UpdateChannels.txt
fmail
UpdateChannels.txt
Post by fmail » 2019-03-23 18:15
Hi
What do you in the file? Not mush in my file, all are so old...
Re: UpdateChannels.txt
Post by SorenR » 2019-03-23 18:40
"updates.spamassassin.org"
Min SpamAssassin er en blanding af 3.4.0 og 3.4.2. Serveren kører på Windows Server 2003 og OS understøtter ikke 3.4.2.
Derimod fungerer min SpamAssassin træning helt fænomenalt!
https://www.hmailserver.com/forum/viewt ... p?p=164777
fmail
Post by fmail » 2019-03-23 19:11
Same in my file and a few line more, but all entry are real old, look like no one do maintenance on this anymore?
I also do spam/nospam training from users mail, but still SA let spam mail pass.
This last days been Mailserver maintenance day.
Post by SorenR » 2019-03-23 19:21
Well, you need to block as a minimum the "Static SPAM":
1: SnowShoe SPAM
2: LashBack SPAM
3: All domains ending in .icu (I have a thing going with the registrar of icu domains at the moment)
4: These domains; rememberbeherenow.com, 3dmeditation.com, luckydaeon.com, danzamor.com, kalosive.com, ssdspace.com, downpic.com, retpem.com, genpip.com, leinno.com, makze.com
When I look at my Eventhandlers.vbs I am surprised ANY mail is allowed throu, but we do receive all valid emails :mrgreen:
fmail
Post by fmail » 2019-03-23 23:08
hmmm may i kindly ask, how to do you first 2 step?
I think your step 3 and 4 is done in a blacklist file .cf like this:
blacklist_from @rememberbeherenow.com
blacklist_from *.icu
Right?
Post by SorenR » 2019-03-23 23:53
RBL...
SnowShoe:
RBL: zen.spamhaus.org
Return code: 127.0.0.3
Score: 1.000.000.000 ;-)
LashBack:
RBL: ubl.unsubscore.com
Return code: 127.0.0.2
Script (EventHandlers.vbs)...
Function isLashBack(strIP) : isLashBack = False
   Dim a, strLookup
   a = Split(strIP, ".")
      strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".ubl.unsubscore.com")
   If (InStr(1, strLookup, "127.0.0.2", 1) > 0) Then isLashBack = True
Function isSnowShoe(strIP) : isSnowShoe = False
   Dim a, strLookup
      strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zen.spamhaus.org")
   If (InStr(1, strLookup, "127.0.0.3", 1) > 0) Then isSnowShoe = True
Sub OnClientConnect(oClient)
   '   LashBack SPAM detection
   If isLashBack(oClient.IPAddress) Then
      Result.Value = 1
      Exit Sub
   '   SnowShoe SPAM detection
   If isSnowShoe(oClient.IPAddress) Then
      Result.Value = 1
      Exit Sub
DNSLibrary.DNSResolver can be found here.
Post by SorenR » 2019-03-24 00:02
fmail wrote:
2019-03-23 23:08
Right?
Oh, if only you knew... My Eventhandlers.vbs is currently 1428 lines and all criteria for Reject/Black/White-lists are in a 178 lines XML file.
The story begins here --> https://www.hmailserver.com/forum/viewt ... 20&t=33602
The XML handling has matured somewhat so I will be posting a new codebase soon.
Post by mattg » 2019-03-24 03:36
2019-03-24 00:02
Oh, if only you knew... My Eventhandlers.vbs is currently 1428 lines ...
Mine is currently 2658 lines...Don't know if that's good or bad though - probably getting to the point of being too big.
Post by jimimaseye » 2019-03-25 09:50
2019-03-24 03:36
2019-03-24 00:02
Remember that the eventhandlers script is loaded in to memory every time on each and every message that reaches your mail server either by SMTP or external download. Something to consider if you run a really busy server.
