication for "Local to local e-mail addresses" for the "Internet" range you would never get a message from your own email address from the 'outside' when not authenticated...and after all, he claimed it was from his own email address, not name
